Question about Kicker ZX400.1 Car Audio Amplifier
Speakers cut off when bass goes up...
I have a 1995 chevy S-10 pickup, with a SONY XPlode cd player, two 1100w 10" sony XPlode woofers hooked up to one l000w sony XPlode amplifier, It was working wonderful for more than 3 months til today. When I turn it on at a low volume it works fine, but when I pump the volume up to more than 20 on the radio, the woofers cut off with any kind of bass, the amplifier protection light (the little green light) doesn't turn red. When I turn it down below 20 again, the sound comes back uninterupted. Turned the radio off and when I turn it on the same problem happens again and again. I already checked the two 30 fuses from the amplifier and the one that goes to the battery (they're fine). The remote turn on wire is fine, as well as the power, ground, and RCA cables. I would appreciate your help. Thank you. the protection/power light on my kicker zx400 amp is red instead of green thus making my sub not work . . . why is this?
You may be running 2 low of ohm load
Posted on Feb 14, 2009
My new rear car speakers wont fit on the wiring harness in my truck.... Can i buy a certain adapter for that
your going to have to cut the wires and use the red connectors that you crimp (squeeze ) shut on each end. before you crimp them just twist them together and turn the radio on listen and see which way you hook them up has a deeper bass. cause if you hook thethe neg to the pos it wont sound very deep and hind of distorted
Jan 27, 2013 | 1999 Chevrolet Blazer
Sony XPlode Amp XM-2150GSX, whats setoff sensor mean? Amp keeps cutting out!
you have a short or your over heating. or more lkely bad ground or you bridged your subs and you should not have that what will give you those erros. OH most common tho is the remote cable from the cd player is loose or the rca cables are loose.
Mar 17, 2011 | Sony Car Audio & Video
I hooked up 1 10" type r to my 600w sony xplode
How many ohms is the speaker? You have the amp bridged going into the sub? You have the negative of one side hooked up to the negative and the positive on the other side hooked up to the positive?
It says that it is bridgable at 4 ohms. What about the input? Set your stereo about half way up. Then turn your amps gain up slowly until it is where you want to listen to it normally. Not to loud. Then when you turn it up it isn't too much.
But it sounds like you have way too much power for one speaker. Especially a ten. It takes two tens to equal one 12.
Dec 17, 2010 | Sony Car Audio & Video
Have mex bt2600 sony xplode car cd player ::: also have sony xplode amp model no.xm 754sx problem is i want to hook up a subwoofer and the amp to the head unit (also currently have 2 sony xplode 3ways...
If the Sony front end unit (stereo) has RCA jacks (Left and Right) in the back it's an input to the Xplode amp. If that's right then the Subwoofer putputs should plug or wire into the Xplode amp. I haven't hooked these up for some time but try a search on Youtube with the units you describe I'm more than 90% sure that there are videos there.
Nov 19, 2017 | Sony MEX-BT2600 Car CD/ MP3 Player
Sony xplode cd player sub problems
Switch your blue wires around.
You have put the remote antenna wire to the remote turn on of the amplifier. The radio cuts off the power to the "power antenna" when you switch to a different mode... so your amplifier is now losing the turn on signal it requires to stay on.
Simple 2 minute fix.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 19, 2009 | Sony XPlod CD Player w/MP3 Playback...
No sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
Feb 16, 2009 | Sony CDX-CA700X CD Player
I can't get bass thru the spkrs
So when you aren't using the sub woofer there's not enough bass, so you need more out of the other speakers. Chances are the front speakers are set to "small" in the receivers menu, change it to "large"if your front speakers have a 6 inch woofer or larger. Note: If you leave the sub on, the input signal to it will be greatly reduced when the speakers are set to "large". Hope this helps.
Feb 12, 2009 | Sony Audio Players & Recorders
sounds like you hava a load problem.if your'e running your woofers at 1ohm,make shure your amp is 1ohm stable.....
Jul 03, 2008 | Car Audio & Video
it might be that your wires from your amp to your subs are too thin. since they were relatively new the first three months, they were probably undamaged, but after pushing them too much, they probably have broken wires, and can't get enough power to the subs when turned up, i suggest getting thicker wires before investing in a capacitor, it could save you money.
Mar 21, 2007 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Open Questions:
See all Kicker ZX400.1 Car Audio Amplifier Questions
Car Audio & Video Logo
503 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
