Question about Toshiba Computers & Internet
Toshiba a215-s5808 doesn't start
Iwas updating the bios according to toshiba website and the screen went blank. and it wouldn't start since then
  • 34 Answers
Hi!
you need to strip your laptop to get to the cmos battery leave it out for 4 hours then assemble the laptop ,it should work:)
regards craig
Posted on Feb 15, 2009
When I try to update Bios on Toshiba Satellite A215-S7462 The computer 'locks up' (becomes completely unresponsive), and the computer's display goes blank (turns off).
Updating the BIOS usually brings up some problems. It burns the motherboard. I suggest that you contact Toshiba regarding this for warranty support.
Dec 11, 2012 | Toshiba Satellite A215-S4747 Notebook
Upgrading BIOS! If it isn't broken don't fix it. Upgrading is a scapegoat fix, and many manufactures have a disclaimer. "You are on you own", and the likes for a reason. Most solutions are found elsewhere. However, if you truly need to update read this to help you with the upgrade. You don't want to end up with a brick. http://www.techrepublic.com/blog/10things/10-common-mistakes-you-should-avoid-when-flashing-your-bios/357
Dec 10, 2012 | Computers & Internet
Toshiba satellite a215-s4697 bios password shown when i start the laptop. please guide me how to disable the password from bios. if possible expalin through circuit
Easist way to disable he password is to, restart the Pc, as it is starting up hit F8 key repetitively until you get into the boot menu. Once in the boot menu, look for Start in Safe mode, Once you start the Pc is safe mode You should get to the log on screen, It should show 1 new user, Know as Admin- The password- If there is one will be, admin or admin doesn't work try signing in with out any password.Once logged in go to your control panel and the into User Acct and disable the Password! Hope this helps!
Best Wishes and Good Luck!
May 05, 2011 | Toshiba Satellite A215-S4697 Notebook PC
How to format a drive so I can reinstall windows visa on my computer toshiba a215-S5808. And the reason need to know is cuz if I try to do it just like that I get an error 03-EEEE-000 and I heard if u...
start the computer and at the same time keep the delete button depressed until the bios screen comes up
in one of the tabs you will find format the hard drive
do that then go to oot tab and change boot sequence from hard drive to cd as first preference
open the cd and insert the disc
close down the computer then restart and it will boot from the cd
Nov 17, 2017 | Toshiba Satellite A215-S5822 Laptop
My toshiba satellite a215-s5837 has a blank screen
if u be able to check the chips VGA and South-bridge, while the board on/working without casing u can fell by touch the chips surface if its hot or warm that mean chips working fine, if not that is make the display blank, if its fine just try to reset hardware Bios.. Good Luck
Oct 27, 2010 | Toshiba Satellite A215-S5837 Notebook
Toshiba satellite becomes unresponsive after bios
First of all try this. Turn the laptop off and remove the battery. hold down the power button for 30 seconds. Plug just the AC mains power jack in and turn the laptop on.
If it boots all is well, turn the machine off, put in the battery.
Just out of interest can you remember who manufactured the BIOS? was it Phoenix or AMI?
Good luck.
Jul 15, 2010 | Toshiba Computers & Internet
The screen on my laptop (satellite A215-S5808) will not come on..it just stays black
Updating the BIOS can give problems if the wrong upgrade was installed or the BIOS update was not completely installed/finished. If possible go into the BIOS and roll back to the previous version of the BIOS/backup version of the BIOS.
Jun 10, 2009 | Computers & Internet
Toshiba Satellite a215-s7437 will not boot at all - black screen
It sounds like two possible things. One thing may be that your screen is not working anymore. Can you get a monitor and plug it into your port located on the side of your laptop? If your screen pops up on the monitor this tells us your screen is either in need of replacement or a connection may be loose.
If that is not the case......
Another thing is your hard drive may not be initiating. If you feel confident enough I would open the back where the hard drive is located and make sure the hard drive is not loose. Does it give you any beeping sounds when you turn it on? Can you count the number of beeps? This will tell you what the problem is on boot up. Also, is it a black screen with a cursor blinking?
Mar 14, 2009 | Toshiba Satellite A215-S4747 Notebook
My Toshiba A215-S4747 Crashes every time I move it.
This sounds like the Toshiba Blacvk Screen of Death issue with early A215 models. Re-boot and hold down the F2 key to bring up the BIOS screen. If your BIOS version is less than 1.9, you must update the BIOS.Go to the Toshiba support site and search by model. If your BIOS is ver. 1.9 or later, then go to the power opetion settings and set BOTH the minimum and Maximum power to 100% for BOTH battery and AC. That will fix this about 90% of the time.
Dec 16, 2008 | Toshiba Satellite A215-S4747 Notebook
On my toshiba laptop A215-S4767 the screen just goes black. I have to pull battery and reboot. Some article I read said something about bios but with no further details.
yes... a common problem with Toshiba...
you DO need to go to the Toshiba website... look for the support and drivers section.....
Match up your make/model from their choices.... and Download/ Install the WinPhlash BIOS Update It will Stop The Random Black Screens and Blank Freezes...
Nov 20, 2008 | Toshiba Satellite A215-S4767 Notebook
Computers & Internet Logo
221 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
