Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t stopping in mid cycle with F abd DL errors
I am in the middle of a wash cycle and the washer stopped. It starts beeping F and DL errors. I have tried to reset cycle and power down the washer, but it will not reset the errors and still beeps when I try to restart it.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
See Phoebe 112 latest solution! This is a common problem with these washers. For a quick fix you can usually get it going again by unplugging it for 30 mins. so the computer will reset. You will hear a slight buzzing noise when it resets. If it keeps doing it, go to the comment for Feb. 14, 2009 and try that if you are handy. Unplug the machine before doing any of this as with any machine that is electric or you will probably get the shock of your life.
Posted on Feb 14, 2009
.cIn the middle of a
'F' + 'dl' stands for Fault Door Lock. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. It will not reset as a service engineer's attention is required I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Apr 15, 2011 | Kenmore Elite 45986 Front Load Washer
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Our Kenmore Elite HE3 Model prefix is 110 stops during the rince and spin cycle,beeps, and desplays F dL or F 11. The door light is not on, but the door is locked. We were able to start and complete the...
wash another load and see what happens the f-dl code means door lock problem and f-11 means communication error between top control board and the bottom control board if you can wash a load completly everything will be ok but you can't let me know and we see where to go from there
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4T won't stop on the Spin Cycle. Stays
Replaced the relays with the 16Amp rated ones from Digitel.
Aug 15, 2009 | Kenmore Elite 45986 Front Load Washer
Washer stops with F11 code; door won't open
Serial Communication Error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
May 05, 2009 | Washing Machines
Sears kenmore elite he4t
Shaking is caused by poor distribution of clothes causing an imbalance. Try the machine empty. If it works well, be aware that you'll have to redistribute your load to stop the shakes.
Dec 31, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Sedona Elite 3.8 Cubic Foot HE4t Washer (Front-Loading) 45089
open lower front with a starshaped bit(screwdriver) three small screws, to get to white plastic cleanout (easy to turn by hand)may have someting stuck in it. about a gallon of water is there so have two big towels ready to soak it up.
Dec 28, 2007 | Kenmore Elite 45986 Front Load Washer
Washer won't start; has alternating "dl" and "f" errors....can't reset
This is a Door Lock Error. The service manual lists the following causes: Door Lock Mechanism is broken or removed from door. Door Switch Unit Lock Failure-Unplug washer and check door switch, wiring connections, and the connection to the CCU (Central Control Unit (You have to remove the lid of the washer for this). To get at the switch, you have to remove the lower front panel. These are torx, I believe 3 screws. By turning yourself on your head, you can visually inspect the lock, and manually lock/unlock to check for bind (pulling/pushing a black plastic handle about two inches long with a teardrop shaped handle on the end.
Oct 28, 2006 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
627 people viewed this question
Sal De
 Brian Main
Brian Main
