Older projection TV reduce picture quality
The TV takes a while to ''warm up'' with the picture washed out and faded. When it does come on, the colors are faded and video adjustments don't help much. Also, the picture has some wavy, shadowy, vertical lines. When connected to the DVD, the picture is better, but still not as sharp as it used to be and still has the wavy, shadowy, vertical lines. The unit is an older (1994) Hitachi rear projection TV, Model 50UX19K.
  • bobwirtz May 09, 2009
    picture faded, washed out. long warmup. wavy shadowy vertical lines. model 50ux19k hitachi
  • 43 Answers
CRT's (tubes) are shot.
Posted on Feb 14, 2009
Most likely its serveral suface mount capacitors, part of the Comb Filter. Very fixable...
Posted on Mar 16, 2009
Color is red and blue green has faded
Check and replace the damaged component/s at its video output card circuit. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 17, 2014 | Toshiba 36A43 36" TV
Picture quality of colours fading
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Philips 60PP9202 60" Rear Projection...
Dark picture
Hmm my dad's old t.v. just cut out on him it took awile to turn on this my be the end of ur tv so this might be a power problem but older t.v. loose there colour on the screen my uncle had a like 10-15 year old t.v the screen was like green when it was light but when u turned of the light or closed the blind's it's picture was ok so try that.
Feb 02, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Samsung HLN507WX/XAA - Bad Picture
its sounds more like the digital board that needs to be replaced
May 04, 2009 | Samsung HLN507 50" Rear Projection...
Poor picture quality on old 55" rear projection phillips tv
replace the coolant in the CRts. Very common problem with the older rear projection tvs. You can get the coolant replacment kit at the following link which contains the coolant and instruction CD.
http://servicemanuals.vstore.ca/
Dec 19, 2008 | Televison & Video
Picture is fuzzy and color seems faded
Sounds like your coolant in the tubes need to be repalced. This is a common problem as the set gets older. Check with www.TvRepairKits.com for the supplies and instruction guide.
Dec 09, 2008 | Philips 46PP9302 46" Rear Projection...
Televison & Video Logo
389 people viewed this question
Top Televison & Video Experts
