Question about Sony CDX-F7005X CD Player
Help i need a wire diagram for this radio system
  • 10,594 Answers
If you are looking for wiring diagram of CDX-F7005X..
Click Sony Support to download required wiring diagram.
If Sony car stereo model is different, let me know to help you out.
Posted on Feb 14, 2009
I have an Eclipse dvd/cd/avinavi UCNV884RE system in my car, I disconnect the battery and now need to re programed the system to have it working again. I don't have the required software. Is there
For radio related problem,check the radio help links .Click the link be;low to go through its procedure:-----How to reset Radio code after car battery is died?
Can car radio code block Passkey anti theft system ?
How to wire new car Radio?
Radio Stereo Wiring Diagram?
How to remove radio on Car models?
Where is Radio Fuse located?
-----------After Market Stereo wiring?
car radio doesn't allow to switch to the XM Band to get the radio ID?
No power to radio Scion Xb?
Radio has power but no sound?
Radio goes ON and OFF while driving?
Town Car Radio stereo wiring?
Radio wiring diagram for Car?
How to remove cd player from dash?
This will help.
Feb 27, 2012 | Cars & Trucks
I need Only color coding for wiring diagram for cdx-gt550
If you are planning to install your radio, I recommend you purchase a wiring harness specific for your vehicle. All aftermarket radios are standardized in wiring colors. The harness will have the diagram to hook your radio to the harness. The problem with hardwiring a radio is the wiring colors don't match, and hooking it up wrong could fry your entire electrical system. You can find a harness at Hope this helps.
Aug 23, 2011 | Car Audio & Video
I need the wiring diagram for this sony car radio. trying to install it on a different vehicle thx
You don't need the wiring diagram, you need a wiring harness. They are only a few bucks and will save you a ton of time and the risk of frying your entire electrical system. The wiring harness will come with instructions. All radio wires are standardized. All you will need to do is crimp the appropriate colored wire to the matching wire on the harness. Then plug the harness into the vehicle. Hope this helps.
Aug 22, 2011 | Car Audio & Video
Need diagram on wiring harness for 2002 ford f150 showing ground wires and wiring for starter/celanoid can you help?
If you need it for the truck car radio then some of these sites will help you. And from what i understand this is the wiring: Car Radio Battery Constant 12v+ Wire: Light Green/Pink
Car Radio Accessory Switched 12v+ Wire: Black/Violet
Car Radio ground wire: Black/Green
Car Radio Illumination Wire: Light Blue/Red
car stereo Antenna Trigger: Blue
Left Front Speaker Positive Wire (+): Gray/Light Blue
Left Front Speaker Negative Wire (-): Tan/Yellow
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Orange/Light Green
Rear Speaker Negative Wire (-): Light Blue/White
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
I put a lot of work into this answer so i hope it helps. If it doesnt then contact me and i will get it right for you but this should be the correct diagram.
Jun 29, 2011 | Ford F-150 Cars & Trucks
Need radio wiring diagram for 2001 mitsubishi eclipse
CHeck HERE the 2001 diagram.
Hope helps (remember rated this).
Jul 05, 2010 | 2001 Mitsubishi Eclipse Spyder
2005 Neon SXT Stereo Wiring Diagram
2005 Dodge Neon Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Jun 19, 2009 | 2005 Dodge Neon
Wiring diagram for 2001 subaru legacy
Hello, this diagram is not for the Mcintosh system. If you need the Mcintosh system just let me know. I hope this info helps...(subytech1)...
Jun 04, 2009 | 2001 Subaru Legacy
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: Yellow/Red
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Yellow/Green
Left Front Speaker Wire (+): Green/Black
Left Front Speaker Wire (-): Light Green
Right Front Speaker Wire (+): Green/Yellow
Right Front Speaker Wire (-): Gray/Red
Left Rear Speaker Wire (+): Blue/White
Left Rear Speaker Wire (-): Blue/Black
Right Rear Speaker Wire (+): Pink
Right Rear Speaker Wire (-): Blue/Yellow
pls rate
Apr 04, 2009 | 2003 Honda Accord
Identification of original wiring to car radio/stereo
no wiring diagram needed go cut a plug from a junk yard and wire it into the cut wires then buy the adapter kit for you car and wire that to the car plug and the radio plug.
Mar 19, 2009 | 1986 Honda Civic
Sony CDX-F7005X CD Player Logo
431 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
