Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
DRIVES NOT OPEN BY DOUBLE CLICK
I double click on my C , D ,E, F, G, drives, it says "Windows cannot find 'resycled\ntldr.com'. Make sure you typed the name correctly, then try again. To search for a file, click the Start button, and then click Search.".the same old message i used to get earlier. anyone can suggest a solution.
  • Bob
    Bob May 11, 2010
    Instead of double clicking the drive(s), right click and select "explore."
  • Peter Steiert
    Peter Steiert May 11, 2010
    Are you trying to get the drives to open their trays when you double-click on them? Or are you trying to see what files are in the drive?
  • 23 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The main reason for using this utility is when you suspect there may be a problem with a Windows XP system file.
Perhaps you get a dialog box appear informing you of a problem with a .dll file, or your program will just not load! It is therefore worth checking to see if there are any corrupt system files using scannow sfc.
To do these simply go to the Run box on the Start Menu and type in:
sfc /scannow
This command will immediately initiate the Windows File Protection service to scan all protected files and verify their integrity, replacing any files with which it finds a problem.
It may ask for your Windows XP CD so have it at hand.
Posted on Feb 15, 2009
I cannot double click and open drives. If i try to double click a drive its prompting for a "Open with" dialog, pls help..
Maybe you can try to read this links content
http://www.winhelponline.com/articles/223/1/Open-With-dialog-appears-when-double-clicking-on-a-mapped-network-drive-in-My-Computer.html
Goodluck hope it coincide with your problem for some solution.
Jul 12, 2009 | Microsoft Windows XP Professional for PC
Changing how to open drives
2 things...go into ur Control panel and in the MOUSE area change the way ur mouse clicks to run things..then save those settings.
OPen Real Player options or preferences. Look for an option to how it handles running things. then uncheck it. save those settings.
May 24, 2009 | Microsoft Windows XP Home Edition
your computer is infected with virus or spyware...
you should remove autorun.inf from all drive ..it is a system and hidden file ...
then remove the contain of recycler...
Feb 14, 2009 | Microsoft Windows Xp Home Edition Sp2...
Cannot access my hard disk from windows
Your windows system by default really has to be located on The C partition of the drive in order to self load.
Jan 30, 2009 | Toshiba Satellite P105-S6227 Notebook
Removal of boot.com virus from external hard drive and USB Stick
Silakan baca di >sini<
Desi Vibes
"boot.com" is a virus which attacks the hard drives & the hard drives could not be opened by double clicking. In hard drives after enabling viewing hidden file u can see some "autorun" file & a file named "boot.com" which cannot be removed just by deleting.
Here’s the REAL way to clean this off your system. You should do these steps after a fresh reboot in safe mode.
1) Navigate to the problem drive(s) via the Explore option.
2) Click on TOOLS -> FOLDER OPTIONS
3) Click the button which says ‘Show hidden files and folders.
4) UNCHECK the following boxes:
Hide extensions for known file types
Hide protected operrating system files
5) Find and delete the autorun.ini file and the resycled folder on the root directory of all affected drives.
6) Check “c:\windows\system32\dllcache” for boot.com file and delete it if present.
7) Check “c:\windows\prefetch” for boot.com file and delete if present.
8) Delete all files from c:\windows\temp
(Some files may not delete, that’s ok, they’re in use by the system and not virus files.)
9) Delete all files from c:\Documents and Settings\[USER PROFILE]\Local Settings\Temp
(Again, a couple files may not delete, don’t worry.)
10) Run Regedit
11) Make sure you are at the very first entry of the registry hive. (My Computer should be hilighted) then click EDIT -> FIND
12) Search for “boot.com”. If it finds an entry, delete it. Keep hitting F3 until you’ve deleted all instances of boot.com in the entire registry.
13) Scroll the left column back up to the top and hilight the My Computer again at the top of the registry hive.
14) Click Edit -> Find again and search for ‘resycled’ and repeat as in step 13, deleting the entries as it finds them.
15) Close registry editor and try opening the infected drives. They should work now.
Worked for me at least.
Dec 08, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
D,f drives "access is denied" on double click. but opens when rt clk and 'open'
What OS you're using?
Are you having Admin rights on the system you're trying to access the e&f drives?
If you have admin rights, then try to look at the security options of the drive (Right click on the drive and check properties). Make sure that your login name / your group is listed with full permissions.
Oct 26, 2008 | Microsoft Windows XP Home Edition
Comp drives not opening
this is because of autorun.inf file.
so run the following command-
go to run > type cmd >then type
cd\
attrib -r -s -h autorun.inf
del autorun.inf
d:
del autorun.inf
just execute the same command for all of ur physcal drives
and finally shut down ur computer
then open ur comp,now u can open ur drives by double click.
Mar 01, 2008 | Computers & Internet
Virus
Hi, there are some xp virus removal visit this site /www.Selecta.site.com
Feb 01, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
