Question about Sharp R-22GT Microwave Oven
Ee5 ERROR CODE on r-22gtf
When I plug in the microwave EE5 appears on the screen
  • Sharp Master
  • 9,098 Answers
Your voltage selector is not set properly.
The R-23GT and the R-24GT have been preset for 230V operation.
If you need to change this oven for 208V operation, follow instructions below.
1. Unplug oven.
2. Remove one screw(A) from the Voltage Select Cover located on back of the oven near the bottom.
3. Remove the Voltage Select Cover and rotate 180 degrees.
4. Reinstall the Voltage Select Cover using one screw(A) removed in Step 2.
5. Plug power cord into wall outlet.
Your oven is now ready for 208V, 60Hz operation.
Posted on Feb 15, 2009
My Galanz Microwave oven keeps beeping then a 3:10 appears. I can't get it to reset. What is this?
If it is just a matter of resetting unplug it and leave it off for half an hour and then plug it back in.
In order to get support for the microwave do a web search using google or bing .....enter the make and model ID and the figures that appear on the screen, that should throw some results up but you may have to trawl through a few pages of them
Jun 23, 2015 | Microwave Ovens
Will not turn on . Appears as though there's no power.
I'd try to unplug for a while. Could be a bad power cord for the microwave itself. I recently had a toaster problem. Bad wire right at the departure from the plug.
May 12, 2015 | Sharp R-930AK Convection/Microwave Oven
Twice my new kenmore microwave has just started beeping with the error code E11 appearing on the screen.Have to unplug it to stop it. WHat is going on?
I think this microwave oven uses an inverter to control the power output of the magnetron. Usually the microwave will advertise this feature with a trade name like "accu-wave" or "true-power" or some similar label on the front of the microwave. Assuming that is the case here, then the E11 error means a bad inverter
Aug 07, 2014 | Kenmore Microwave Ovens
Microwave plug started melting and is leaking what appears to be oil
Replace it. it may have a short near the plug causing it to melt. if the wires touch you may have a fire on your hands.
Nov 10, 2013 | Whirlpool MT4155SP Microwave Oven
Whirlpool mircowave model MH3184XP the display reads F2
There is a problem with the control pad. The membrane, or surface, of the pad may be broken or damaged somewhere, resulting in the F2 error code. This is common for Whirlpool microwaves.
Press "Stop/Cancel" twice and select a new cook program. Press "Start" to begin.
If the error code persists, press "Stop/Cancel" again and unplug the microwave. Wait several minutes and plug it in. If the F2 code appears again, it requires repair.
Replacement membranes can be found online
http://www.appliancepartspros.com/whirlpool-panel-asy-control-8205376-ap3775860.html
but the internals of a microwave are dangerous, having high voltages even when unplugged. With the cost of parts and labour from a service tech, you may be best buying a new oven.
Sep 04, 2013 | Whirlpool MH3184XP Microwave Oven
Samsung Microwave Mod # SMH9187ST. Starts on its own, "bake potato" on display screen. After shutting down, code SE appears on screen. No response from keypad until unplugged. Reset and problem ret
Contact Samsung, I was having a similar problem with the SE error appearing on my microwave. Apparently its a problem with the control panel and they are going to replace it free of charge under there epidemic warranty
Mar 18, 2013 | Samsung SMH8165W Microwave Oven
Code ee 5 on sharp microwave model rcd 2200m
It may be that the voltage selector on the back of the oven is not set to the proper level of your AC supply.
It will probably have settings for 208VAC or 230VAC.
Chances are your oven is set to 208VAC but it is on a 230VAC line.
Refer to your owner's manual for specific details.
Jan 15, 2013 | Sharp RCD2200M Microwave Oven
GE Microwave Model: JVM1540DN1BB Keypad appears to work... but Microwave doesn't work
The problem is more than likely in the microprocessor control board, sometimes a bad relay, or poor solder points.
Mar 11, 2012 | Microwave Ovens
How do I unlock the touchpad of my Profile 2.0 Spacemaker Microwave Oven # JVM2070
calvin,
If you have access to where your microwave is plugged in, unplug it for a few minutes and then plug it back in. This will reset your contol panel. Then follow your book directions to reset the time on the clock. Hope this helps!
Nov 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-22GT Microwave Oven Logo
267 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
