Question about HP 35s Scientific Calculator
HP35s extracting P to R anwsers and place in memory
I've been an HP 32Sii user for over 15 years a roof leekage took the caluclator to it's grave, replaced it with a HP 35s.
I use the polar to rectangular conversion daily, how do you extract the solutions from an polar to rectangular calculation and store the X, Y or the R, angle into memory?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
Given a complex number, ARG (yellow-shift i) will give you the angle in the current angular mode, while ABS (blue-shift +/-) will give you the magnitude.
To extract the real and imaginary components, you'll have to use the relationships
x = r cos(a) and y = r sin(a).
Posted on Nov 01, 2010
The HP 32SII calculator has a very common problem with the keyboard connections. There might be nothing else wrong with the calculator except the contacts.
Try pinching the calculator just below the middle of the screen above the [LN] and [Y^x] keys while pushing the [C] button to power it on.
If this worked, at least you know where the problem is. Fixing that problem temporarily, some users wrap a rubber band around the calculator at that point and put something under it to keep pressure on that spot.
The longer-term fix is harder and involves taking the calculator apart to replace a foam pad to keep pressure on the plastic keyboard contact strip against the printed circuit board contacts.
Somebody (not me) put together an Instructables page for the HP 17B calculator, which is built exactly the same as the 32SII.
HP 17b series calculator repair
Nov 30, 2015 | HP 32Sii Scientific Calculator
Hp 32sII enter degrees minutes seconds
According to the "HP 32SII RPN Scientific Calculator Owner's Manual" (at the link below), you just need to treat degrees, minutes, and seconds conversions as hours, minutes, and seconds. Use the left-shift and right-shift keys together with the 5 key to convert to decimal-fraction form (D.d format) and to minutes-seconds form (DD.MMSSss), respectively.
See pages 4-9 and 4-10.
hp-32sii-enter-degrees-minutes-seconds-5ti10bsvdnjq4loa1azfxjeu-1-0.jpg hp-32sii-enter-degrees-minutes-seconds-5ti10bsvdnjq4loa1azfxjeu-1-1.jpg
Apr 09, 2014 | HP 32sII Calculator
Printed manual for Hewlett Packard 35s scientific calculator
CalcPro sells the original HP35S User's manual for about 10 dollars. Here is the link.
Dec 31, 2011 | Office Equipment & Supplies
My HP35s keeps flashing MEMORY CLEAR. I removed the batteries and reset it with a paper clip. Nothing works.
I'm not sure if it is the only solution, but I had the same problem and I replaced the batteries. My HP35S works fine now.
Previously, however, there was no "battery" annuciator on the screen. This calculator went four years without a bettery change. My HP48GII, on the other hand won't go two months without a change. Go figure.
May 11, 2011 | HP 35s Scientific Calculator
I have a HP 32sII and the screen has gone fully on. All the displays are on at once. I replaced the batteries, that did not help. Any suggestions?
Hold down "C" key. Press and hold both top left and top right key along with "C" key. Release all three. Reset.
Dec 21, 2010 | HP 32sII Calculator
Have new batteries but unit will not come on
Adjust contrast : Hold down [C] key and press [+] to increase contrast or [-] to decrease it.
Diagnostic tests (from the Users manual)
1. Hold down [C] key and press [LN]; may have to repeat several times.
2. Press and hold down [C] key and press and hold down both the square root key AND the Sigma + key. When all keys are released, MEMORY CLEAR is displayed.
3. Remove batteries and lightly press a coin against both battery contacts in the calculator. Iy should say MEMORY CLEAR.
If these steps fail to restore calculator operation, it requires service.
Hope it helps.
Sep 29, 2009 | HP 32sII Calculator
HP 32 won't work
Hey Dave- take a look at the following link. I like to have the user actually look at the user guide instead of describing it. If this solves your problem PLEASE rate this as fixed. If this isn't exactly right or you need more help just add a comment and I'll be glad to help you further. Thanks.
Apr 30, 2008 | HP 32sII Calculator
HP 35s Scientific Calculator Logo
441 people viewed this question
Ben Johnson
