Question about Pioneer VSX-35TX Receiver
VSX-35TX Four-year old (?) VSX-35TX has worked fine until recently. Now, if I advance volume about ~ -23dB, it goes into protect mode, shutting down. I can restart after ~ 5 minutes, but it will continue to cut-out. Seems like a thermal problem... am guessing accumulated dust may be preventing it from running at proper termperature. No changes in speakers (all are 8 ohm) nor in the positioning of the receiver -- it has several inches of air space all around for venting.
4 Suggested Answers
  • 14 Answers
SOURCE: Overload
try turning the unit off in standby mode then hold down the enter button and then the power button for about 10m seconds that should reset the unit depending on how new the unit is it sometimes has a digital saftey setting but i doubt that would cause it to do what you are saying
Posted on Apr 02, 2008
SOURCE: Pioneer VSX 915 powe off
Had a power surge last night and got the same problem. Unit wont power on and has a blinking blue light on standby button. I found the solution from the service manual for a similar model.
Hold down ENTER and ADVANCED SURROUND buttons.
This resets the DC overvoltage sensor and bingo the unit comes back to life again.
Posted on Feb 05, 2009
SOURCE: problem with pioneer vsx-916 av receiver
i have been using this with two speakers and was working perfectly fine . recently i bought two floor standing speakers and worked fine when connected . When i tried connecting all four speakers it showed overload kindly tell me how this could be solved
Posted on May 02, 2009
I have Pioneer VSX-1027; the volume drops 3 digits every three minutes and it keeps dropping three digits every three minutes until it reaches to the minimum..! Why does this happen? How to fix it?
It is a problem with the temp sensor circuit. The unit thinks it is getting hot, so it is trying to turn the volume down to avoid overheating. You either has a bad thermal resistor on the amp board, or you need to change the cpu board. Best to have it looked at by a pro.
Sep 26, 2016 | Pioneer Audio Players & Recorders
How intelligent is Pioneer's vsx amp/rec "power off" protecting mode? Hi, I would like to have an answer to the foregoing title in order to find out if it's worth repairing my Pioneer...
When you remove boards, you may be breaking a circuit somewhere that is causing the shutdown. Pioneer uses rear panel jacks for ground points a lot, and if even one of these screws is out it can cause it to shut down.
Sep 26, 2013 | Audio Players & Recorders
My power went out while watching TV. Now there is no sound when I turn my receiver to TV/SAT. If I put the receiver on CD there is sound but no picture. The receiver works fine if I go to DVD; there is...
It would seem the TV/SAT source is where the problem lies. No picture with CD? Really?
How about bypassing the receiver to prove what is failing?
Apr 21, 2011 | Pioneer VSX-35TX Receiver
Getting out of protect mode I have a Denon 787 receiver. It was working fine for 8 months. All of sudden, my reciever goes into protect mode after playing for about 30 min. Right after it goes into protect...
most of the receivers come with a cooling fan inside see if its working they usually work when you turn the volume up,, if its working that means you are playing it to loud if you lower the volume a little it will play just fine..( if the fan inside is not working thats the reason it goes into protect mode and it means you must have it repaired,, it goes into protect mode to prevent furter damage to the unit or the speakers,,
Dec 18, 2009 | Denon AVR-787
Pioneer VSX-D209 receiver shuts off when too loud
Dear Tabasco,
Your receiver is basically going into protect mode.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck! Thanks for using FixYa!
Apr 19, 2009 | Pioneer VSX-D209 Receiver
Black Box
You have inadvertently activated one of the closed-caption modes called T1 or Text 1. Find out how to turn the closed-captioning off and on and you'll be able to turn this off.
Mar 30, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
My pioneer VSX D2011 cuts to standby when playing music
Are you pumping up the volume when you connect the TV?
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate. Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck and have a great party!! Thanks for using FixYa!
Mar 11, 2009 | Pioneer VSX-D2011 Receiver
Pioneer VSX-35TX , "Power Off Message" , will not stay on.
It's probably going to need output transistors and some resistors, it's a job for a technician. A rough estimate on price is $100 to $130 (that's parts and labor). Before the smoke it may have only needed repair of bad connections.
Mar 08, 2009 | Pioneer VSX-35TX Receiver
My samsung HT-TX75 keeps shutting off in a few minutes saying protection.
protection mode activated to protect from serious damage and please follow me.1-shut down your system2-make volume in low position3-remove all your connected speaker4-switch your system on and watch if it does not go to protect mode insert your speaker one by one until you find the bad one and change it and start with cable change first and then speaker itself-if it goes to protect mode you must call service center.
Jul 07, 2008 | Audio Players & Recorders
Jun 18, 2008 | Pioneer VSX-915 Receiver
Pioneer VSX-35TX Receiver Logo
43 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
