Question about Philips 60P8342 60" Rear Projection Television
I have a 60 inch Phillips 60P8342 and the picure is blurry.
Do i need a new pictre tube. If so what color? The is redish with blurry edges. Help!
  • Anonymous Mar 15, 2009
    Bright on the outer edges and red dominates the entire picture, did convergence, color and picture settings, no joy. Don't know if it's the red green and blue lamps or the board. This is a common problem but have been unable to find the fix
  • lilmia Mar 23, 2009
    i had the same problem with my tv for about a year and almost got
    rid of it but my friend found a mechanic that did not charge for estimate, he looked at the tv and right away said the oils in the color tubes needed to be replaced. i had the work done and now my tv looks like new.
    Mia
  • Philips Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directiI have a 60 inch Phillips 60P8342 and the picure i - 2c07611.pngnvergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
I have a 60 inch Phillips 60P8342 and the picure i - 578ba6c.jpgef="http://www.fixya.com/support/t1631691-red_aura_in_middle_55_phillips#" >Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 29, 2009
Hi, i had the same problem.
the technician i know changed or filtered he oils in the color tubes.
Posted on Mar 23, 2009
  • 3 Answers
I heard you drumbanger, but I like answer this just to help him. First I AM NOT EXPERT. Now that is out of the way. When i tinkering with my big screen i got for cheap. I found adjust to focus can be adjust. Just REMEMBER HIGH VOLTAGE in TV. I would take to professional. This will be last answer if fixya don't pay people like above. Thank you.
Posted on Feb 14, 2009
Philips 60PW9363 60-Inch Widescreen HDTV-Ready Projection TV discolored. possible crt fluid issue??
Thats sounds like the classic sign of CRT coolant needing to be replaced you can get the phillips CRT coolant kit from www.tvrepairworld.com and it comes with the coolant for all 3 CRTs and the instructions
Nov 08, 2012 | HP Philips 60Pw9363 60-Inch Widescreen...
TV intermitingly color goes redish sometimes turning tv off and then on will temporarily fix
the high voltage splitter and the horizotal transformer and that is only if all three tubes are blurry.if only one tube is blurry, more than likely the tube itself is bad.
Aug 23, 2008 | Televison & Video
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Phillips 60 in projection - colors yellowed
you have 2 problems one of youy tubes is low on fluid and the convergence is way off.
Sep 11, 2009 | Philips 60P8342 60" Rear Projection...
Blurry picture
With the back off and if you can get a small mirror above the blue and the green tube, look at the picture coming out of the tube. If it looks like you're looking through fog then you probably have contaminated coolant. Compare them to the red tube for reference because the red one is very seldom affected.
If contaminated, the fluid will have to be changed and the chamber cleaned out by someone that knows what they are doing.
Be careful reaching in there. Wear gloves to help protect your hands.
May 18, 2009 | Philips 60P8342 60" Rear Projection...
I have a phillips 60'' and has yellowish color around the edges
hi the problem the picture tube of ur tv has got repaired. pls rate me
Jan 18, 2009 | Philips 60PP9363 60" Rear Projection...
Philips 60P8342 picture blurry with orange tint
Your TV most likely has one of two possible problems.
  • Screen looks 3D
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Oct 30, 2008 | Philips 60P8342 60" Rear Projection...
Popping sound and picture goes out
Sounds like the flyback or the picture tube. Either items can cause this. If the pop comes from the rear right side its the flyback. If the sound comes from the lower front behind the speaker grille its the tube. Let me know what you discover as I have access to any of the parts you would need.
Mar 10, 2008 | Philips 60P8342 60" Rear Projection...
No Picture
you have sound, but there is no sound?? or do you mean picture?? try replacing the bulb!!
Dec 24, 2007 | Philips 60P8342 60" Rear Projection...
Philips 60P8342 60" Rear Projection Television Logo
296 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
