Question about HP Compaq nc6000 Notebook
Fix fan compaq nc6000
I'm trying to take the bottom cover off to repair the fan - it sounds like a screw is loose in it when I turn on the laptop. However, I'm having problems getting the bottom cover off. Any suggestion?
  • HP Master
  • 4,338 Answers
Here is the service manual,see page 5-32 (Page 118 in the reader):
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00725201/c00725201.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Feb 14, 2009
What the solution of laptop hp compaq nc6000 when turn on won't start up
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/original-hp-compaq-nc6000-ac-adapter-65w-cord.html
http://www.chargerbuy.com/replacement-hp-compaq-nc6000-ac-adapter-18-5v-3-5a.html
Nov 13, 2012 | HP Compaq nc6000 Notebook
My Hp compaq nc6000 with Windows XP used to have a good wireless connection, but now it has a very low signal and I cannot connect to the internet. It does connect to the internet with an ethernet cable. I...
Make sure that the antenna on your wireless router is not damaged or pointed the wrong way (down or the the side). Also if you look under the cover under your laptop make sure that the wireless antenna is properly plugged in to your laptop's radio. I have seen a few loose ones here and there.
Jul 28, 2010 | HP Compaq nc6000 Notebook
I have a Compaq nc6000 that would not boot up. I
Sounds like your display panel is bad or it's another symptom of a mother board flex problem at the Maxim chip
May 22, 2010 | HP Compaq nc6000 Notebook
Starting problem
Starting problem Answer hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan... (More) hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan starting up with one glowing orange light next to a lightning bolt like symbol. IWhen I turn ON my laptop first time HP Compaq nc6000, sometimes the orange LED will just light up and nothing happens, sometimes when I get lucky I will be able to goto Windows. when start work properly.
Jan 31, 2010 | HP Compaq nc6000 Notebook
Windows black
my hpcompac nc6000 doesnot pick up the fan rolls but no display on the sreen
Oct 08, 2009 | HP Compaq nc6000 Notebook
NC6000 starts to boot but then turns off, no lights or screen. I can hear the fan when the power is turned on?
On ac adapter and battery power,could be several things sounds like bad caps on the main board. Less expensive to replace the motherboard.
try here
www.ebay.com
Oct 07, 2009 | HP Compaq nc6000 Notebook
Compaq nc6000 wiring schematics
there are no schematics availlable However the fan plug wiring when the laptop is facing you is: left to right...red.white,black,yellow
Aug 24, 2009 | HP Compaq nc6000 Notebook
I would like to find the location of my CMOS battery on my laptop HP Compaq nc6000 to replace the battery.
Try taking off the Keyboard, it is probably under there. There might be some screws on the bottom or snaps on the top.
Jun 12, 2009 | HP Compaq nc6000 Notebook
My keyboard does not work on my NC6000 , I havee googled the error and found it to be a common error corrected by taking the laptop apart and tightening the screw next to the fan for some reason this helps...
This might sound obvious, but try removing the keyboard, and check to see if the ribon cable is connected. I just purchased a used nc6000, and had no response from my keyboard. 2 screws on the back, and 4 little plasctic tabs between the f keys at the top. The tabs just slide down. Hope this helps.
Dec 19, 2008 | HP Compaq nc6000 Notebook
Battery Light blinking and Laptop (Compa Nc 6000)won't turn on
MikeB2554,
Unfortunately you have a system board issue. I've have seen this problem many times while I was repairing this unit. Sorry for giving you the bad news.
Nov 26, 2007 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
1,177 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
