Question about Toshiba 42H81 42" Rear Projection Television
42H81 Convergence issues
I picked up a 42H81 last week for free locally. I brought it home plugged it in and noticed the convergence was off, maily the red. I had a pair of stk392-110 ICs here and installed them along with the 1.8 ohm 1w resistors. I plugged it in and still no fix.
I'm new to this field but very skilled with an iron and not afraid to try anything.
I noticed while it was on the something smelled like it was getting warm. I looked at the resistors and the very same one that was bad to begin with was getting hot, the colors changed on it. Now, the one thing I did notice was the band that holds the convergence yoke to the tube was off, just hanging there, no bolt in it!! I went to the hardware store and picked one up and installed it. When I first turned it on after installing the amps was the red was shifting before my eyes so I shut it down (couldn't be good). The red didn't shift this time but still didn't fix the issue and the resistor was still getting hot.
This set has 2 main boards and it looks like half of the convergence is on the power board. I did check that side and there is 4 resitors that are out of spec and 1 of them has almost no resistance at all.
Is it possible that the convergence yoke is shorted in some way?
Could I turn this set on with the wires to that yoke dis-connected to find out if that is the source to my problems?
I'm no wiz with these yet but it seems to me (bear with me please) that the STK originally went south and everything powering it took a hit. There is one fuse on that circuit open. Maybe the hit fried that resistors and now that I have changed the parts they are getting too much power?
Thank you for any replies, good or bad.
  • redrobin29 Feb 15, 2009
    I'll have to wait for the resistors to come in for the power board. They should be here tomorrow. The fuse that was popped on the power board isn't a pico fuse and I cannot find it anywhere online, can I replace it with a pico fuse of the same rating?
    I'll post back with my findings.
    Thanks!
  • redrobin29 Feb 24, 2009
    I orderd the new 2sj512 FET that is in front of the resistor that is getting hot and it's still frying that resistor?
    I'll tear back into it and recheck everything again...
    Novelist:
  • 184 Answers
I've seen a few shorted convergence yokes in toshibas. Sometimes after running the TV for a few minutes, you can feel the relative temperature of the 3 yokes to tell which is overheating and therefore shorted. Don't forget to re-check all the low resistance resistors around the convergence ICs to make sure that the are within the 5% tolerance rating they should be. Also on some of these models, there is a jumper wire located near one of the ICs that develops an intermittent solder connection.
michtech
Posted on Feb 15, 2009
  • Billy Bauer Feb 15, 2009
    michtech
Toshiba model 42H81 projection tv receiving blue and yellow shadows on screen.
Convergence is dead.Know how to solders?Must replaced the 2 convergence ICS and all it resistors.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 06, 2010 | Toshiba 42H81 42" Rear Projection...
Colors separating...convergence issue
If you have any electronic soldering skills you can replace the convergence amp IC's which are part # STK 392-110. Buy the expensive IC's which are made by Sanyo and they last longer.You can buy these from www.encompassparts.com for about $30 each.
Buy some desoldering wick from radio shack to assist in removing the old IC's.
Jul 29, 2009 | Toshiba 42H81 42" Rear Projection...
RCA 46'' rear projection TV, dated 1998 won't turn on
Probably a new problem given the age of the TV. If you already haven't done so, try unplugging the power for about 10 minutes, plug back in and try again.
Jul 07, 2009 | Televison & Video
Toshiba TP43H60 Convergence Problem
This may sound odd but try moving the remote further from the set. I have seen similar issue with my 42H81.
Jun 01, 2009 | Toshiba TP43H60 43" Television
PT-53wx53g Convergence issue?
Both convergence amplifiers should have been replaced at the same time. If you can get your hands on a service maual, replace both of them, and go through the convergence alignment in the manual.
Jun 01, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Service manual for 42h81
Email me privately and I can send you one via Pando... You will need Pando to download it but it in itself is a free download... Be precise in what you're asking when you email, I get more than 3000 emails a day so it will be impossible to figure out what you need without you telling me.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Nov 05, 2008 | Toshiba 42H81 42" Rear Projection...
Convergence problems
you need to replace both of your convergence ICs they are STK392-110 you can get new replacements at the following link and they provide free instalation instructions with pictures. Heres the link
http://servicemanuals.vstore.ca/
May 29, 2008 | Toshiba 42H81 42" Rear Projection...
Convergence
you can replace these your self if you can solder and are mechanical. there are two stk ic attached to a silver heat shield
You can call or on line give them the model number and tell them you are looking for the convergence ics The part store .com
www.partstore.com
Be careful unplug if it looks to hard please call your local tv shop the fix for a shop is around 250.00
Thanks doctor video
May 20, 2008 | Toshiba 42H81 42" Rear Projection...
Convergence issues
Drifty convergence IC's need replacing..located on center PC board......STK392-570...change them both for reliability...T.
Feb 28, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Toshiba Model # 42H81 Picture Problem
Can you describe the issue a little more? It may be a convergence issue which is quite common on big screens. But there are quite a few issues that can cause a bad picture.
If it's convergence, you'll be able to tell by going to a news channel and looking at the text. If the convergence is bad you'll see a ghosting like image of 2 or 3 letters for each one that should be there.
Nov 25, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
134 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
