Question about Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button...
Westinghouse Gold GD22DF, Blows circuit.
Unit has been working fine. Tryed to reset circuit, would not hold. Unpluged ref. citcuits holds, untill ref. pluged in, and iimmediately blows circuit.
    Guru:
  • 1,524 Answers
There are a variety of reasons this can be caused by. With the unit unplugged, remove back panel. Look for loose or burnt wires.
Posted on Apr 20, 2009
The router was working fine yesterday. I checked it today, and it isnt working anymore. I unpluged it, and plugged it back in, and no indication lights are illuminating. I have tried this several times and...
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds
Dec 16, 2010 | Belkin F5D8236-4 Router
Prolems with the power.
Try leaving it off and unplugged for a while then hold power button while pluging back in to reset. Most brands of tv's flash to display trouble code.
Mar 15, 2010 | Jwin JV-DTV3212 32 in. HD-Ready LCD...
Westinghouse 1080P 42" LCD TV - HDMI stopped working
I know this is late, but this happens frequently. If anyone else has the same problem try unplugging the TV for 60 seconds. Plug it back in and then hold the power button down for 30 seconds. That will reset the TV.
You should see the Westinghouse logo come up and the HDMI should work. This has happened twice with my TV in 1 year.
Apr 10, 2009 | Westinghouse TX-42F430S Television
Ink catridges want work
Try this to reset the unit:-
1) Disconnect power cable
2) Press # and 6
3) While holding buttons connect power cable
4) After you see a message on the screen release the buttons.
5) If you still get the error message, powercycle the unit.
6) You should get a message to select your country and language settings, when you see this reset should be completed.
You might have to try this a couple of times, others seemed to.
HP website link here for ref:-
http://h10025.www1.hp.com/ewfrf/wc/product?product=79477&lc=en&cc=us&dlc=en〈=en&cc=us
Jan 24, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Whirlpool Ref shuts down
It sounds like to me its your defrost timer(usually under 20.00) that is bad. Yhe are very inexspensive and easy to get to.You can purchase one AT YOUR LOCAL SEARS or online with your model # Glad to be of service
Jan 08, 2009 | Whirlpool Refrigerators
F60 Error message on DMR-ES40V unit
Unplug the unit.
Plug back in and wait till you see 000000.
Press and hold the power button in at least ten seconds or until the clock shows up.
This worked to fix mine.
Jan 05, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Froze
Hold the power button down and the UP volume botton at the same time to reboot it.
If that fails youll have to le t the battery die and recharge it, that will reset it.
Oct 02, 2007 | Philips HDD1630 MP3 Player
GARMIN c550 will not turn on
There is an ISSUE with the DEAD ZUMO, however some of the are solved, and some need to be shipped back.
There are a couple of options.
1) remove the battery, keep power button pressed for a few minutes. install battery, try.
2) fully recharge the battery with the wall charger, try
3) With a fully charged battery, press and hold the + button and press the power button(hard reset).
4) hold thumb firmly on top left of touch screen and hold power button till it switches on(hard reset).
5) Try a different battery (fully charged)
6) Ship it to Garmin
Sep 08, 2007 | Garmin zumo 550 GPS Receiver
My Sansa E250 Froze..
that happened to me once. all i had to do is hold down the power button for at least 15 seconds sometimes more. if not call tech support
Jan 07, 2007 | SanDisk Sansa e250 MP3 Player
Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button... Logo
179 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
