Question about Whirlpool RBS245PDS Electric Single Oven
Door wont shut and the light stays on
Brand new installed to day
  • icemantonker Mar 15, 2009
    I am doing a new install and after installing the door the lights stay on and the door doesn't appear to shut all the way at the top. Please help! The model is GBS307. Thanks.
    Novelist:
  • 117 Answers
Since this is a new install, check around the perimeter of the oven door and see if it is closing all the way flat against the surface. The hinge could have partially popped out and needs to be reset. Can you tell if the oven door is popped out at the top portion of the oven door or the lower portion of the door?
Waiting to hear from you,
Eric Campion
Posted on Feb 14, 2009
Arcoaire furnace ran out of propane and now wont ignite
Check along the gas supply line to the furnace and make sure there isn't a valve that is shut off. If you have a gas oven see if the ranges light and have gas. I'm assuming you've also turned on the gas supply at the furnace itself as well. Check that the furnace has electricity it won't be able to open the automatic valve let alone fire the igniter. My brand new furnace had a safety switch that went out 3 days after installation preventing it from lighting. You might contact Arcoaire about that. http://www.arcoaire.com/
Dec 23, 2013 | Ovens
Can't get the oven door back on. it was sitting
As you said they are spring loaded so be careful. You will need to pull on the hinge, which takes some muscle and you should see a small hole to put a pin or small screwdriver in to hold the hinge out. When this is in place on both the hinges you can put the door back on. This is the most common hinge style on Wpl or there may be tabs on the tops of the hinges to hold the hinge out. If the door still does not close all the way after getting the hinges all the way on you will need to take the door apart and replace the hinge/spring assy. Thanks for rating me after you read this.
Dec 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven door not staying fully open
phone bosch for clarification first. If this is not the case get the gas board out again
Oct 21, 2009 | Ovens
Oven door wont stay shut
U need to fit new door hinges, only solution as they are not adjustable.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Oct 13, 2008 | GE JKP15 Electric Single Oven
Jenn-Air built in oven Model W188-C, Serial # 210764UC approx 1987
Big oops, Millwood. Shut power to the unit immediately and wait a day or more for it to dry out. If it works then, fine. If not, you've got a learning experience installing a new pad.
Dec 07, 2007 | Jenn-Air JJW8230D Electric Double Oven
Whirlpool RBS245PDS Electric Single Oven Logo
179 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
John Tripp
John Tripp
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
