Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
The printer barely show any lettering with black ink,
The color is great I have tried 3 new cartriges and none of them work my printer is less than one year old the printer is the kodak easy share 5300
  • 1 more comment
  • Anonymous Mar 24, 2009
    black is a light grey color and the color works fine...haven't even had it for a year.
  • Anonymous Mar 30, 2009
    I have a Kodak 5500, I got a new printhead and it worked for a couple of days , less than 20 pages. Then the balcka stoppe printing again. New cartirdges as well.
  • bud706 Apr 05, 2009
    I have good cartridges in the printer and the black ink is very faint and i have to set the properties to best to get around this problem. Now the colors are very faded and i have sufficient color ink left.
    I have a 5500 (KMM7519323V24969LOKM) & if you look at the records, you will see that Kodak has replaaced the print head once already.
    Can you help?
    Bud Brown
    bud706@verizon.net
I had the same problem and it needed a new printhead. If you get a paperjam, after that it pretty much means a new printhead and I had the same deal with lettering missing. Email Kodak and tell them you need a new printhead.
Posted on Apr 03, 2009
    Sergeant:
  • Kodak Expert
  • 285 Answers
Please call 1.800.421.6699 to get a new printhead free of charge from Kodak. Please rate my solution as FIXYA as this is a common issue.
Posted on Feb 15, 2009
I have a Stylus CX 5000 with a new black ink cartrige and empty color cartriges. I only need black/white printed material. It won't print at all. What can I do to make it print just black and white...
Epson software does not permit printing when any of the cartridges are empty. It is a way to make sure you purchase more ink (It stinks, we all agree). They also use the color cartridges to make up black ink, then print the black over the top!! Again a way to make sure it uses more ink than it is supposed to.
Good thing is there are plenty of compatibles on the market that work very well and cost much less than Epson OEM's.
Sorry it is not the answer you are looking for.
Regards GM
Apr 07, 2011 | Epson Office Equipment & Supplies
Kodak esp 3 printer won't work
For that problem kindly try doing the ff:
  • Re-seat the inks both color and black then try printing
  • Re-seat the Printhead of the printer then print again
  • if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Aug 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
All cartriges have ink, still an error msg
have you tried not connecting to pc and running built in tests
Jul 30, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Cant print in black and white when out of a color.
disregaurd any prior solutions in cleaning any contacts. that model doesnt have an electrical contact to clean. there are little magnets inside each color and black cartrige that work off a float mechanisim inside each one. when the levels get low the magnet indicates to the printer it is empty. unfortunately for you this stylis model as with all brother model printers wont work even if the color your setting up in the properties or settings feature are set to black and the black is full. its the companies way of forcing you into buying new ink. be aware though that my brother catriges cost 78.00 for the 3 color and one black set. i found these cartriges online through ebay but with one more additional black cartrige for a total of 5 not for ,for a total cost of 13.11 with free shipping. sounds too good to be true but for 13.00 it was worth a try. i have now purchased several 5 packs from them and couldnt be happiere.
Jul 10, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Cartriges
Black - #94
Tri-color - #95 or #97 (#97 yields more pages)
Photo - #99
Thanks for using Fixya.
PS. Here is the page of available cartridges if in US. PSC1610 Ink
Jun 18, 2009 | HP PSC 1610 All-In-One InkJet Printer
Epson C82 & C84 Printers will not laydown any ink!
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
http://www.fixyourownprinter.com/kits/Epson/K89
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
Apr 10, 2008 | Epson Stylus C84 InkJet Printer
Nothing comes out when I print
Epson 777 will not print. No paper jam. Power light flashing; red error light on steady. Paper does not feed; if paper supply is placed deeper in feed, entire paper supply (about 12 sheets) feeds thru as one sheet normally would , without printing.
Feb 27, 2008 | Epson Stylus Color 777i InkJet Printer
RX500 EPSOM STYLUS PHOTO PRINTER Won't Print
I used some less expensive generic ink cartridges on my RX500 and had a similar experience with the black. If you're already using the Epson brand, done the head cleaning, realignment and nozzel checks, I'm not much help. Try Epson's support at their web site.
Mar 25, 2007 | Epson Stylus Photo RX500 Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
196 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
