Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
How can I put my chain brake back on?
I just bought a 3416 Poulan chainsaw. Well after cutting fire wood all day, I wanted to clean it out. Well in the process of that I took out the chain brake. Any suggestions on how to put it back would be greatly appreciated...
  • 2,176 Answers
Tye going to psep.biz and looking at a breakdown for this saw. make sure you have the exact model and type number and their breakdowns are excellent. Let me know if this doesnt work
Posted on Feb 15, 2009
    Problem Solver:
  • 13 Answers
I think the chainbrake is in position on! In that case its to thight to get
back.Just pull the handle back and the brake klicks off then Try again
Posted on Apr 16, 2014
When go to cut engine is runnig but chain stops when touch the tree
Hi Pam:
Using chain saws takes a bit of getting used to, and it can be DANGEROUS.
- The chain must be sharp to be able to cut properly, and a sharp chain "bites" into the wood.
- Before you touch the chain into the wood, you have to speed up the engine. This takes some getting used to.
- Try this technique: With the chain about an inch above where you want to cut, squeeze the throttle about half way so the chain is spinning. Touch the chain to the wood and increase the engine speed as the chain starts to cut. The harder you cut, the more power you need to apply.
After a while it gets to be second nature.
Work Safe, and get an experienced friend to help with some "hands on" coaching.
Cheers.
Nov 26, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Troubleshooting chainsaw
Sadly, the 3816 is not designed for larger timber. 38cc is only for smaller limbs, As a general rule also the largest timber to cut should only be 2/3 of the length of the bar
Jul 27, 2014 | Poulan/Pro 3314 3416 3816 3818 40184218...
Poulan 3816, back fires through carburator, wont start.
water in the gas or carb needs to be removed and taken apart and cleaned
Feb 20, 2014 | Poulan/Pro 3314 3416 3816 3818 40184218...
When cutting wood saw will not oil chain whats the problem
make sure oiler jet under the chain tightener plate is clean even take bar and chain off and start saw
Dec 12, 2010 | Poulan 18" Wild Thing Chainsaw
What are the high and low carburetor settings on a poulan 3416 chainsaw?
are they two separate screws? one for fast, one for slow.for the slow setting, first start the saw then screw until motor runs smooth without chain moving....if to slow the motor will stop....for fast screw....rev motor flat out then adjust so it screams its head off so to speak....it will need all its power for cutting wood so don't think you are opening it up to much as its designed for it.
Jul 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Idles fast, won't cut wood, stalls under load
Clean the fuel filter, air cleaner and muffler if clogged. Check all fuel lines for condition--replace any with original rubber lines--not plastic. The carburetor sounds like it could use a thorough cleaning and re-kit. It's somewhat common for saws to leak some bar oil over a long period. Good luck!
Jun 11, 2010 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
I'm using a Poulan 3416 and it's simply not cutting my neighbor and I used it last weekend to cut up fallen trees but it doesn't cut at all now?
It may sound oversimplified but....is your chain sharp? Is the chain on backwards?
When cutting you should be getting nice big chips from the cut. If you are getting more "dust" than chips the chain is dull and needs to be resharpened.
There is no set "time" to sharpen a chain,but you will only get a few hours of cutting before the chain dulls. In soft wood like pine you can go longer. In hardwood like oak or locust you may get an hours worth of cutting. If the bar digs into the ground or hits a rock it's time to sharpen right then because the chain will be dull.
I always carry an extra chain or two just for emergencies like hitting a rock or some wire in a tree.
May 17, 2010 | Garden
It starts and runs right for about five minutes, then it won't rev. to the highest rpm's. Will start after that but won't run fast enough to cut.It's a Poulan 3416----16" 34cc
Remove the muffler and clean out deposits from the spark arrestor screen. Make sure the intake air filter is clean. If these two items are good, then the 'H' carburetor adjustment may be too rich--turn clockwise somewhat until the engine runs at full speed, but 4-stroking slightly. The engine should smooth out and 2-stroke with even a light cutting load. Make sure the chain is being properly oiled while running. Hope this helps!
Dec 24, 2009 | Poulan ES350 16" Chain Saw
Poulan Pro 42cc Just Won't Cut It
The chain is directional, only cuts one way. If a new chain won't cut, it must be on backwards.
Apr 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Wood Shark Chainsaw - wood smoking. Is chain on backwards?
I cannot tell you about a picture, but for one: chain direction, the bottom of the bar is where the cutting takes place, and therefore, looking at the chain, you will see, on the bottom, the antikick back link is sort of curved, and then the next part is the straight tooth. The highest part of this straight tooth is the sharp edge, and this high part should face towards the motor. The chain, on the bottom side of the bar, is pulled in towards the motor by the clutch/gear. That is your direction of travel.
As to cleaning the air filter, Hopefully you have access to compressed air, as in simply blowing off the dirt. You do not want to use liquid cleaner. Simply blow off any dirt, after pulling the filter away from the carburetor, of course. Then place it back in place.
It may be that your chain is real dull. The top edge of the high part of the flat tooth needs to be sharp. And the outside corner needs to come to a nice point. Remember, there is two cutting surfaces on each tooth, the top is cutting down into the wood, and also that outside sharp corner is openning the cut for the bar to pass through. Proper sharpening, if new to it, can be hard to grasp. Any chainsaw manual should show how to do a good job.
Nov 16, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
191 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
