Question about RCA F32444 32" TV
RCA TV Model F32444 Will not power on
When I turn the power on it makes a noise like it is going to turn on however it never does. I was wondering if you had any solut
ions Thanks
  • 230 Answers
The noise you are hearing is probably the degauss (it demagnetises the screen every startup). The most likely problem is the power supply. Do a replacement of all the caps on the powersupply board and it will likely fix your problem. Because it still has power to the degauss coils it hasn't blown the fuse. Power supply not starting like that is usually caused by a small electrolytic capacitor near the heatsink on the mains side of the powersupply. They can be replaced for about 10 cents.
Hope this helps
Posted on May 06, 2009
RCA 32'' TV
Unfortunately, the Power Supply has spat the dummy out. It is giving enough power to light the LED but not enough to run the set. To replace it will probably cost more than buying a new set. But ask around your local repairers for a price before you make any decisions...
Feb 23, 2010 | RCA F32444 32" TV
I own an 32 inch RCA TV Model No. F32444 one day
The TV has burned out.......Don't switch it back on again unless you want to get electrocuted, or burn your house down
Jan 19, 2010 | RCA F32444 32" TV
RCA 32'' TV making a humming noise
sounds like a shorted horizontal output transistor probably caused by the high voltage transformer or hot. it is most likely fixable but it will be costly.
Aug 19, 2009 | Televison & Video
Power supply
Most power supplies die because of the electrolytic capacitors replace them and it should solve your problems.
Hope it helps
May 06, 2009 | RCA F32444 32" TV
RCA 32444
While it could be that the power supply has failed, it's more likely a problem within the Horizontal sweep circuit. Might be the Horizontal output transformer, or, the transistor, or both.. An exception would be a shorted diode in a derived supply from the horizontal sweep, or a short on the load circuit of the supply. All of the parts are soldered in. There is no "power supply" that can be removed and replaced as a unit. If you have no electronics experience, stay out of the TV. You have no business inside of a box that when working develops something to the tune of 30,000 volts. Not just a little dangerous, it can kill. If you have the experience, fine, if not, consult an electronics servicer.
RCA TV dead
If this is a crt type tv. This could be attributed to a faulty high voltage circuit. A defective horizontal output transistor or the flyback. Or better to check some minor component with regards to flyback like diodes.
Fix TV
I have a sony i have picture but its has a red sceen.
May 25, 2008 | RCA F32444 32" TV
Can't View Cable RCA f32444
You will have to go in the menu and switch it to cable mode, then do an autoprogram and you will have all the channels.
Sep 04, 2007 | RCA F32444 32" TV
CHANGING CHANNELS ALL THE TIME
I have seen some RCA TV's with this problem and it has usually been a switch going bad on the keypad of the tv. This can be confirmed by disconnecting the plug from the control panel to the main chassis.If you are lucky, and the ir rcvr for the remote is not on the control board, you can still control tv with the remote.Good luck.
Jul 25, 2007 | RCA F32444 32" TV
Tv wont turn on
A high pitched chirp is a sign that you have a short on the load of your power supply. I just finished repairing one of these sets and it had a shorted horizontal output transistor and a bad flyback transformer.
Jan 10, 2007 | RCA F32444 32" TV
RCA F32444 32" TV Logo
245 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
