Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Windows xp /ubuntu
I dont have a valid xp so i downloaded ubuntu 8.10 operating system. but either wont load now and its just a windows xp frozen screen which wont do anything all that i can move and see is the mouse arrow. is ubuntu a os of its own or in conjunction with windowsxp ? and who do i fix this problem now.
thanks
  • 4 more comments
  • Jay Feb 14, 2009
    i have and it dose give the option for xp or ubuntu and wheni select it loads but still after download it installs xp cause after install there is no difference to computer all items look xp
  • Jay Feb 15, 2009
    i have downloaded it again and reinstalled and still has not worked. I now have the added problem that when i reboot my pc it goes to a option of rebooting windows xp or ubuntu but dose not work and xp half works have tried to wipe my pc clean and this also has not worked and suggestions at this stage all i want to do is just wipe my pc clean if possible
  • Jay Feb 19, 2009
    thanks sorted
  • Roberta Smith
    Roberta Smith May 11, 2010
  • Roberta Smith
    then ubuntu didn't finish installing ... reinstall it
  • Roberta Smith
    reboot... when the grub loader comes up make sure it's booting to ubuntu
    Scholar:
  • 77 Answers
It will be better if you print these instructions since you will need to type many commands later. I'm typing a detailed procedure to recover your windows.
It's possible that somehow your Windows registry is corrupted. But there is a backup. Only thing is you need to manually restore it.
Boot using your Windows XP cd in the drive and press enter when it asks to boot from CD (if it does not ask, then you will need to go to the CMOS setup by pressing DEL or F2 key and change the boot sequence)
Now, when booting from XP CD, it asks if you want to do a recovery, press R and you will get this screen:
Microsoft Windows(R) Recovery Console
The Recovery Console provides system repair and recovery functionality.
Type EXIT to quit the Recovery Console and restart the computer.
1: C:\WINDOWS
Which Windows Installation would you like to log onto
(To cancel, press ENTER)?
Type 1 and press enter.
Now type the commands I am putting below, one by one per line and press enter after every line.
md c:\tmp
cd system32\config
copy system c:\tmp\system.bak
copy software c:\tmp\software.bak
copy sam c:\tmp\sam.bak
copy security c:\tmp\security.bak
copy default c:\tmp\default.bak
del system software sam security default
Now, type these commands: (Take care to type the dot as it is)
copy c:\windows\repair\system .
copy c:\windows\repair\software .
copy c:\windows\repair\sam .
copy c:\windows\repair\security .
copy c:\windows\repair\default .
Now type exit and press enter and the system will reboot.
Remove the CD and boot normally in Windows (even if you get the grub menu)
If it boots in to windows, then do the following:
Start Windows Explorer.
On the Tools menu, click Folder options.
Click the View tab.
Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the "Hide protected operating system files (Recommended)" check box.
Click Yes when the dialog box is displayed that confirms that you want to display these files.
Double-click the drive where you installed Windows XP to get a list of the folders. It's important to click the correct drive.
Open the System Volume Information folder. This folder appears dimmed because it is set as a super-hidden folder.
This folder contains one or more _restore {GUID} folders such as "_restore{87BD3667-3246-476B-923F-F86E30B3E7F8}".
Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RP x under this folder. These are restore points.
Open one of these folders to locate a Snapshot subfolder; the following path is an example of a folder path to the Snapshot folder:
C:System Volume Information_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}RP1Snapshot
From the Snapshot folder, copy the following files to the C:\tmp folder with the mouse:
_registry_user_.default
_registry_machine_security
_registry_machine_software
_registry_machine_system
_registry_machine_sam
Now, once again put your XP CD in to your CD Drive and reboot using the CD. Again press R for the recovery console.
At the console, type these commands one by one per line and press enter after every command:
cd system32\config
del sam security software default system
copy c:\windows\tmp\_registry_machine_software system
copy c:\windows\tmp\_registry_machine_system system
copy c:\windows\tmp\_registry_machine_sam sam
copy c:\windows\tmp\_registry_machine_security security
copy c:\windows\tmp\_registry_user_.default default
Now type exit and remove the CD. Boot normally in Windows and you must be back to normal.
HTH,
Regards,
Deboo
Posted on Feb 17, 2009
How do you uninstall the operating system on a AMD Athlon 1.3 GHZ, 512mb computer
You'll need a valid copy. If you don't have one, Ubuntu and other Linux distributions are free. When you go to install the new OS, you'll format the drive and erase everything anyway.
Nov 18, 2012 | Computers & Internet
I have original win Xp Home ed. but it is on recovery disk. I changed my motherboard and i could not install my windows from that disk. I want seperate cd of Win XP Home edition.
I'm afraid its a case of buying one. I'd try ebay, the latest version is SP3.
Alternatively you could download and install Ubuntu. Its a free operating system. Google Ubuntu, all instructions are there on the Ubuntu website.
Jun 28, 2010 | Microsoft Windows XP Home Edition
Counterfeinting Problem
If you do have a valid number then the easiest way is to contact Microsoft. Usually there is a sticker somewhere on the computer. If you have an upgrade with a valid number then Just call them and they will issue you a code to make you valid.
When you try to enter an invalid key (or what the computer thinks is an invalid key) They will tell you to call Microsoft and give you a number.
If you don't have a vald key. Call them and they can sell you a valid key and get you going over the phone.
good luck
Mar 01, 2010 | Microsoft Windows XP Professional With...
How to validate windows 7??
Go to PC-GEEKS.NET and get REMOVEWAT21 or LOADER !!! vThey will activate windows 7 instantly!!! I know its my site!!!! gromero007
Sep 25, 2009 | Microsoft Windows Vista Ultimate Edition
I need a validation key for Windows XP.
That would be piracy; Microsoft's products are protected by copyright. You have three options; pirate a license, purchase a license or try a free operating system instead. Try Ubuntu for starters.
May 27, 2009 | Microsoft Windows XP Home Edition
I dont have genuine windows xp installed in my notebook. what should i do to solve this problem. i dont want to format it or reinstal the windows. thankyou
please enter www.andr.net
there you can find one crack file.
download the crack file
please apply the crack in c:\windows\system32\
after that you can use ur opereating system normally.
regards
murali
Dec 05, 2008 | Microsoft Windows XP Professional With...
USB mouse won't work under XP in a dual boot Ubuntu GRUB 1.5
It has the latest mouse driver (logitech setpoint 4.0). Before installing Ubuntu the setup worked w/ SUSE/XP using GRUB dual boot. After installing Ubuntu XP does not see the usb mouse. Even Logitech setpoint does not have the mouse setup/configuration option. It appears that at boot it does not recognize the mouse or disables it. The BIOS has the usb keyboard and mouse enabled. Currently, I have two mices one for xp and either mouse will work under Ubuntu.
Sep 03, 2008 | Canonical Ltd. Ubuntu
30 day use Windows Xp Pro
The problem is with the actual key that you are using. Not your computer, or the components inside of it. If you are certain that you are using a valid key Its likely that you have a a key for windows home, and you are trying to install windows professional, or visa versa... Either way, If all else fails, you could replace the OS ( Buy or download) much easier than the hardware inside your computer.
Basically your computer is fine, just get a valid OS. If your adventurous try ubuntu.
Hope this helps!
Jan 10, 2008 | Microsoft Windows XP Professional for PC
Windows XP OEM OS
Yes, you have to purchase a new copy of Windows XP... Or alternatively you can try a freeware operating system such as UBUNTU. It does basically the same stuff your Windows did, just with a little more flair! http://www.ubuntu.com/
Sep 25, 2007 | Microsoft Windows XP Home Edition
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
185 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
