Question about BenQ Scan to Web 4300U Flatbed Scanner
Realistic pro-2011 direct entry programmable scanner 20 channels
Does anyone know where I can find iowa scanner codes for this? And how to program it? Picked it up at a sale and thought it would be nice to listen to in my home but dont know how to do it-plz help
Its easily done. If you go to Googles site, and put iowa scanner codes in the search space, one of the choices there will be >>>>>
http://www.radioreference.com/forums/iowa-radio-discussion-forum/36607-ultimate-iowa-scanner-frequency-page.html
Posted on Apr 16, 2009
PRO-2011 Programmable Scanner (200-0118) Operation Faxback Doc. # 34694 PROGRAMMING FREQUENCIES 1. Select the desired channel in one of three ways: (a) Press [MANUAL]. Continue pressing until the display shows the desired channel. Press [PROGRAM]. (b) Press the desired channel and [MANUAL]. Press [PROGRAM]. -- or -- (c) Press [PROGRAM]. Press the desired channel. Press [PROGRAM]. 2. Type in the Frequency. NOTE: If you are uncertain about specific frequencies in your locale, RadioShack's "Police Call Directory Including Fire & Emergency Services" is an excellent reference. 3. Press [ENTER]. To program the next frequency, press [PROGRAM] to advance to the next channel Repeat the same steps to add more frequencies. HINTS AND TIPS FOR PROGRAMMING When you make a mistake while entering a number, press [CLEAR] and re-enter the correct frequency. If you enter a frequency that is outside a PRO-2011 band range, Error indicator lights. Press [CLEAR] and select another frequency. Any frequency within a PRO-2011 band range will be accepted. However, the frequency that can be stored into PRO-2011 memory is in 5 kHz step in the VHF bands and the 12.5 kHz step in the UHF bands. The scanner will automatically round off the entered frequency to the closest valid frequency. For example, if you enter 145.234 MHz, the PRO-2011 will accept this entry as 145.230 MHz. Or the entry 398.263 MHz will be treated as 398.262 MHz. The tuning range of your PRO-2011 is permanently stored in the microprocessor chip. There's no way it can be extended or altered -- even by a skilled electronics technician. So if you try to enter a frequency not in the PRO-2011's tuning range, you'll get an error message every time. If you want to change the frequency entered for a specific channel, enter the new frequency over the old one, following the steps in "PROGRAMMING FREQUENCIES" (above). (IR-09/25/96) Privacy Policy
Posted on Mar 05, 2009
Go to radio shack buy police call book it will be in there
Posted on Aug 28, 2009
Realistic uhf/vhf model 20-400 pro 58 ten channel. Where can I get an owner's manual?
Products associated to Radio Scanners - RadioShack.com
support.radioshack.com/productinfo/ProductResults.asp?...Scanners...
Get Acrobat Reader. Previous Page. Products associated to Radio Scanners. SKU/Catalog #, Model, Description ... 20-139 · Realistic PRO-38 10-Channel Direct Entry Programmable Scanner ... 20-313, Pro-76, Pro-76 200-Channel VHF/AIR/UHFHandheld Scanner ... 20-400 · Realistic PRO-58 Programmable Scanner.
Dec 18, 2015 | Radio Shack Radio Communications
Can a realistic pro 55 model 20 124 be programmed to different frequencies?
Hello, your scanner appears to be a 10 channel crystal controlled scanner. I'm estimating it to be around 30-40 years old. I think there is a couple companies still making custom crystals but you have to find the freq's #'s to give them. Here is the freq. range it will pick up. Frequency range RX 30-50 / 144-174 / 450-512 MHz I personally would take the money spent for crystals and apply it towards a newer scanner that is programmable so no crystals needed. Here's a link to some more info;
RadioShack Realistic Pro 55
Sep 07, 2015 | Radio Communications
I need to know how to reset my Realistic pro-41
PRO 41 10 Channel Programmable Scanner 200 0301 Operation here is a link to instructions on how to unlock the channels or reset your device, hope this helps
Sep 02, 2014 | Radio Communications
Www.radioreference.com
Setup an account at Radio Reference dot com. If you get a premiere membership, you can do much more. Here is a sample link for Hamilton, Ohio / Butler Country Ohio to see what it is like. Let mw know if you have any more questions. https://www.radioreference.com/apps/db/?ctid=2048
Feb 09, 2014 | Radio Shack Realistic Direct Entry...
Realistic patrolman pro16A radio scanner, do not know how to program freq, this scanner does not have crystals, does anyone know how or have a manual??
I have checked several sources, and they all show that the PRO-16A is a 16-channel VHF/UHF CRYSTAL scanner. Remove the bottom cover and you should see the crystal sockets.
http://radiopics.com/RS-Realistic/PRO-16A.htm
Bill B.
Listening in since the 60's
Oct 14, 2010 | Radio Shack Radio Communications
How do i program my realistic pro-2025 scanner
PROGRAMMING CHANNELS
1. Turn on your scanner by turning the volume clockwise.
2. The scanner might start scanning. If so, press MANUAL to stop the
scanning.
3. Enter the channel number that you want to program and press MANUAL.
4. Enter a frequency including the decimal point. The decimal point shows
up on the display as a -- (dash).
5. Press Enter to store the frequency.
6. To confirm the proper entry, press REVIEW. The programmed frequency
appears on the display one digit at a time.
7. To program more channels repeat steps 3-4.
Jun 03, 2009 | Radio Communications
BenQ Scan to Web 4300U Flatbed Scanner Logo
3,119 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
