Question about Jetway (939AGP-OC) Motherboard
Not everything powers up when I turn on my disassembled computer
Ok, so this is my first time building a computer, and I made a mistake in buying a mobo with a manual written in bad English. Now when I power up my computer, the monitor, mouse, keyboard, & maybe even the hard drive don't. I need aid!
    Problem Solver:
  • 6 Answers
Remove first the power suppy. if it is 24pin power suppy, shorten pin 15/16. that is the black and green,
if the fan of power supply rotates, then the P.S. is ok.
then return it to motherboard. check your connection with the motherboard power switch.
good luck
Posted on Feb 15, 2009
Insignia IS-HC040917 schematic
sometimes we have to do that though when like you said it takes too long .
May 19, 2015 | Insignia Audio Players & Recorders
I have never had any problems with this car until I decided to have the dealer look at it. I have a 2006 Mercury Milan and now after the car was served the wrench light comes on now and sometimes the...
ok with the transmission i have had the same issue sometimes if u do alot of in town driving the fluid will build moisture and if its real cold it will freeze the light could be on cause its acting like low fluid. letting it run and shutting it off thaws it out and it runs better if so take it to another shop and have the trans fluid and filter changed first like $175 tops, try that first worked on my explorer now shifts perfect again
Mar 04, 2015 | 2006 Mercury Milan V6
Hi,my hp probook 4310s does not turn on.before, everything was ok with the laptop.i just used it for two days,then it couldn't even takein power and there is no single when i plug the charger.i have...
Did you try another Cord/Charger before disassembling? Has the AC jack been damaged due to pulling on the cord? Has there been and damage? Do you leave the laptop plugged in all the time? Any electrical surges? Do you get anything when plugged it? Charge LED?
Sep 23, 2013 | Acer Aspire 3004WLCi Notebook
Entourage power steering freezing up
I suggest flushing the system first, could simply be build up from leaving the cap loose, or whatnot. Refill it with a conditioning fluid, like Lucas power steering fluid. Let us know if further diagnosis is needed
Jul 23, 2012 | 2007 Hyundai Entourage Limited Minivan
No picture screen black
un plug the monitor cables power cord everything turn off the computer the reconnect everything power back up turn on the monitor should work then
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
When i turn my computer on i hear the fan come on but nothing else comes on. I changed the cord but that is not the problem. I took it to Best Buy they plugged it there and everything turned on.
Sometimes the BIOS locks up on Boot. Doing a BIOS Upgrade from the Manufacture should help. A Pro should do this... any mistake can be catastrophic. Other conditions is the HD... Age, Fragmatation or Erros could cause the HD not to be read the first time or cause a Boot delay
Dec 30, 2009 | Gateway GT4022 PC Desktop
LG flatron L1970 h monitor flickers.
Just fixed mine :)
Biggest mistake was to try to open the monitor itself :( But I didn't brake anything :D
You just have to gently open the transformer unit (power brick) and replace two identical 1000uF 16V capacitors.
Here's how:
Remove the power cord first, to discharge the capacitors to avoid any nasty shocks when inside. Remove two rubber feet on the bottom side of the power brick. Just use your nail and lift them. Put them safely for later assembling. Unscrew two screws you just found under the removed feet. Now you have to unlock the other side held together by plastic locks. Try to apply pushing force and toque with screwdriver just where the seam is meeting the power cord socket's edge. Look for two identical capacitors and check if the tops are bulged of broken. I assume they are but you can try this method anyway. When the unit is disassembled you'll have to unsolder at least one of the wires that hold shielding plate on the bottom of the circuit board. Then unsolder the two capacitors (1000uF 16V). Replace them with the same type (1000uF) and the closest voltage possible. I have replaced mine with 1000uF 24V ones and so far I'm typing :D
That's it. If you have done this and looked for other damaged capacitors and replaced them also... Well then good luck disassembling the monitor unit and checking on inverter and lamps ;)
Cheers!
Nov 02, 2009 | LG FLATRON L1970HR LCD Monitor
PS3 wont turn on!!!!!!!!!
happnd ta me 2 fan waz broken i had ta fukn buy a nu 1....sory mate , ax the shop where ya boht or else try ta buy a nu wun....
Oct 29, 2007 | Sony Playstation 3 (PS3) Console
Receiver won't power on
My receiver was turned on and plugged into a surge protector along with my LCD TV. The power went out and everything shut down.
Dec 28, 2006 | Pioneer VSX-D514 Receiver
Jetway (939AGP-OC) Motherboard Logo
49 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Iqbal Husain
Iqbal Husain
Starnley Johnwells
Starnley Johnwells
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
