Question about Ariston Technologies AW 129 NA Washer With 1200 rpm max and 16 lbs/7.5 kg. Load Capacity (AW129NA, AW129 NA, AW-1...
ARISTON AQSF 129 EU COD F5
My washing masine ariston aqsf 129 eu stop and aan f5 cod appear
  • 6277 Answers
SOURCE: my washing machine ariston et
Ariston (Indesit) F05 probably indicates that the drain motor filter is blocked and needs cleaning. Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 22, 2011
Testimonial: "Thanks John!"
SOURCE: ariston a1636 washing machine
I have the same problem, did this get solved for you?
Posted on May 18, 2008
  • 10 Answers
SOURCE: we have the Ariston Margherita front loader
if the machine is full of water pump blocked or broken if machine empty needs new door interlock or pressure switch blocked or broken
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Posted on May 17, 2009
barkencoa
  • 3463 Answers
SOURCE: Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Posted on Jul 24, 2009
  • 53 Answers
SOURCE: I have an ariston amd 129 washer dryer. F-10 keeps
F10 - Pressure switch not sensing correctly. blow in to switch gently it should click. blow into pipe should be clear.
Posted on Oct 14, 2009
How to change noisy bearing on Ariston AQXXF 129
inner and outer drum has to b removed replace the bearing kit 2 bearings one oil seal as kit
Aug 25, 2014 | Ariston Technologies Washing Machines
Ariston artxf 129 error f02
F02: Blocked Motor, Short-circuited/Open Tachometry
Overhaul CNE
Overhaul Motor connector
Control CNE Continuity/Motor Connector
Control Motor Windings
Control Tachometry Windings
Replace Card
Dado
Jun 04, 2014 | Ariston Technologies AW 129 NA Washer With...
WHAT IS F12 IN A WASHING MASHINE ARISTON AQUALTIS AQXXF 129 H?HOW CAN I FIX IT?
F12 SPECIFIC FOR LVB2000 INDESIT EVOLUTION / DIALOGIC.
F12: Lack of Display card-Main Card Communication
1. Check the effectiveness of contacts on CNC Connector Card
2. Overhaul 8-way connector on Display card
3. Check continuity of CNC-CN 8 way connector
4. Replace Main Card
5. Replace Display Card
Dado
Apr 24, 2014 | Ariston Technologies AWD 129 NA Washer/...
How to remove front of Ariston washing machine AVD 129 SK
take the top off,remove the soap bucket,take the screws off on the pc board/front cover. the top screws of the front pannel are usualy behind the display cover. the botom screws are behind the bottom plastic cover which you have to prey off with a screwdriver from the top side.
Mar 18, 2014 | Ariston Technologies Washing Machines
My washing machine ariston et 1400 it stop and aan f5 cod appear.
John C
Mar 22, 2011 | Washing Machines
I have an ariston amd 129 washer dryer. F-10 keeps coming up on diplay
Oct 14, 2009 | Ariston Technologies Washing Machines
Washing Machines Logo
583 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
