Step 1 - Start your PC and place your Windows XP
CD in your CD/DVD-ROM drive. Your PC should automatically detect the
CD and you will get a message saying "Press any key to boot from CD".
Soon as computer starts booting from the CD your will get the following
screen:
Step 2 - At this stage it will
ask you to press F6 if you want to install a third party Raid or SCSI
driver. If you are using a an IDE Hard Drive then you do not need to
press F6. If you are using a SCSI or SATA Hard drive then you must press
F6 otherwise Windows will not detect your Hard Drive during the
installation. Please make sure you have the Raid drivers on a floppy
disk. Normally the drivers are supplied on a CD which you can copy to a
floppy disk ready to be installed. If you are not sure how to do this
then please read your motherboard manuals for more information.
Step 3 - Press S to Specify that
you want to install additional device.
Step 4 - You will be asked to
insert the floppy disk with the Raid or SCSI drivers. Press enter after
you have inserted the disk.
Step 5 - You will see a list of
Raid drivers for your HDD. Select the correct driver for your device and
press enter.
Step 6 - You will then get a
Windows XP Professional Setup screen. You have the option to do a new
Windows install, Repair previous install or quit. Since we are doing a
new install we just press Enter to continue.
I bought custom barebones with no OS.When i try download XP
from CD,it doesn't recognize the hard disk.First i thought the hard disk is bad,so i replaced it.Same problem.I talked to proffesional
and was told that i need a driver .I know how to integrate it in install disk,just don't know where to find it.
Could you explain why you need the driver? As far as I'm aware, you don't need it.
