Question about IBM ThinkPad T40 2373 Notebook
Wehn i put in the ac adepter without the battery it works and whe
Wehn i put in the ac adepter without the battery it works and when the battery is attached and the laptop is off it also charge the battery but when the battery is there in the laptop the ac adepter dosent work or it dosent gose to ac power but it keeps on working with the battery power please tell me what to do’
Please help me
karan mistry
  • Raymond Danner
    Raymond Danner May 11, 2010
    This just sounds plain weird. For one, laptops (Hey, I'm using a HP Pavilion DV6408nr myself to type this) typically do run off battery. However, if the icon in the upper right of the system tray (for Vista) shows a plug with a battery to the right of it, it means you're on AC. if you see just the battery, you're on battery.
    Which icon are you seeing?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 70 Answers
Here you may get your answer.
Posted on Feb 05, 2010
Can I use a 19V, 4.74A ac adapter for my acer aspire 5602WLMi, for which its battery is 10.8 V 4000mAhr.?
Before you plug the adapter pls check the voltage of the laptop that it accepts the one that u mentioned is not the voltage that the laptop takes,their is a sticker behind the laptop back which tells you the charger adepter power that the laptop takes i am 100% sure Enjoy!!!!!!!!!!!
Dec 23, 2013 | Acer Aspire 5602WLMi AC Adapter
Medion MD 98200 My laptop will not turn on after my son removed the battery pack accidentally
Turn on the laptop without the battery, using only the AC adapter. If doesn't work remove the AC Adapter and battery. Hold down the power button for 30-45 seconds then plugged in the AC Adapter and put battery back in then [on]
Apr 11, 2013 | Computers & Internet
Hello , i have acer aspire 3680 laptop , i have face same problem. when i am connecting ac adepter then my laptop will hang and none of the procedure will work.one another problem is when start my laptop...
Hi
Try to remove the battery and power up your laptop, if the problem is still the same try to press F6 or F8 and start into Last known good configuration. and disable the automatic restart. But back up your data and reformat your laptop. it might have viruses on it that triggering the restart.
Good luck
Jul 11, 2011 | Computers & Internet
My Yamaha keyboard YPT-210 just stopped working one day. It won't turn on with either the AC/DC adapter nor with six fresh AA batteries. Any ideas?
This is likely a problem near the power input jack or the regulator. It requires opening the unit. If you are not electronically adept, best to take it to a shop for repair.
Dec 30, 2010 | Yamaha Music
The turnsignal usually don't work. Wehn they do work it is usually when you are giving it throttle they will not work at all with eng. not running even with hot battery.
check the battery voltage , should be over 12v with the engine stopped and 13-14v with the engine running, or it may just need a new flasher can, make sure the bulbs are all coming on including the dash and they are the correct wattage for the bike
Apr 25, 2010 | Harley Davidson FLHTCUI Electra Glide...
The suction isn't working. It is there, but wehn
Check hose to see if it is clogged. ALSO MAKE SURE ALL THE COMPARTMENTS ARE PUT BACK CORRECTLY.If the water resevoir isn't sitting correctly , you will lose suction. Check that hoses are corect as well.
Dec 15, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
End of power cord has 20vdc. Whe it is plugged in the AC led does not light on the laptop. A65-S1066. How dead is it?
try checking the out put voltage from adaptor, if the adaptor has screws open it and check the fuse, remove batteries and check
Jul 08, 2009 | Toshiba Satellite A65-S1066 Notebook
My T42 suddenly wont recharge the battery or wrk off mainsadapter
If the Laptop wont work off the power adepter, it also will not charge. The adepter could be bad (even if showing a power light) or the connector on the laptop could be broken. The best test is to take the battery out, attach the power adepter and try to start the computer if it starts, your battery is at fault. If nothing, suspect eh charger first. Be sure the pin on the Laptop power connector isn't bent or broken.
Jan 04, 2009 | IBM ThinkPad T42 Notebook
ITouch with road runner email
can not vonect to email with itouch tried resetting did not work
May 06, 2008 | Apple iPod touch
AC Power Adepter for Benq DC 3400
Benq ? ? ?
such a brand that no spares are available in market.
so, say no to Benq.
Sep 13, 2007 | BenQ DC3400 Digital Camera
IBM ThinkPad T40 2373 Notebook Logo
98 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
