Question about Fisher Audio Players & Recorders
How to connect
I need help with how to connect these components, wiring is my short coming. I have a fisher ca-276, fm-276, eq-276, cr-w854, mt-854, ad-834.
Any help very much needed.
Thank You
Jeff
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: i need manuals for hooking
I can't even find a reliable picture of the amp but it's not rocket science.
The Tuner output goes to, say, FM or Aux on the am, anything BUT Phono, which is ONLY for a turntable.
The EQ output goes to the first available Tape In; Input Comes from the same Tape Out. Select that tape function to engage it in line with any source and the downstream electronics (second tape, tone, volume, speakers).
The tape deck output goes to Tape In; Input comes from Tape Out. If there is not a second tape loop on the amp, nest the Tape Deck into the EQ's Tape loop. They always have at least one to replace the one they use. Select THAT tape function to engage it in line with any source and the downstream electronics.
Posted on Mar 13, 2011
How so i get a Fisher CA-854 amplifier to work without the remote control
Press the buttons on the unit. Which means getting up.
Sep 12, 2014 | Televison & Video
Do you have a owners manual for a fisher CA-276 stereo amp?
The owners manual can be found here :
http://www.hifiengine.com/manual_library/fisher/ca-276.shtml
Aug 30, 2014 | Audio Players & Recorders
Fisher equalizer-2322
"Rec" is considered a send (output from Fisher to an external device) and PB (playback) would be an input from external devices in to the Fisher. Remember all outs feed in's, and all in's feed outs...output from Fisher (Rec) IN to EQ. Out of EQ in to Fisher (PB). A quick test is to simply jumper the out to the in and check Fisher for proper operation. Also, in these modes you MUST press the "Tape Monitor" button for the audio signal to be routed through this In/Out loop.
Dec 12, 2013 | Fisher Vintage Ca-880 Integrated Amp...
Fisher equalizer 2322
"Rec" is a send (output from Fisher to an external device) and PB (playback) is a input from external devices in to the Fisher. Remember all outs feed in's, and all in's feed outs...output from Fisher (Rec) IN to EQ. Out of EQ in to Fisher (PB). A quick test is to simply jumper the out to the in and check Fisher for proper operation. Also, in these modes you MUST press the "Tape Monitor" button for the audio signal to be routed through this In/Out loop.
I have a Fisher stereo.The amp is a ca871 the eq is a ca871 the casset deck is a crw870. How do I connect these components up.
The amp has tape rc out and pb. The eq has line in, line out, tape rec out, tape pb. The casset deck has line in,line out.
Ok, hook the amps RC OUT to the eq's LINE IN.
amps RC Pb to the eq's LINE OUT.
The tape's LINE OUT to the eqs TAPE PB
the tapes LINE IN to the EQs TAPE REC OUT.
on the eq, there should be a button to toggle between tape and source.
let me know if that works.
Jul 01, 2011 | Audio Players & Recorders
I have a Fisher CA-871 and all componets, I misplaced the hookup digram for the amp to all componets. The problem i have is only the EQ-871 to CR-W870 and also to tape deck. I hope you can help Thank...
if you visit the link below you will find hookup diagram for your need..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
How do I wire my equalizer into my audio system?
http://installationsplus.com/docrepair/hookup.html
Jun 23, 2011 | Audio Players & Recorders
I need manuals for hooking up my fisher stereo system model ca 871 amp fm 871 tuner cr-w890 tape deck eq 867 eq can not find manuals
Mar 13, 2011 | Audio Players & Recorders
Need help connecting my eq to my system.
You will want to connect all of your devices to the pre-amp or receiver, then connect the outputs of your pre-amp/receiver to the inputs of the EQ. Then connect the outputs of the EQ to the inputs on the amplifier or receiver. If you give me some model numbers, I would be able to tell you exactly which cables go where.
Mar 31, 2009 | Audio Players & Recorders
How to connect the FISHER EQ-273 equalizer to the FISHER CA-885
It goes between whatever you are using to create the sound and the input to the amplifier.
e.g. for a standard HiFi.. HiFi aux out to equalizer input... equalizer output to amplifier aux input.
Trying to keep left and right channels the same through out. They are usually colour coded. Red = right Left = white.
Hope that helps.
We all start somewhere
Mar 18, 2009 | Audio Players & Recorders
64 people viewed this question
Top Fisher Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
SHARCNET-USA
SHARCNET-USA
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
