Question about Canon PowerShot G9 Digital Camera
Canon G9 says "No Memory Card" even with a brand new memory card
Recently dumped images off of 2 PNY 2G cards and reinserted them to format. Camera is not recognizing the cards as being inserted at all. Have taken battery out and reinserted, even tried a brand new Sandisk memory card. Its still says, "No Memory Card."
SOURCE: no memory card error on canon powershot a400
Maybe you have to format the card before the camera recognizes it
Posted on Jan 13, 2008
  • 3 Answers
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
Posted on Jan 28, 2009
t00nz
  • 4738 Answers
SOURCE: I put a brand new SanDisk SDHC 4 GB memory card in
I also own an A620, but unfortunately I also learned the hard way that SDHC cards are not compatible with this camera. The A620 was designed before the newer SDHC format came out, thus although they look exactly the same, your camera will never work with these cards. Your camera uses standard SD cards (2GB or less). There are some standard 4GB SD cards, but they are very rare these days, and costly.
Posted on Aug 06, 2009
  • 571 Answers
SOURCE: When I inserted the new memory card (SanDisk Ultra
Some cameras cannot handle over 2GB memory cards. If it works fine with 2GB card - stick to that. If some other A620 you know operates with 4GB card, take yours to repairs.
Posted on Oct 24, 2009
t00nz
  • 4738 Answers
SOURCE: Loaded new memory card, and screen reads memory
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Posted on Dec 25, 2009
My Canon says Memory Card error even with a new Memory card..what to do?
Some older cameras will only accept certain size memory cards and types. Some faster new memory cards may not work with your canera - check your manual
May 21, 2014 | Canon PowerShot SX120 IS Digital Camera
I have a Canon PowerShot G9 camera. When i plug it into usb cord to dowload pictures, i get the error message "Communication Error" across the viewing screen of the camera.
The problem I believe is the sequence or flow of the connection.
With the camera turned off. Connect the USB cable to a computer USB port and the other end to the camera digital port turn the camera on by using the "Playback" button here is a diagram
Place diagram here
You know there is an easier and better way of transferring picture files and that's by using a memory card reader. A memory card reader plugs into the USB port of a computer and the camera memory card is inserted into the reader slot. The computer then looks at this as an external Hard Drive. Both methods will need you to format the memory card after the images have been downloaded to the computer. Formatting the memory card in the camera in which it is to be used will clean the card and making it compatible with the camera both the camera and memory card can then communicate without errors.
Jan 16, 2011 | Canon PowerShot G9 Digital Camera
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
Memory card error?
Hi, Check if other memory card is working on your camera. This is one way of checking if your memory card if still working or there is an issue wither the camera. Formatting Memory card **you should always format a new memory card or one from which you wish to erase all images and other data. ** Please note that formatting a memory card erases all data, including protected images and other file types. 1. (Set up) Menu [Format]
2. Select [OK] and press FUNC SET button.
Low Level format, recommended by cannon
Select the [Low Level Format] when you think that the recording/reading speed of a memory card has dropped. A low level format may require 2 to 3 minutes with some memory cards.
Apr 12, 2010 | Canon PowerShot A610 Digital Camera
Formatting memory card
First of all, yes, you will lose your pics if you format the card now. Get a card reader and download the pics to your computer. If you've used 1.7GB on a 2GB card, it may very well be full since the camera uses part of the card to write the files.
Feb 17, 2010 | Canon PowerShot G9 Digital Camera
Cana powershot g9 memory card kocked
Hi there
The card may be in write protect mode, take the card out and look around the edges for a small lock, like this >>>>>>528f45e.jpg
put the card back in the camera and you should be good to go.
Thanks for using Fixya!!!
Feb 01, 2009 | Canon PowerShot G9 Digital Camera
Canon G9 camera and G7 similar problem... checked out memory cards and they were reformatted. cards work fine in other digital carmeras I own. Can not get either camera to read a memory card
Usually this means there is a problem with the memory card part in the camera that reads the card. When this happens it will usually say either memory card error or card locked, even when the card is fine. Try emailing this site for help with this: www.camerasandparts.com All they help with are the Canon Powershot cameras and they're excellent for help with these models. Good luck with it. They'd be the place that could help with this.
Dec 31, 2008 | Canon PowerShot G9 Digital Camera
Can't format 2Gb Extreme III SD card in Canon G9 camera
bad card trash it and get new one changeing formats will cause errors most camera's use their own format if u cange it from one to the other so many time it burns card out
Dec 28, 2008 | SanDisk Memory Media
Memory card error
Dear jk_cibergirl:
It is likely that some type of corruption has happened to your memory card. Try reformatting the card in your camera to correct any problems. If that works then you should be fine to take more pictures from this point. If not, you may need to get another memory card. Check your memory card manufacturer for warranty information.
Just a few tips to help you avoid this problem in the future:
1. Even though your computer can format a memory card, do
not ever do so from your PC. Your computer lays down a
different type of file table than your camera, which can lead
to data corruption.
2. Always format the memory card in the camera it will be
used in after each downloading session AND even when
using a brand new card right out of the box for the first time.
3. Do not share cards among cameras - even if they use the
same type of card - even if they are the same camera model!
Consider your memory card to be camera specific.
4. Do not place your camera close to strong magnetic fields
(e.g on top of a television)
5. Lastly, even though your camera has a single image erase
button, do not do what some do and fill your card up and then
go into the playback mode and erase a few images just to
take a few more new images. This almost certainly will lead
to data corruption on your card. Download your images and
reformat the card to take additional shots.
If you need to recover any lost images from that memory card, you can give it a try by simply downloading free software from the internet (such as Zero Assumption software available at www.z-a-recovery.com), connecting your memory card to your computer via a card reader, and running the program on the card reader volume.
Hope this helps.
Sincerely,
HeavyDLB
May 28, 2008 | Canon PowerShot A520 Digital Camera
Did you try formating with the Camera? Before that, Try formating with Windows Disk manager, then format with the camera, It will solve the problem.
Nov 01, 2007 | SanDisk Memory Media
Canon PowerShot G9 Digital Camera Logo
29 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
