Question about Xerox DocuColor 12 Color Copier
Offset catch tray failure docucolor 2045
How come I get an offset catch tray failure for my docucolor 2045. The tray looks fine. I removed it so I can move the machine and when I put it back, I got this error.
  • howsimple Feb 23, 2009
    The tray makes a clicking noise. Sometimes the copier reads it fine and sometimes I get a offset catch tray failure. The wires look good. If there is a fault with the tray, what is the fault so I can check. Thank you.
  • 62 Answers
There must be a fault with the tray or wiring. There is nothing else that can cause this fault
Posted on Feb 20, 2009
  • oooimstuck Feb 23, 2009
    either with the motor oe gears in the tray. I would just fit a new tray, i dont think the parts are spared
How to clear code f901 toshiba 456
CDF0 Offset tray related
service call
Initialization error of the offset tray: The home position of
the separator cannot be detected when the power is
turned ON.
[CDF0] Initialize error of the offset tray (e-STUDIO205L/255/305)
(1) Check if each connector between the OCT motor and OCT board (CN261) is disconnected.
(2) Check if each connector between the OCT board (CN261) and LGC board (CN302) is
disconnected.
(3) Check if each connector pin is removed or the harness is broken.
(4) Check if any conductor pattern on the OCT board and LGC board is short circuited or open
circuited.
(5) Replace the OCT motor.
(6) Replace the OCT board.
(7) Replace the LGC board.
Dec 16, 2016 | Toshiba E-Studio 456 Copier
Xerox docucolor 2045
Try cleaning the paper dust off the pickup roller.
Nov 09, 2017 | Xerox DocuColor 12 Color Copier
Docucolor 252 facultad code 047-210 hoy do you Fix this?
may be offset catch tray. Just unplug the cable try again.
Feb 12, 2014 | Xerox DocuColor 242-252-260 PS
How to reset cdfo error toshiba estudio 355se
service call
turned ON.
disconnected.
circuited.
Oct 31, 2013 | Toshiba e-Studio 350 Copier
Fault code 047-211
There is a loose connection on the finisher. The fault code does not appear if the copy/print is delivered to the middle tray I think.
The code means that the "offset catch tray home sensor did not turn on in specified time". You may manually move the offset mechanism and see if it moves smoothly.
Sep 03, 2010 | Xerox CopyCentre C128 Black and White...
TURNS ON BUT KEEPS SAYING CLOSE OFFSET COVER
There is an exit sensor with a black actuator attached. I suspect the actuator has fallen off. If you can't clear that you should be able to remove the offset catch tray assembly and just let the paper feed into the center output tray.
Feb 09, 2010 | Xerox WorkCentre Pro 416 All-In-One Laser...
Where is the offset tray in a AR-M45on+ model copier? Secretary wants to staple, but it says clear off-set tray first.
This copier has two possible offset trays, depending on which type of finisher you have. If you have a finisher on the left side of the copier (called ARFN7) then the offset tray is the one and only top tray. If you have a finisher mounted on the right side of the copier (ARFN6), the offset tray is the bottom(lower) tray. It is possible that the sensor that detects the paper present in the tray is malfunctioning. Have a close look to see that there are no sensor actuators/flags out of place and that they are moving back and forwards freely. They will look like little black plastic fingers.
Jan 26, 2010 | Sharp Office Equipment & Supplies
Collate copies
The control to collate printing is in the driver. If your machine is equipped with an output tray that will offset sort the sets then they will be staggered otherwise they will be in one stack.
This machine does not collate while copying. Dah...shame on Xerox!
Jan 06, 2010 | Xerox DocuColor 12 Printer
Copy off set
What tray are you making copies out of? Does it happen ( the off setting) from every tray and the bypass tray ( if you have one)? If the copies are offset from only one tray, check the paper guide alignment for the tray ( paper side and end guides in the tray). Check to make sure that the machine see the proper paper size. If you are having the offset problem from all the trays then you are looking at a registration problem and woould need to replace the reg> clutch/ motor.
Jan 06, 2009 | Office Equipment & Supplies
Xerox DocuColor 12 Color Copier Logo
383 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
