Question about Ovens
Kenmore electric oven light will not turn off.
I have model 911.41065, electic oven. The light stays on constantly, and gets very warm. I keep tuning my oven off at the circuit breaker level because I'm afraid it will catch fire. Help.
  • 6,784 Answers
The internal pressure switch is stuck in position. its due to surface gunk build up. carmelization of oven debris.
Posted on Feb 14, 2009
I can't use my oven it keeps turning off and my oven is beeping and the problem light is flashing how can I fix this so I can use my oven
Kenmore electric oven keeps shutting off.... ' Sears PartsDirect
www.searspartsdirect.com > Ask an Expert
Oct 15, 2010 - Kenmore electric oven keeps shutting off. ... Can't locate your model number? Use ... hi, i purchased and replaced my etc (#316455420) for kenmore electric range model # 790.9011.2010. i was ... How to use the site (3:58) ...
Frigidaire oven Bake functions randomly beep and shut off ...
Dec 25, 2015 | Ovens
The "element on" indicator light
It the indicator light on all the time? Or after cooking and you turn the elements off the light stays on for a long time but it does eventually go off?
Mar 04, 2011 | Ovens
Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
I have an older Sears Kenmore oven. It has the
the internal fuse is blown out and the circuit breakers gone short its a reparing job not a resetting job.you will have to opoen the oven and get the circuit breaker checked and repaired or replaced.
Mar 02, 2009 | Kenmore Ovens
Kenmore oven locked door light on but not, won't bake
Check your breakers and also your wiring. Try to turn off the breakers for about 10-15 seconds. Your board inside the control panel may be bad since you are getting mixed signals.
Jan 12, 2009 | Kenmore 47783 Electric Single Oven
Kenmore elect oven 40499
NOT SURE ABOUT THIS MODEL BUT SOME OVENS HAVE A CALIBRATION PROCEDURE THAT MUST BE DONE AFTER CHANGING THERMOSTAT CHECK WITH APPLIANCE SHOP OR DEALER FOR ANSWER DONT HAVE BOOKS ON THIS MODEL
Dec 20, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Oven going crazy
The bang may have been an element arcing over.  Turn off the power and remove the element.  If it shows any form of damage, replace it.  If you're not sure, use a continuity checker to check it.  If you have two elements...do this for both.  You will likely find the problem.
Nov 13, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven light
This is done to regulate the temperature. Higher heat settings will let the element stay on longer, while lower settings will turn it off sooner. Even on high, the elements may turn off periodically because there is a switch called a temperature limiter. Its job is to keep the element from overheating.
Aug 11, 2008 | Dacor MCS130 Millennia Electric Single...
Oven doors will not close properly
Most of these I have seen have to have the hinges and recievers replaced to get the doors to close properly and keep the light off.
Apr 17, 2008 | Ovens
Ovens Logo
236 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
