Question about SanDisk Sansa e200 MP3 Player
Stuck on refresh database
My sansa e250 is stuck on fefresh data base please help me
  • 8,596 Answers
I would use the Sansa Recovery Tool to return the player back to normal, since it is easier and less perilous than reformatting, but here are other methods you can try:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Feb 14, 2009
Refresh database
Did you try reseting it?
May 25, 2008 | SanDisk Sansa e250 MP3 Player
Refreshing database
User guide for Sansa e200R:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Check this link for Sansa e200 "freezing in refreshing database",
2 steps to follow up:
http://kb.sandisk.com/app/answers/detail/a_id/34/kw/e200r%20freeze/r_id/101834
1. Reset the device as described on the site of Sandisk.
http://kb.sandisk.com/app/answers/detail/a_id/189
If resetting didn't solve your problem
2. Update the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/306
2.1 Use the Sansa Firmware Updater for a download of your device
with the next link:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
2.2 Follow the instructions "update the firmware" for sansa e200 series:
http://kb.sandisk.com/app/answers/detail/a_id/306/kw/e200r%20freeze/r_id/101834
Sep 20, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
MP3 needs to refresh DataBase?
You have to many songs a sansa e 250 only holds a certain amount of space so your best bet is to buy a memory card or delete songs so you can add new ones.
sincerely,Britani
Apr 19, 2008 | SanDisk Sansa e250 MP3 Player
Simply reset the Sansa e250 by holding the power button down for 10-15 seconds.
Jan 15, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database
I by mistake formatted My mp4 there misssing my data
Dec 08, 2007 | SanDisk Sansa e250 MP3 Player
Refreshing data base
It refreshes the database to build the menu for you to navigate.
Your device may have corrupt data in it and therefore takes longer than normal to build the library.
You can format the device to remove everything, and then re-transfer them to see if that helps.
To format in My Computer>Device Name (e250)>right Click and select format.
Best of Luck.
Oct 12, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 screen is stuck on refresh database
Press the "lock" button to where the Orange is showing. Then press the record button on the left side of the MP3 for a bit. Try this several times. I did it twice and it worked! M.P.
Aug 04, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
