Question about Alpine Audio Players & Recorders
Blown output drivers
Does anyone know where to purchase output drivers for a Luxman LV 105 amp.
K405 and J115.  They have a 7 on them????
  • 1 more comment
  • gkilburn Feb 17, 2009
    Would it be possible to buy a set from of 2SK405 and 2SJ115 from you, and I can do the work?  It would save on shipping.
  • gkilburn Feb 22, 2009
    Any luck finding anything?
  • gkilburn Feb 28, 2009
    Thanks.  I'll try the fix.
    Genius:
  • 1,175 Answers
The transistors are 2SK405 and 2SJ115.
I fix Luxman if you dont mind sending to Vermont.
Cheers ( I hope that helps)
Posted on Feb 16, 2009
  • Scott Frye
    Scott Frye Feb 17, 2009
    From one of the DIY groups I use:
    For 33V rails use IRFP9140 for P channel, IRF240 for N channel (yes I know one is 100V the other 200).
    I'm currently trying to get a couple of each of the 2SK-2SJ ..Get back to me on friday + I'll let you know how I fared.
  • Scott Frye
    Scott Frye Feb 25, 2009
    I lost the bid on the original parts...( Grrrrrrrrr)
    but I hope the above DIY helps
Samson SX1200 - Protect light on. No blown output transistors.
Have you checked the power supply section? Also look out for any IC's in the amp stages. They can go causing that kind of fault.
Oct 11, 2014 | Samson SX1200 Amplifier
My Luxman d-90 cd player (manufactured in 1988) doesn't have digital out therefore I can't use my DAC. I am looking for a schematic for this product better yet if there is someone out there who already did...
choondo
In regards to getting a digital output off your CD player there really is not any point in doing this. With standard CD quality you are not going to get any audio benefit from upconverting to a digital format with the player.
You would have to purchase a $50 to $100 Analog to Digital converter and then you are still limited by the audio output of the Luxman d-90 cd player.
So I would recommend that you just use your analog outputs. If you are wanting digital output for your CD player you would be better off buying a new CD Player that has digital output.
Also note unless you are wantling to play digital CDs that are in a DTS for Dolby format there is no need for digital output on a CD player.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Oct 08, 2010 | Audio Players & Recorders
LUXMAN L-85V AMPLIFIER LOW VOLUME
Make sure that you have the turntable connected to the PHONO input. If there is none (I don't know your specific model), then you will need a phono pre-amp. Connect the output of the pre-amp to tape-in or Aux in and the unit should work as expected. The alternative is that you may have the tape monitor turned on. Check that as well.
This unit is old enough to have pre-out and amp-in connectors on the back. Make sure that those are connected to each other. Use standard RCA cables.
If none of those resolve the problem, there is an internal problem that will need a bench to resolve.
Dan
Oct 26, 2009 | Audio Players & Recorders
No sound out of left speaker
did the left channel work when u switched speakers, if so then the left speaker or wiring is a fault.if not then the output circuits on the amp are blown or the fuse is blown some amps have internal fuses in the output to protect the output transistors. unplug the power cord and take the cover off, look to see if u can find any fuses and check these for continuity u can hold these up to the light and u should see a fine filiment in one piece and not broken. these fuses sometimes blow just from age and use at high volume like a regular light bulb.If the fuse is blown replace with the same value else the output transistors will need to be replaced most likley along with the drivers.
May 19, 2009 | Sony STR-DE135 Receiver
Luxman Digit synthesized stereo Receiver AM/FM & Phono not work'g
The problem is still there, but I am expecting HELP fir free.
May 11, 2009 | Car Audio & Video
Luxman LV-111 Home audio amp chatters at power-up.
Hi....
Check on the speaker connections. Make sure theyre firm at both ends. Do you have another set of speakers you can try on it? If so,try that too.
The chatter is the speaker protection relay.
Let me know...Thanks
Mar 31, 2009 | Audio Players & Recorders
Power to Amp but no lights and does not switch on
(1)When the unit is switched on the relay clicks in,but no sign of life, and then five seconds later the second relay clicks on/off don't know which. This symptom is DC outputted to speaker terminals. Check any DC at power amp stage output.(2)Must have blown up.
Positive. If Caps blew, your amp shutted itself down within 5 seconds due to + & - power supply creating an unbalanced +B & - B voltage not allowing your amp to turn on.
Oct 05, 2017 | Optimus STA-3500 Receiver
JVC KDSH55 REAR SPEAKER OUTPUTS BLOWN?
well it sounds like u may have blown the channel or your amp was powering your rear speakers
Dec 20, 2008 | JVC KD-SH55 CD Player
Luxman LV 105 Amplifier gone dumb
Hi: If the Amp has an audio output transformer, check for bad solder connections to the pc board, This are the wires from the transformer to the PC board. Another place to look is the earphone connection plug. If the jack has a bent contact inside of it, you will have all sound cut off. Good Luck.
Al
Mar 09, 2008 | Carver PM950 Amplifier
Whats wrong
If the outputs were blown, the 20 pin HIP4080 probably needs to be replaced.
Nov 02, 2007 | Earthquake Sound PH-D2 Car Audio Amplifier
303 people viewed this question
Top Alpine Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
SHARCNET-USA
SHARCNET-USA
Are you an Alpine Audio Player and Recorder Expert? Answer questions, earn points and help others
