Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Convergence problem I have a panasonic hdtv projection monitor (pt-53wx53) all of a sudden the bottom of the scene gave a doubling effect, blueish coloring.I believe it to be a convergence problem. when I try to correct it I can't get the blue cross to go down to match up the cross, it goes side to side only.
    Scholar:
  • 150 Answers
Hi, you`ve lost the convergence IC`, requires a good knowledge of soldering and. posssibly an alignment after replacement, good luck, video-tek
Posted on Feb 14, 2009
I own a Panasonic HDTV projection monitor PT-47WX42C I am having convergence/warping issues; There is a large green/red curve in the bottom rear of screen about 4 inches tall, and stretching over more...
Replace the convergence ICs they will be big black ICs and will have Part number on them example STK392-110
Mats Electronics has them for 9.95 each you will need 2 .
1-800-628-1118
Sep 10, 2010 | Panasonic PT-47WX42 47" Rear Projection...
I have a Panasonic HDTV Model PT-53WX53G. I am getting a 3D / Double screen effect.
This is the convergence chips. They are 18 pin Amplifier IC Chips that control your three tubes to line the colors up. They are only about $20 each (there is two of them). They are difficult to replace if you dont know how to solder/unsolder. There is usually at least one resistor or fuse that will blow when the chips go out, you must replace this also. If you have no experience in electronics then i'd suggest you take the set to a pro.
Aug 27, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Picture shows double images in red and green with red and green bands across the bottom of the screen
convergence ICs need replacement there are two STK392-110 Convergence ICs in that model, Also check the 2.2 ohm 2watt resistors there are 6 of them in that model.
Jan 22, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Double vision on the words with blue tint
Convergence failure. The PT53WX53 convergence repair kit available from www.tvrepairworld.com will usually repair that issue. The kit contains the Two ICs , six resistors and the CD with repair instructions
Dec 01, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53wx53 rear projection tv does not turn on, blinking
Thats the error code for the convergence. You can get the PT53WX53 Convergence repair kit at the following link. www.tvrepairworld.com
the kit contains the parts and CD with instructions
Aug 14, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Double Display on screen
The convergence Ics need replacement along with the 2.2 ohm 2 watt resistors. There is a repair kit available for your model which contains both the ICs and all six of the resistors and contains step by step instructions with pictures. Heres the link to the repair kit.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Mar 06, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Bad Picture
you need to replace both STK392-110 Convergence ICs. You can get replacemnet ICs at the following link with free installation instructions and free tech support. You will need two of the ICs. Heres the link.
Aug 21, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Hdtv projection monitor (pt-53w-42h panasonic
bad convergence ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 21, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Green....purple....colors
If you are technically savvy and you can solder.....requires
chassis pull...replacement of convergence IC's...mounted on large heatsinks on board to the right looking in from rear....If
you want help........Let me know................T.
Dec 27, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Cannot adjust convergence, screen has rainbow effect
You probably need to change out the semiconductors. The parts are STK392-110. There are two of them, one for horizontal and one for vertical. Search it online more.
Dec 28, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
194 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
