Question about Maytag Neptune MAH5500B Front Load Washer
Replace front seal
Can it be done by a novice?
    President:
  • Maytag Master
  • 2,651 Answers
Can be done just need PATIENCE!.. youll need ot remove the door assembly, and the 2 screws oppisirethe heing willalow for the front "u" shaped panel to be reomved.. next remove the 4 screws from with in the dispenser area, and then there are perhaps (6) 5/16 screws holding the nextfront bulkead and maintop assy down.. after removing theese screrws youll be able to lift eh main top back wards( prop it with something, a few more screws will release te hlatch assembly.. from here you can probably install the new bellow, remove the spring and wire, and the work the new bellow around the tub lip. a third hand will come in handy, after working it around , youll needto reconnect the tension spring..HARDEST PART OF JOB>>> REQUIRES PATIENCE!!!!!. sometimes this goes on for me with out issue in 5 min, other times 25 min and im PISSED AT IT!!!!!!!,, wrap the wirer around bottom of lip and your going to hold one end of spring, needlenose vice grips work perfectly. then with another set of needle nose. stretchthe spring togethr to lock the wire around.. whern you finally get this reassemble the latch and drop the top back down replace all teh screws, and finally you need to retuck the bellow into the front bulkhead( tabbs line it up nicley.. good luck!!!
Posted on Feb 14, 2009
I am a novice. How do you replace the outer seal on the main large drive wheel, please
what maker of machine and model
there is a lot to undo to get it right
on a front loader I cant find a step by step
how to diy for a front seal renewal
watch this youtube if not clear for you ..its an LG front loader
ring a washing machine repairer
Washer Leaking Water LG Front Load Washer Door Boot Seal Replacement part...
Sep 22, 2016 | Washing Machines
Replace door seal
its quite easy on this machine,you can view a video on Espares.co.uk or remove front panel ,seven screws 4 top 3 bottom unclip wire on seal at front seal has two large clips to secure one outer and one inner, I find it best once the front panel is loose to unscrew the door interlock to fully remove cover once this is done you can see the workings and the exposed seal good luck.
Nov 02, 2013 | Hotpoint Aquarius WMA42 Front Load Washer
Replace crankseal on 1997 mpv
front crank seal or rear.
Front involves cambelt removal so you might think of changing that too
rear involves gearbox and flywheel removal so if it's a manual you may consider a clutch replacement. Neither job should be attempted by a novice and you really need a manual if your doing it yourself to ensure you don't mess up the timing etc etc
Apr 06, 2012 | 1991 Mazda MPV
How hard is it change front and rear oil seals?
By front and rear oil seals, I am assuming that you are refering to the CRANKSHAFT front and rear oil seals.
The front crankshaft oil seal is under all the components that must be removed to replace the timing belt.
The standard labor time to replace this seal is 4.0 hours for the 4 cylinder and 4.8 hours for the V-6.
The rear crankshaft oil seal requires removal of the transaxle to replace it.
The standard labor time required to do this is 7.3 hours
This is not a job for a novice unless you want to purchace a service manual and spend a lot of time reading the instructions before jumping into it.
Dec 01, 2010 | 1995 Honda Accord
I have a 2001 kia sportage. There is oil leaking into where the spark plugs are and shorting them out. Where could the leak be coming from?
You have a broken seal that is seated around the tube where SPARK PLUGS go thru. Fixing it is easy for a novice mechanic, just remove the VALVE COVER and u will see the SEAL around the tube, clean the area around the tube so that it will be oil free, replace all 4 seals, and put in a new one w/ a light coat of silicone sealant,clean also the valve cover gasket put some sealant. Put back the cover and ur done! Hope that makes ur day! taaah!
Nov 11, 2010 | 2001 Kia Sportage
To replace front axle shaft seal on 1995 f-350 4x4 is it required to open the front differential cover, or can it be done by working from the outside. By removing the brake caliper and hub assembly, will...
Most oil seals are just pressed in from the outside. I've removed oil seals by using a small Allen wrench to hook the seal and pull it out.
Aug 13, 2009 | 1995 Ford F350
2001 saab 95 SE, passenger side front and rear window problem... front windows motor is good, but off track, and back windows motor seems to be shot... how do I fix these? I am a novice female, please use...
Probably have to replace the plastic rollers. Have to remove the panel then not too bad. Probably don't want to do if first timer. Get someone to help that has done this.
Jul 11, 2009 | 2008 Saab 9-5
I need to change the door seal on a Hotpoint Aquarius WMA50
Basic diy tools should be ok. Take out lid screws behind plastic caps on edge(will be stars but small flat will do it).Lift front of lid and push back to remove.Remove kick plate and take out screws behind it.Remove band holding front end of seal and detach seal from rim of opening. Remove screws holding door lock and push lock through. Remove soap drawer & take out screws behind it.Carefully bring panel forward & slide to right to remove(Take care here with board &wiring)Remove screws holding front panel & lift front panel & remove it.Remove band from seal and your there.Note locating slot on seal. If possible get an extra pair of hands to hold panel with board to avoid damage.
Nov 16, 2008 | Hotpoint WMA50 Front Load Washer
Wf860 door seal
un-plug the washer take the lid off now open the door undue the clasp that goes around the rim of the door seal on the outside of the washer (look carefully) once done the door seal should push into the washer now if u look into the washer from the top at the front though u will see a another clasp going around the door seal on the inside of the washer this is a screw un-screw it once done then the door seal should pull out repeat backwards to replace it m8
Apr 27, 2008 | Hotpoint Ultima WF860 Front Load Washer
Whirlpool awm 759 frontload washmachine
be best to have repair man that done it it can be a long job and not finished 4 someone that never done it
Mar 02, 2008 | Whirlpool AWM8163 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
