Question about Canon imageCLASS D320 Digital Copier
Getting LCD Error: Toner not set Insert Toner
Imageclass D320: Changed Toner, Cleaned contacts, even tried the paper tray fix I saw on another machine. No change
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
    Problem Solver:
  • 18 Answers
Sometimes what causes the problem is the black cartridge guide on the inside rear of the machine. It comes loose and so when you put your cartridge in it does not line up with the contacts properly. The parts cannot be ordered seperately. It comes with the whole rear assembly. The part # for it is HM1-0244
Posted on May 29, 2009
    President:
  • Canon Master
  • 1,447 Answers
Please cartridge is not install properly
  1. machanical problem
  2. cartridge assemling problem
Posted on Aug 17, 2009
  • Sazeed Computer
    Sazeed Computer Dec 01, 2009
    Dear,
    This machine some times calls ,Toner not set install toner .When your toner unite is not adjust drum lock by right side grounding or cartridge is not assemble properly.
Image distort when copying and horizontal lines
Getting caught? Loose paper shred inside feeder?
Mar 28, 2014 | Canon D320 imageCLASS Digital Copier
My printer MF4122 shows Toner is not set. Insert Toner. means what?
Believe it or not this error normally relates to the paper tray. Take all of the paper out of the tray and then reinsert the paper into the tray.
Hope this helps.
Sep 14, 2012 | Canon imageCLASS® MF4150 All-In-One Laser...
ALL COPIES BLANK. NOT LOW ON TONER. ALREADY REMOVED AND SHOOK. D320
probably the problem is in laser shuter or toner cartridge pin in toner holder. But when you try to copy, when paper goes to the drum, open the right cover and produce paper jam, now look at drum for image, if on drum isnt image its laser problem...
If the laser shuter is faulty, these means that when you close the right door, the nose on door doesn't lift the laser shuter and so the laser unit cant write on drum.
If the toner crg. pin is faulty, when you insert toner in holder inside the copier, on right side of toner holder is small circle with pin that contacts the toner and gives voltage. You can apply some wd40 to that circle, that goes in and out when you open or close door.
But, probably is laser shuter... to check him you need to dismantle the copier.
Hope that helps!
Jun 23, 2011 | Canon imageCLASS D320 Digital Copier
I am working with a canon imageclass d320. I believe there is a problem with the fuser and am wondering how i can gain access to the fuser? There is nothing in the manual about the fuser either.
from the left side of machine there are door, when You open them you will have access to fusing unit, but only to the paper exit section.
To dismantle the machine you need to strip all the plastics and much more...
Apr 11, 2011 | Canon imageCLASS D320 Digital Copier
Canon Image Class D320 does not copy entire page. New toner has been installed.
Has anyone changed the paper size in the paper tray to another size by accident? Have you tried the manual feed tray? If that copies the whole image then the problem is with the paper size input of the paper tray.
Apr 15, 2009 | Canon imageCLASS D320 Digital Copier
Printer will not print: Canon imageCLASS D320
The paper size selected in the menu system must match the paper size in the rec. (recording) paper tray. If you have 'letter' size paper in the tray and the menu system is set for 'A4' paper you will get this message. Either put A4 size paper in the tray, or change the paper size in the menu system to 'letter'.
Oct 15, 2008 | Canon imageCLASS D320 All-In-One Laser...
Canon Imageclass D320 supply rec. paper malfunction
My problem was that I was trying to print from a PDF file. I found out that the file was legal size and that the setting for the printer to "choose paper source by PDF size" was checked. I unchecked it so that it would print on letter size paper. Hope this helps
Jun 05, 2008 | Canon imageCLASS D320 Digital Copier
Toner
I had the same problem with this printer. And I think I got the problem solved by removing the all paper from the paper tray, and re-inserting the toner cartridge. I think it is the problem with incorrect error message from Canon's printer. It is problem of paper being fed into the printer mechanism slightly.
Nov 27, 2007 | Canon imageCLASS® MF4150 All-In-One Laser...
Toner not set insert toner message
The problem is with the paper tray not the toner, believe it or not. Take all of the paper out of the tray and then reinsert the paper into the tray. It should then work fine.
Nov 06, 2007 | Canon imageRUNNER 400S Copier
Canon imageCLASS D320 Digital Copier Logo
139 people viewed this question
old marine
old marine
