Baby Gear Logo
Posted on Feb 14, 2009
Adjusting straps on baby carrier
Lost the instructions and need to know how to make the arm straps for the baby go up another slot
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Feb 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
377
Points
Hi. here is the website that may be helpful to you..
https://plweb.evenflo.com/replacement_parts.aspx
6helpful
The waste buckle on my ergo baby carrier broke. I don't know how to go about getting it replaced.
Replacement buckle for your model can be found on amazon. Click here and take a look: Amazon com Ergo Baby Carrier buckle. I hope this was helpful. Cheers
Adjusting harness (make it large enough) on discovery 5 evenflow
You can download this PDF instructional manual for the Evenflo Discovery car seat: https://www.google.co.il/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&cad=rja&ved=0CHUQFjAH&url=https%3A%2F%2Fplweb.evenflo.com%2FShowDocument.aspx%3FManualID%3D583&ei=A8UtUbW5AY_Z4QSCjoDoCA&usg=AFQjCNFj1O1EuRQVLmKwgOLTJsL6yoeOTQ&bvm=bv.42965579,d.bGE
You can also read this article on how to adjust the harness straps on an Evenflo car carrier: http://www.ehow.com/how_6391052_adjust-evenflo-car-carrier-straps.html
I need instructions for the genki house baby carrier and for the bubba moe baby sling
Here are Genkihouse Sling instructions - I tried to attach scanned copies of the instructions, however it exceeded the file size limit:
For front use
  1. Hold your baby close to your chest
  2. Still holding baby close to your chest, grab sling and place over baby - Genkihouse logo facing away from you, arrange baby's legs through leg openings. Alternatively, you can lay the sling on a change table with logo facing down, lie baby on top and put legs through leg holes then lift the baby and the sling onto your chest.
  3. Still holding baby close to you, place sling straps over your shoulders.
  4. Reach behind with one arm (still holding baby with the other) and firmly take the strap from behind opposite shoulder. Your other arm still holds the baby and sling.
  5. Thread the strap through D ring with one hand whilst your other hand still holds the baby.
  6. Simply 'hook' the strap through the D ring with your index finger.
  7. Do not change hands at this stage.
  8. Tension strap backwards - away from your back and don't let go.
  9. Feel the baby's weight now firmly supported by the sling at your waistline.
  10. As you continue to hold the same strap reach behind with the other hand and thread the second strap through its D-ring. The straps should criss cross over your back.
  11. Bring straps together, adjust tension to suit and tie a secure knot in the middle of your back.
  12. Check the position of the baby - you should be able to kiss his/her head.
  13. Baby can also face outwards when he/she gets older.
Jun 15, 2011 • Baby Gear
1helpful
We recently purchased A Baby Trend pack and play from a friend and she lost the instruction manual. We need a manual My email address is [email protected]
These are easy. Just make sure the middle pull strap/handle is up like a volcano in the middle of the bottom of the crib in order to RAISE or LOWER the sides. It's a saftey feature. Nothing goes up or down if the bottom is flat.
Can't make Baby Bjorn Active Comfortble
Use the size adjustment buckle to produce a comfortable fit for you and your baby. (The Baby Bjorn Active Baby Carrier is adjustable both for the baby and the parent). Make sure you are using BOTH adjustments, rather than merely adjusting for one or the other of you. Think of it as putting on (and tying) two separate shoes. Both should be nice and snug. Every review that i have said says these are never as comfortable as a wrap, but seem to be more convenient.
  • Step 3 use-bjorn-active-baby-carrier-1.3-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep3 span.image a:first').attr('href','http://i.ehow.com/images/a04/ur/dd/use-bjorn-active-baby-carrier-1.3-800X800.jpg'); }); Unbuckle one or both of the side straps when taking the baby in and out of the baby carrier. This makes the job much quicker and smoother and everyone will be much more content.
  • Read more: How to Use a Baby Bjorn Active Baby Carrier | eHow.com http://www.ehow.com/how_5205421_use-bjorn-active-baby-carrier.html#ixzz0wKrU4VJb
    1helpful
    Putting on the infantino front2Back rider. Do you have any video instruction on putting on the infantino front2back rider?
    I don't have video instructions, but I might be able to explain it.
    Find the straps that go on your shoulders. I know the right one has a warning label on it - they might both have it. The labels should be against your body, and the square where they meet should be on your front or back depending on where you want the baby.
    Fasten the waist strap (has an odd oval shaped buckle) and the strap higher up between your shouders. If this second strap is too tight, you have to lengthen the shoulder straps.
    Next, find the velcro bits that have buckles near them. These need to fasten above your baby's legs. do up the velcro then the buckles. Finally, the buckles over your baby's shoulders need to be attached to the little knobs on your shoulder straps. Squeeze them, fit them over the knobs and release.
    If you're on your own, you might want to put the baby in first and then fasten it to yourself, I just find it easier to put it on myself first.
    2helpful
    2answers
    Need instructions on how to strap baby in rear facing in Evenflo Snugli Comfort Vent Soft Carrier
    I went to this website:
    typed in the model number and manufacture date (both are on a label on my Snugli), and a pdf of the instruction manual came up. Hope this helps!
    By avatar8.jpgterraplnr Aug 03, 2008
    Evenflo carseat,can't figure out the straps after washing
    You need to put the straps throught the bottom, then the top openings you put it through the 2nd **** or where the baby will be comfortable. Then you tie it on the back.
    Jun 17, 2009 • Baby Gear
    Backstrap slid out
    There is a recall on this model. The company will send you a new holding device for the back straps that has screws instead. See the babybjorn.com website for more info.
    2answers
    Infant Rear facing car seat
    ON THE BACK OF THE CAR SEAT ARE TWO LATCHES SIMPLY REMOVE ONE BY PUTING THE STRAP THROUGH THE LATCH AND ADJUSTING IT TO YOUR CHILD FIT DO THE SAME TO THE OTHER. LET ME KNOW IF I WAS ANY HELP...
    Top Evenflo Baby Gear Experts
    ZJ Limited
    ZJ Limited
    Jennifer Rock
    Jennifer Rock
    john h
    Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
