Question about IBM ThinkPad A31P Notebook
My display lcd suddenly fadded to a faint display .
Works fine when I connect an external monitor. This is the IBM A31 laptop 2653-MT1.
    Problem Solver:
  • 9 Answers
I really don't know if it will work, its been a long time since I had a PC, sorry if my possible solution sounds stupid
Check in Properties, in the section of battery or display, there's an option (i think) which fades the display when the battery is at a certain level.
Posted on Feb 14, 2009
When I turn on the power on my thinkpad the picture on the monitor is garbled and it's almost near impossible to get it ungarbled. It does it right when it starts up
connect an external monitor and check how is the display,if the display is fine on external monitor,then it would be your
LCD OR VIDEO CONNECTION OR CABLE NEED TO CHECK .
If you are getting the garbled picture on the external monitor also it could be
SHARED MEMORY AT FAULT( If the laptop uses shared video memory (part of the main memory is used for the video purposes), it's possible that you have a faulty RAM stick.)
OR
VIDEO CARD (if the video card is discrete replace take out that and check the video with integrated video card and if the video card is integrated then you have to replace the mother board)
Sep 17, 2010 | IBM ThinkPad A31 Notebook
IBM 2653 start afther 2sec the laptop is dead the green light of the battery is gone.
The battery is defective and needs to be replaced, contact your manufacturer (IBM) to find out if he can have it replaced.
Jul 30, 2010 | IBM ThinkPad A31 Notebook
My A31 is a refurb and a backup computer. It works well but I don't know what the blue keys do or mean. Also, how do I get the Thinkpad button and the mouse to work?
The blue keys are activates using the FN button.
Hole down the FN then tap the blue keys to activate that option
The one with two monitors switches your laptop to external displays etc.
the symbol on each key is a clue as to its function.
You can get the manual here
Mar 11, 2010 | IBM ThinkPad A31 Notebook
The display on my ibm thinkpad r40 is black after initial dim ibm screen. External monitor works fine though. This happened immediately after I used my ibm with a projector this morning? Fn F7 does not...
The problem youve discribed does seem to point to your back light has failed on the laptops lcd display, i dont know exactly how this would accure just using a projector though, go into bios again and try loading factory settings.
This problem could also be the inverter if you cant make out even a slight image on the screen.
let me know what happens. thanks
Jan 19, 2010 | IBM ThinkPad R40 2681
I have 2 ibm thinkpads t40, on one of the systems the lcd inverter and screen get no power but when i take the lcd and connect it to the 2nd ibm tkpad it works fine, What would be wrong with the one lap...
On the second Thinkpad laptop, that doesn't show a display with an LCD screen.
Plug a VGA monitor into the VGA port on the back of the laptop.
Hold the Fn key down, tap once on the F7 key (Toggle your display over to an external monitor)
Give the VGA monitor a few seconds to come on. (It's a VGA monitor)
Do you have a display on the external monitor? No? You May have a bad GPU then. (Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU )
Fix? Change out the motherboard. Possibly Ebay has one, dunno.
VGA monitor has a display? Then you may have a bad Inverter. The Inverter provides power for the LCD screen. Inverters go bad.
Are both Inverters the same? (Laptop to laptop)
BE SURE. The Inverter MUST match the LCD screen!
Check the numbers on both Inverters. If they are the same, switch the good one over to the 2nd laptop. See if you have display now.
No?
Then it's the GPU.
Service Manual for IBM Thinkpad T40,
http://tim.id.au/laptops/thinkpad/T40-T40p-T41-T41p-T42-T42p.pdf
Copy and paste the above link into your Address bar. Press the Enter key. (I don't post direct links that you just click on. I want the asker to be able to see where the link takes them, by looking at the link. I feel it helps make the asker more comfortable with my solution, knowing I have their best interest in mind.
Regards,
joecoolsvette)
(If this link doesn't work for you, come back, and let me know)
Nov 20, 2009 | IBM ThinkPad T40 2373 Notebook
IBM T43 laptop display
This is an example of an inverter going out slowly. Usually, they tend to just go out and you diagnosed correctly when you seen the faintness on the screen and tested with another monitor.
The Dell inverter will not fit, more than likely. They are all different sizes, lengths, etc.
I would recommend just replacing the screen of the Toshiba. You can get one for less that $50.00 on eBay and it will save you alot of hassle trying to swap out the inverter (my opinion).
Oct 04, 2009 | IBM ThinkPad T43 Notebook
HOW do I remove the keyboard on a Gateway Laptop Model T-6330U, I spilled juice on keypad and heard sizzling when I restarted, and monitor fadded out. An external monitor works fine, and computer boots up...
You could send the laptop in for repair but it could be quite pricey, it sounds like the LCD is toast. If your keypad still works using an external monitor then you won't have to replace that.
Sep 20, 2009 | Gateway T-6330U Notebook
Plugging into a different screen doesn't work
The Cold fusion lamp in your LCD and or the invertor board for the LCD could be bad that is the reason why a faint image . As for the external monitor you should enable it by the Fn+F5/F6/F7 key by pressing it twice at boot up before windows is fully loaded - this to ensure that the external monitor works with your laptop . If the resolution setting and frequency is not comaptible with external monitor you connect then you wont have display on your external monitor . Start windows in safe mode .
May 13, 2008 | IBM ThinkPad G40 2388 Notebook
Thinkpad a31 lcd problems
Well yes BUT if it is a problem with the LCD then you would need to replace try plugging an external monitor to see if the sizes are normal if they arent then it is definately a problem with the screen resolutions.??
Sep 02, 2007 | IBM ThinkPad A31 Notebook
Computers & Internet Logo
71 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
