Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Refrigerator not cooling
I have a Hotpoint side by side refrigerator, model # HSS25IFMB ww, and the refrigerator is not cooling well. I have it turned all the way up to see if it will help but hasn't. It keeps the food and drinks a little cool, but not cold. I cleaned underneath and in the back to remove the dust, but that did not help either. Any suggestions?
  • 2 more comments
  • wooser99 Mar 13, 2009
    same problem i set the controls to the center how long is the testing period
  • ljbrooks Mar 19, 2009
    What do you do after you set the temp to middle setting?
  • kfyearout May 18, 2009
    same prob. what after settings to middle?
  • Anonymous Mar 22, 2014
    not cooling enen on coolest setting
    Novelist:
  • 117 Answers
Check in the freezer section by removing the food exposing the rear inside panel. DO you see frost beginning to build upon the rear inside panel of your freezer section? If so, the is a simple defrost problem and can be repaired easily. For testing purpose, st both control to the middle setting and do not move them during the entire testing period. Moving the controls only makes things worse.... Let me know what you find....
Waiting to hear from you,
Eric Campion
Posted on Feb 14, 2009
We had the same problem with our HSS25GDMDWW side by side. Only 5.5 years old. Freezer cold, refrigerator not. Found that the little door on top left connecting the freezer (which actually cools the fridge) was stuck closed. You have to remove the cover. We then shut down the freezer control to and refrig to zero. Brought both back up and then helped manually open the door. Did this a couple times to make sure no more sticking. For two days after that the freezer kept running. I thought we had another problem. But after two days, the temp in the fridge came back to normal and the motor finally shut off. It probably means we will need a new fridge soon, but at least not right now. We already replaced the actuator for the icemaker inside flap which wasn't closing causing the inside to frost up and sometimes melt the ice just enough to make it hard to dispense.
Posted on Apr 17, 2009
Hotpoint HSS25GFPA WW Freezer not cooling
check for ice build up on evap coils ,,, bad efrost cycle
Oct 05, 2014 | GE Refrigerators
After a moving to a new city, we had our Hotpoint model HSS251FMD WW refrig in storage for 4 months. When I installed it in our new house it will not cool. Is there a reset button?
flush the refrigerant by nitrogen & refile new refrigerant.every work doing by qualified technician.my be some compressor oil over com in freezer
Jan 03, 2011 | Hotpoint Refrigerators
Where is the hotpoint HSS251FMD WW defrost timer located?
Hi, I think Your model number is HSS25IFMDCC . There is no defrost timer on your refrigerator, main relay board controls defrost cycles in this fridge. main board p/n WR55X10942 But I suggest to check on heater and defrost switch first - more common problem on this refrigerators. here is my video. hope it helps.
Aug 24, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Inside my side by side freezer side (hss25gfta ww)
The ice maker water inlet valve has failed allowing water to pass when it is not supposed to pass. The water valve is item 800 of this link. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5203104&diagram_id=24933031#d24933031
Changing the water valve most always returns the ice maker operation back to normal.
Kelly
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
I HAVE A wailing HOTPOINT HSS25GFPH WW refrigerator
change the rubber isolating washers on the pump and compessor too hard a compound will make things worse ,neoprene works best ......
Feb 07, 2010 | Hotpoint HSS25GFP Side by Side...
Freezer and fridge are not cooling but we hear the sound of the refrigerator
your defrost heater or timer is not working . rotate you defrost timer until it clicks and check if its is defrosting if it is let it defrost for about 10 mins and turn the timer some more to take it out of defrost. replace timer
Jun 02, 2009 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25IFMB WW will not defrost.
I was having the same problem. I replaced my defrost heater (2 screws and 17 dollars) and it works great now
Mar 09, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Hotpoint hss25gfpaa ww
easy to change. no reconfigure required.
Oct 22, 2008 | Hotpoint HSS25GFP Side by Side...
Not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
Sep 24, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
692 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
