Question about Sharp R-520LK Microwave Oven
Primary intelock switch on a Sharp R-520Lk continues to fail
This microwave is just over 1 year old. I replaced the primary interlock switch in December 08 and now in Feburary 09 it has failed again. When I examined the switch it appears to have melted the case at the NO contact. The switch is an Omron D3V-16G-1C25, which I assume is rated at 16 amps. I looks like the power lead of the fan motor, turntable motor and primary of the power transformer are in series with this switch. The return of the motors and transfomer goes through the cavity temperature fuse and the magnetron temperature fuse. Is this a common failure of the model?
  • Sharp Master
  • 9,098 Answers
That switch carries the current of the turntable motor, fan motor, and the high voltage section.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
It causes a spike at opening that eventually arcs and pits the contacts inside, and it can cause melting of the case.
You should check the switch mount for cracks, too.
Sometimes excessive current can make them fail too, but your fuse should blow before the switch.
We have the full service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
We're happy to help you. Once we have all your information and offer a final solution, we'd appreciate your thoughtful rating of our answer.
Posted on Feb 15, 2009
I have a sharp carousel microwave model R-305 K it has just stop heating its running like it is heating but it not. this micorwave is only 2yrs. old.What could be the problem
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Mar 05, 2011 | Sharp Microwave Ovens
My sharp microwave/convection oven come on, clock counts down but it does not heat nor does the turntable turn. About a week ago the breaker was tripped by it I think but it was fine until now. It doesn't...
It sounds like one of the door micro switches is bad. There are three micro switches typically. A primary interlock, a secondary interlock and a monitor switch. It is most likely the primary or secondary interlock switch. You may need to take your switches to a professional appliance shop to determine which one is bad.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 22, 2011 | Sharp R-930AK Convection/Microwave Oven
Microwave not heating up
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 15, 2010 | Sharp R-1502 Microwave Oven
My sharp r-340f works for 10 seconds, then turns off, then turns on again but with the countdown timer not counting down. Moreover, no microwave radiation comes out. Thus, the food is still cold after...
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Hope that helps.
Nov 23, 2010 | Sharp R-340 Microwave Oven
GE Advantium Microwave section doesn't work.
The primary interlock switch on my Advantium has failed twice. The replacement part is available at: appliancepartspros.com part no. for my Advantium was AP2622452 and it cost $11.74 + $6.95 shipping.
For what it's worth, my nylon connector and wire covering were also scorched a bit but the last primary interlock switch lasted me for over a year.
Please note that I am not an expert at repairing appliances and that I assume no responsibility or liability for any attempt you may make to repair your own appliance.
May 30, 2009 | GE Advantium SCA2000B Microwave Oven
SHARP MICROWAVE R9H20 STOCKED FOR LONG
if the problem is tempermental then is sounde like you may have a failing interlock switch. this is a series of switches that are activated then the door closes. there are normally 3 and you would be looking for/ replacing the middle the Primary interlock...
Hope that helps
Jan 11, 2009 | Sharp R-510HW Microwave Oven
Fuse
The Interlock Monitor Switch is an added
safety check on the Primary and
Secondary Interlock Switches. If the
Primary and Secondary Interlock Switches
allow the oven to operate with the door
open, the Monitor Switch will blow the
fuse.
You can get more information about adjuting the interlock switch from this link
http://136.166.4.200/contents/Microwave/LMVM1935xx/LMVM1935xx_Service_Manual.pdf
sections 7-11 thru 7-12 discuss the door interlock adjustment that will cause the 20A fuse to blow if it isn't set up right. I hope this helps you...
Aug 03, 2008 | LG LMVM1935 Convection/Microwave Oven
JMC7000ADW Blows circuit breaker
I've had this problem twice with our microwave. The hint to where the problem lies is that the breaker blows when you open the door at times. Inside the microwave are three microswitches; primary and secondary interlock micro switches and an Interlock Monitor switch. The switches are supposed to shut down the microwave if it is running and the door is opened. But, I've found the upper primary switch can stick internal at times and when the door is opened the stuck switch will, because of the way it is wired as a safety switch, cause either the fuse or possibly the main circuit breaker for the oven to pop. The reason the stuck switch blows the breaker or fuse is when the door is opened the interlock switch will cause the neutral wire from the AC power to be applied to the Upper Primary Interlock switch which normally should be open when the door is opened, but if the switch is intermittent or the contacts weld themselves shut the neutral line is connected direct to the "hot" side of the power line through the fuse and thermostat. The first time my microwave failed the switch had melted the contacts together inside the switch and the second time the switch became intermittent and would blow the breaker to the over ever so often. I suspected the switch the second time this happened and utilizing an ohm meter I checked the switch several times by opening and closing the door and once in a while it would remain closed instead of opening when the door was opened. Of course while trouble shooting the power cord to the microwave must be disconnected and use all safety precautions when working around the high voltage areas inside the microwave. I wrote Jenn-Air about the bad switch and the way it is wired into the circuit, but never received any acknowledgement. I suspect these microswitches are under rated for the amount of current that passes through the switch, thus they overheat and eventually arc the contacts together. I hope this helps explain the intermittent problem and could explain many of the intermittent blown fuse problems I see in these internet help sessions
May 09, 2008 | Jenn-Air JMC7000 Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Waleed, Since the microwave is going through all its motions we can feel safe that the oven and magnetron thermostats are ok. If they were bad you would not have a display. Just inside the control panel to the left, you have 3 switches which the door activates. A primary (top switch) a secondary (bottom switch) and a monitor switch (middle). If the primary or secondary switch is not closing when the door is shut, you high voltage side will not activate, therefore no heat. If the monitor switch failed or found either the primary or secondary switch closed with the door open, it would blow the main fuse and the oven would be dead. Therefore Im leaning on either the primary or secondary switch not operating correctly. When checking these switches, unplug and discharge the capacitor. This is high voltage. Good luck
Jun 17, 2006 | Sharp R-340 Microwave Oven
Sharp R-520LK Microwave Oven Logo
367 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
