2001 Ford Expedition Logo
Posted on Feb 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
REAR TURN INDICATOR WILL QUIT WORKING
I HAVE A FORD 2000 FORD EXPEDITION. THIS WEEK THE PASSENGER REAR TURN LIGHT QUIT WORKING. I CHANGED BULBS (AND YES ITS IS A GOOD BULB ALL 3 I TRIED WITH) AND STILL DID NOT GET THE TURN INDICATOR TO WORK. THE LOCAL PART STORE SUGGESTED TO CHANGE THE RELAY, BUT I TINK THIS IS WRONG BECAUSE BOTH FRONT TURN LIGHTS AND DRIVER REAR TURN INDICATORS WORK. THAT TELLS ME THE RELAY IS OK. AM I RIGHT? WHAT SHOULD I CHECK TO FIX THE PROBLEM
  • Anonymous Feb 22, 2009
    The same thing happened to me. I took it to a local repair shop and they replaced the entire wiring harness for the turn signal. It was very expensive. $500+
Anonymous
Level 3:
Brigadier General:
  • Master 3,533 Answers
  • Posted on Feb 14, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
3533
Questions
Helped
1419741
Points
10516
If you have done all of this check out the socket with a 12- volt tested and the wire behind the socket to see if you have power coming to it or a loose wire or a broken wire.
1helpful
6answers
1999 Ford Ranger. Front passenger side marker light does not turn on, but works as a blinker. The bulbs are good and are correct (3157). Also, the blinker blinks fast. Is this the relay even though the...
There should two separate bulbs for marker and blinker. It sounds like a bulb is burnt out, bad ground, melted socket or a wiring anomaly. Are you certain it's supposed to have 57 series dual element bulbs for blinker and markers?
Turn signal indicators do not work on my 1999 Ford Expedition. Emergency light works fine
I dont mean to sound condescending, but first check fuses... if theyre fine check bulbs... then flasher relays... if all checks fine you have a wiring problem and need to do a complete trace.
1helpful
Tail light is not lighting up in my 2000 ford expedition
brake and turn are the same filament in the bulb. Try a new bulb. if that doesn't work your going to chase a short/ground on that wire back to the switch. get a wiring diagram to help.
3helpful
My 199 Ford Expedition-Left turn signal and brake light in rear does not work. I had the buld changed last Sat. And it was working for almost a week...But now I was told by a friend that is not working...
It is very common for the light bulb socket to become minorly burned. You need to replace the socket. They are less than 10$. Hope this helps. TJ
2answers
2000 Expedition: what is a multifunctional switch on a 2000 ford ex...
This is usually the turn signal lever which also has other controls built into it.
1helpful
2answers
How to replace a rear turn light on a 2000 ford expedition?
how do i change a front turn signal on a 2000 expedition?
2000 Ford Expedition-Left turn signal and brake light in rear does not work, and left front flasher works but flashes quickly. The front and rear right side of turn signal and brake works perfectly. I...
You may have some wiring 'grounding' problems in the areas of concern. Remove each connection, and clean any rust. Place a light film of grease and a fresh star washer next to ground point, then the wire connector and other washers. Tighten firmly. Check the lamp sockets for any corrosion and replace same if found. The front lamp flashes rapidly because the rear light not working causes the flasher unit to switch faster.
1helpful
2006 Ford Ranger. Rear passenger side tail light
Bad earth connection.Clean or replce wire.
1helpful
Left rear turn signal quit on 2000 ford ranger.
Check correct wattage globe is installed in both front and rear indicator lights;
check if any other side/repeat indicator lights have failed.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
