Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
My computer is not able to detect my handycam
Hi
i have a DCR-HC42 handycam. i am connecting my cam with the computer through usb cable but it is not detected by my computer.Please let me know the solution.
  • 2 more comments
  • DaenaHughes Feb 21, 2009
    I have windows vista and i dont have the first step guide cd rom so my computer's not recognising my camcorder. what do i do?
  • anth_seba Mar 14, 2009
    I have windows vista home premium. Do not have the First Step guide Cd rom. Not able to connect to my pc.
  • Anonymous Apr 03, 2009
    I have gone to menu - standard set, then the only thing i can see about USB says " USB-CAMERA" which i have set to USB STREAM. My computer now says new hardware detected but doesn't do anything else. I am using windows XP and have not installed the software that came woth the camera - do I need to do that? Also, the LCD screen has just gone black and only comes on when it is flat against the camera or almost closed.
  • Tim Babcock
    Tim Babcock May 11, 2010
    What software are you using for video editing?
  • 10,594 Answers
Please go to camera menu > settings and enable USB stream option so Windows will detect / recognize your camcorder.
Let me know if this not works to help you out.
Please intimate what Windows you are running in your PC?
Posted on Feb 14, 2009
Hi All, I have DCR-TRV238E Digital 8 Handycam... I want to transfer the recorded video to my computer... Can you please tell me where i can download the software to upload the video on to my computer...
All of pre-HDD cam does have FireWire port somewhere in it (or at the docking station in case of SONY's)
In order to capture the footage from the cam to your PC,you need the Firewire card and the cable.Should be available at any computer hardware store.All you have to do is to install the card to your PC,connect your cam to your computer via the cable,then capture the video by your favorite video editing software.
Yes,that sounds a bit more difficult than drag-and-drop work in USB-connection camera,but not too difficult to understand,of course.
Aug 07, 2010 | Sony Handycam DCR-TRV260 Digital Camcorder
Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
Mar 28, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
I can't copy from sony handycam mini DV to my computer. it is like the usb cable is not registering as an import option, even though i did the hardware installation
Check the connections. The plugs should be fully inserted in the handycam or its stand. If you are using the stand, then the camera should fit properly on it and the USB streaming switch should be at ON position.
If these are OK, then check the USB cable.
Probably you are aware that you have to use a USB 2.0 port in the PC. If your PC is old and has lower USB ports, then the picture will freeze many times and the import will not be of acceptable quality.
Oct 14, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
How to down load recorded caste from sony HC42E
if you have the usb connector, you can simply plug it in your computer and your computer will start recognizing the cam. follow the wizard so that you can download the vids from your cam.
Jan 25, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Import video from Sony handycam DCR-SR42 to computer
Does your camera having a docking station? If so, press the "burn to disc" button on the docking station, while the USB is connecting camera to computer.
Oct 27, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR HC42 Video Capturing
you should be using a firewire cable to transfer video from cam to comp-cable comes 4 pin to 6 or 4 pin to 4 pin use 4 x4 for laptop and 4 x 6 for tower-make sure comp has port-not usb which is only for stills-once cam is connected or before open movie maker in vista and it should work or connect cam and computer should recognize it
Jul 26, 2008 | Video Cameras
My computers do not recognize sony dcr-hc28 camcorder
Hi, I'm from the Philippines. I have the same handycam model. The first time I connected it to my PC (Windows XP) via firewire, nothing happened. It cannot detect my handycam. I returned the firewire card to the shop where I bought it. They tested it and the firewire card is ok but the firewire cable is defective so they replaced it. When I got home, I tested it again but still the handycam cannot be detected by my PC. I went online to find a solution and I came upon a solution that you need to attach/connect your charger to the handycam before you connect your handycam to your PC. It said that the handycam needs a steady supply of power to be able to connect to the PC. It sounded weird but I tried it and BINGO! The handycam got detected. I was able to capture my videos.
I also have a TV Tuner & Capture Card but when I capture videos thru the RF cables, the videos losses quality and videos are blurred. Thats the reason I bought a firewire card.
May 04, 2008 | Sony Handycam DCR-HC28 Mini DV Digital...
Problem with my handycam
I have a Sony Handy cam when I try to record on the screen it says "movie recording disabled" and I can't figure out to to fix it
Oct 06, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Connecting to computer
You should have got a sofware disc with the handycam when you bought it.if you load the disc it should accept the video on usb.if you dont have the disc try sonys website for software,.
May 15, 2007 | Sony Handycam DCR-HC36 Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
604 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
