Question about Cuisinart DCC-1200 Coffee Maker
The reservoir tubes are clogged so the water doesn't flow through
I'm wondering how you get the bottom of the coffeemaker off to get to the reservoir tubes to clean them out. What looks like hex screws are not.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
I used a small screwdriver in those, which worked great as long as I used a size that would wedge between the points of the star. They are probably Torx screws (star-shaped).
Posted on Jan 20, 2015
  • 137 Answers
If this maker was mine I would put a 50/50 solution of "Lime Away" and water in the reservoir and let it sit all day, then I would put two or three pots of clear water through it followed by a soultion of a tablespoon of baking sode disolved in water I would let this sit for 15 minutes or so followed by a couple or three more pots of clear water, that should do it. Don't worry it wont hurt you it will be so diluted and neutralized by the baking soda, it couldn't possibly be harmful..
If this works please respond.
Posted on Feb 15, 2009
I can do the vinegar thing but the cleaner thing is a piece of plastic. I just dont know how a piece of flat plastic is going to help.
Do you have the de-limer spring that came with the coffeemaker?
Sometimes you have to take the top off of the coffeemaker & run the spring down the entrance hole to clear lime obstruction from the tank fill tube.
There are 2 or 3 phillips-head screws that hold the top on. 2 are under the water reservoir fill cover, and a 3rd may be in on the middle -top towards the back. Depends on your exact model.
Once the top is off, you'll see a lever arm.that keeps the water from flowing down the fill tube while the reservoir cover is raised. To get access to the fill tube, you gently pop this out from the pivot point with some upward pressure, Run the de-liming spring down the tube a few times to make sure it's clear.
Reverse the above process to reassemble.
Be sure and remove & clean the spray head over the brew-basket after de-liming also. Sometimes chunks of minerals block the holes.
Feb 28, 2014 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Why is my coffeemaker leaking from the bottom?
  1. Make sure the filter is properly in position and that the brew basket is fully closed.
  2. If the coffeemaker is equipped with a removable water reservoir ensure that the reservoir is properly installed.
  3. Avoid overfilling the water reservoir. The coffeemaker is equipped with an overflow slot near the top of the water reservoir. If too much water is added it will flow out of this slot and collect near the base of the unit.
  4. The coffeemaker may require service. Contact an Authorized Service Center.
Sep 21, 2011 | Philips Senseo HD-7810 Coffee Maker
I have had my hamilton beach brew station for a year. The past 2 weeks, the water put in the bottom reservoir does not empty completely into the coffee reservoir. It leaves about 8 oz in the bottom water...
On your machine there is maybe inside water reservoir a hose or tube that goes down to bottom, or suppose to go down to bottom, to **** up all water. Look inside and see if hose is going all the way to bottom, maybe it got hung up or crooked. Please let me know, glad to help, thanks mike ( mr bean man )
Jun 08, 2011 | Hamilton Beach BrewStation 47214 Coffee...
Coffee brewer works to the point wher you push the flashing brew button no water pumps through.
Hi
If your coffeemaker appears to be clogged. Create a vinegar and water solution and flush the concoction through your coffeemaker pump. This will help dissolve build up in your coffeemaker. If you do this once a month, your coffeemaker pump won't clog.Unplug the coffeemaker and inspect the pump valve. Water won't rise through the fill tube if the pump valve is stuck or broken. If your pump is sealed, replace the pump. If the pump valve is accessible, make sure there are no coffee grounds or mineral deposits around it.
Also check the brewing switch is in good working order. Remove the base plate on your coffeemaker and test the switch with a volt-ohm meter. Set your volt-ohm meter on the RX1 scale. If your switch reads zero ohms, your switch works fine. If it reads anything other than zero, replace the switch. Also take a look at the tube connectors, if your coffeemaker is sputtering, leaking or steaming. Leaks in pump coffeemakers are often due to faulty tube connectors. Unplug the coffeemaker and fill the reservoir with water. If water leaks from an elbow, clean the mating surfaces before replacing it. If your water leaks from a tube connector, replace the tube and mating elbow to ensure a good fit.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 07, 2011 | Breville BKC600XL Coffee Maker
I actually have the model B30, but didn't see it as an options. My coffeemaker won't brew the whole amount of water in the reservoir, thus making only about 1/3 of a cup of coffee.
With the coffee maker unplugged and an empty cup in place, I filled the reservoir with filtered water and with a short length of flexible plastic tubing I blew in to the small hole in the bottom of the reservoir. I did this 4 or 5 times sucking some water in to the tube to force it through the system. When I had finished there were a lot of grounds in the cup and the next time I used the coffee maker it worked perfectly.
Jan 18, 2011 | Keurig Elite B40 Coffee Maker
My coffeemaker wont pump water what gives?
check the plastic tube that runs through the water reservoir. usually when they stop moving water there is a leak or kink in the tube stopping the flow. sometimes they make the tube out of an almost surgical tubing and when the hot water travels through the tube it gets soft and collapses stopping the water. if you have one of the later ones, i suggest taking it back and demending your money back.
Mar 31, 2010 | Braun Aromaster KF 400 Coffee Maker
Seems clogged
The problem may be caused not by a check valve in the inlet hose. This little gadget, about an inch inside the heater end of the tube, allows water to flow into the heating element but not back -- unless it's broken. This hose is the one closest to the outside edge of the bottom.
I'm sure *someone* must sell a replacement part, and I'm in the middle of that search. But I did get an older, broken coffeemaker from my brother (another member of "the Slow Wastebasket" society!
I was able to disassemble my Model CBC-00PC2 using a standard Torx 10 screwdriver. However when I tried to take apart an older model, DCC-1200, I found that it used the security version of the Torx 10 screw: it has a tiny nipple (correct word?) in the center of the screwhead that prevents a standard Torx driver to fit. I was unable to find the correct screwdriver and a security Torx bit is too thick to fit, so my brother and I resorted to brute strength to pop of the bottom.
The only other problem I had was that the older hose was a bit brittle and both the older and newer ones had sort of welded themselves to the aluminum heater element tube. Luckily, there was enough extra length and I was able to make it fit -- barely! I lost one of the little metal clips so substituted a tiny cable tie.
Everything seems to work. Oh, the only reason I knew about the check valve is that I previously disassembled the thing to see what was wrong and I found something (probably a piece of the valve!) floating around.
Hope this helps.
Nov 18, 2008 | Cuisinart DCC-1200 Coffee Maker
DGB-600 grind & brew thermal coffeemaker
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
Jul 21, 2008 | Cuisinart DGB-600 Coffee Maker
Won't Brew. No water from resovoir to fileter.
To clean your coffeemaker:
1) Pour four cups of undiluted white household
vinegar into the water reservoir.
2) Place a paper filter into the removable filter
basket and close the brew basket lid.
3) Place the empty decanter on the
warming plate.
Make sure to accurately place the
decanter on the warming plate
to avoid the possibility of overflow.
4) Start the brew cycle:
a. Turn the switch to On. Then, press the
brew button to begin the brew cycle.
b. When the water has flowed into the
decanter, turn the coffeemaker Off
and let the water stand for 30 minutes.
c. Repeat Steps 1 – 4b.
Have a nice day!
tc
Apr 16, 2008 | Mr. Coffee ARX23 / ARX20 Coffee Maker
Ice amker and water spickett is no longer working
Hollow ice cubes are the result of poor water flow to the ice maker. I know you already have experienced flow issur since you mentioned poor water dispenser flow. You apparently have a filter clogged, a house supply valve clogged or lastly a clogged water solonoid valve. The filter is self explanitory. You would replace the filter. The house supply valve is next most likely, to test it you would need to remove the supply line at the rear of the refrigerator after turning supply off the turn supply on to check flow. If the flow is STRONG then next most likely is a clogged solonoid valve. To test it you would, with supply connected and turned on, need to locate the plastic tube that goes to the water dispenser reservoir in the refrigerator section. Disconnect the tube at the solonoid valve and place glass or pitcher at solonoid port while someone presses the diapenser lever. If you have poor flow then but had good supply flow, the valve must be bad.
Nov 21, 2007 | Jenn-Air JBR2088HES Stainless Steel Bottom...
Cuisinart DCC-1200 Coffee Maker Logo
1,442 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
