Question about HP Officejet Pro L7580 All-In-One InkJet Printer
HP 7580 Paper Jam made piece pop up in the way of carriage
I was printing an envelope and it jammed. I opened the printer and pulled the envelope out but when I did it made one of four little pieces (black plastic with little rubber rollers on the bottom, looks like they hold down the paper and/or feed it through) pop up and I can not get it to go back down. These are under the carriage so now it sticks up into the way of the carriage.
I have tried wiggling, pushing, pulling the plastic piece that looks like it should go back down easily but it will not go and I am afraid forcing it down will break it.
    Sergeant:
  • 242 Answers
Two choices; 1. Take the machine apart and take the roller out and then bend back the little follower.
2. Break the offending follower off and hope the paper still feeds through OK.
Posted on Apr 28, 2017
2 Suggested Answers
laxmankumar
  • 191 Answers
SOURCE: HP 7580 Paper Jam made piece pop up in the way of carriage
Please go through the web link given below and follow the instructions to clear the paper jam without damaging your printer.
bc://bt/QUEvVGVybWluYXRvciBTYWx2YXRpb24gMjAwOSBDQU0gWFZJRC1GRUFSLzg4OTg5NDI5OC8zMzQ2MmI4YTEyZDQ4MzIxNDVmOWVkNGQwNTFiZjBjM2ZkNmFiMzZhL1pa
Posted on May 28, 2009
My officejet 5610 says "carriage jam. Open Door etc. I can't find a door to the carriage.
Hi!
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is on.. open the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper from the roller...return the paper output tray and the carriage access door. plug the power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriage access door.
disconnect the power cord from the back..remove the paper output tray...look inside if the carriage is stuck and if there is no papers or object that restrict the carriage to move..return the output tray.. return the carriage access door...
And lastly after doing this steps try to reset the printer and try to print..
To reset the printer....press the power button to turn on the printer..disconnect the power cord from the product..disconnect the power cord from the wall outlet.. wait for 15 seconds.. plug the power cord to the wall socket....plug the power cord at the back of the printer.. press the power on of the printer.. try to print the test page...
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
May 23, 2010 | HP Officejet 5610 All-In-One InkJet...
HP j5780 printer sends "paper jam" message AFTER it prints one page. there is no apparent jam in all the places I have looked. I am in need of a repair manual (not an owners manual).
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
May 12, 2010 | Office Equipment & Supplies
Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
May 08, 2010 | HP Officejet Pro 850 InkJet Printer
May 28, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
The paper won't advance enough to print in our HP officejet 7580
Look for little pieces of paper that get stuck in the rollers, also verify that the gears and roller didn't get misaligned when you cleared the jam.
Good Luck,
Mar 02, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Carriage jam message HP D7360
Try opening the top cover again and look into the printer with the help of flashlight or some light. I think you will find that there is paper stuck on one side of the carriage. Do this aspa since if the pape is really there, t will not let the carriage sit over the rubber gasket and will dry the ink out.
303Electronics eBay Stores
http://www.303electronics.com/
Jun 01, 2017 | HP PhotoSmart C4280 Laser Printer
Paper jam from printer an envelope. I got out the envelope except for a small piece about 2x2 and I can't find it. Now my printer will not work at all and it says carraige jam. I tried putting a piece of...
More than likely, there's paper stuck in there somewhere. It's causing something not to move right, and then the carriage is getting **** on whatever part isn't moving right.
Turn the printer off, and then lay it out on a table. Take whatever panels you can off, or open them. Go through the paper path like a fine-pick-comb and find that piece of paper.
Hope this helpe :>
Jul 26, 2008 | HP Photosmart 3310 Printer
HP 6180 printer
henryandjane,
Look over on the wheel that will feed the paper mybe there is a tiny piece of paper on it and find the sensor for the paper mybe it is stack-up already
Jul 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
267 people viewed this question
Seeker5211
Seeker5211
