Question about Polaroid TLA-01511C 15 in. LCD Television
Black box in the middle of the screen flashing some sort of code
On one channel, (satalite tv), 110 I get a black box in the middle of the screen with code being generated. example: <0085B10>[F5E5] the code keeps changing and the black box stays there.
  • Anonymous Mar 17, 2014
    after the tv is on for a little while, a black box comes on in the middle of the screen.
    President:
  • Polaroid Master
  • 1,779 Answers
Try turning off your closed caption.
Posted on Feb 14, 2009
A BLACK SQUARE APPEARS IN THE MIDDLE OF THE SCREEN HOW DO I GET RID OF IT
Hi Tony
You`ve mentioned that ON CERTAIN CHANNELS THE TV WORKS FINE, so your trying to say that not all channels THE BLACK SQUARE APPEARS IN THE MIDDLE O THE SCREEN... my be that black square is generated from the broadcast center. may be your unit is good. let me ask you how many channels that your tv works fine..?
Jan 16, 2014 | Panasonic CT-34WX52 34" TV
Black box in middle of screen/picture
Closed Caption function to that channel you select is ON. Make it OFF, when you are in that channel which displays this black box. It will be best to reset the TV to its factory settings first, and then re-tune it. for more details, refer its user manual.
Jul 10, 2012 | RCA L32WD26D HDTV/DVD Combo
Tv screen is black everything is plugged in Guide will come up but no picture
This problems,it not the tv, it is the satalites boxes or the cables boxes are the problems.Tries unplug the satalites boxes or the cables boxes for about an hour.Replug those boxes back in now those boxes should be resetting itself and updating it software.U should have picture now,if not call ur cables or satalites providers,get a replacement boxes.
Nov 25, 2010 | Sony Televison & Video
I pressed the cahannel up and down button on my panasonicTv and I changed the input signal. It is a black screen and it says no channel available no signal. How do I fix this?
Tries a better antena like a digital antena or a roof antena for the free air tv signal.Rescan the channels.
If cable,satalite or telicom signals unplug replug the reciever box for reboot to upgrade.Make sure ur tv in cable setting,rescan for for dhannels.
Nov 07, 2009 | Televison & Video
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Can't get rid of black box
You have your TV in the "Teletext" mode. Go into the TV menu and select the closed-captioning menu and turn off the text function. What you are seeing is the result of the TV's captioning circuit latching onto a false text pilot signal and then throwing up the black box on the screen.
michtech
Feb 17, 2009 | Hitachi 50UX57B 50" Rear Projection...
Black square box pops up in the middle of tv screen.
turn off the closed captions - you have it in text mode that will have a big black box with video on the sides
thanks
scott
Feb 14, 2009 | Polaroid LCD-1700 17 in. Television
I have a LG plasma T.V., model 42PB4D. Black box/middle of screen
Try this:
In the menu go to CC and set the TV to CC1 as this is a text box appearing for captions. Hope this works!
Jan 11, 2009 | LG 42PB4D 42 in. Plasma HDTV
Big black box in the middle of the screen
The black box is there because your closed captioning is on and set to text mode. Some channels send the signal even when there is no actual text to display. You can get rid of it by either turning off closed captioning or changing it to CC1 or CC2 mode instead of text. If you can't find those settings, then restore factory settings as directed in your user manual.
Jun 04, 2008 | JVC AV-32230 32" TV
You have CC (closed captioning) turned on and it is set to text mode.....Go to the menu on the remote use the right arrow and hilight "C.CAPT",use the down arrow to highlight "C.CAPT",use the right arrow and highlight "off" then exit button on remote.
Sep 15, 2007 | Toshiba 36A60 36" TV
Polaroid TLA-01511C 15 in. LCD Television Logo
167 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
