Question about Hotpoint Dryers
Hotpoint Aquarius VTD 00 Tumble dryer no heat
Hi, it tumbles well but there is no heat at all on either setting (hi /low). Checked the filter which was packed solid. Cleaned it out but still no heat, Im assuming the thermostat has tripped but don't know where it is or if it can be reset. Help needed and thanks in advance.
  • keithrobi970 Feb 16, 2009
    Thanks a lot amgm. Worked straight away .
  • 32 Answers
Hi, it sounds like the reset stat gone on your vented drier. Remove the back cover, where the element is, and you should find two stats, one with a green spot. That's your reset stat. If you have a multimeter, turn it to buzzer and check the stat by touching the connections with the meter leads. If there's no buzzing, it's the reset stat. also check if the dark side of the stat is pushed inside. Remove the stat and hold it about 20inches from the floor. Drop it on the floor and the dark side will become flat. Repeat as many times as necessary. GUARANTEED TO WORK. Put everything back and that's it.
Cheers
Posted on Feb 15, 2009
Hotpoint Aquarius tvm560 tumble dryer is blowing cold Air can it be fixed
sure it can., check ur heating element, with multimeter, and check ur thermostats the hi-lo the thermal cut off , cycling thermostat, etc.
Jan 28, 2015 | Hotpoint Dryers
Hotpoint TVF760 Aquarius + change belt
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. 9 rib stretch tumble dryer drive belt Contitech 144001958 9PHE 1860 How...
Aug 06, 2013 | Dryers
Hi I've Got A Hotpoint Aquarius CTD40 Tumble Dryer
that isn't a model number,open the door to the dryer,look around the opening where you put the clothes in and send the full model number,
Dec 21, 2017 | Hotpoint Dryers
My Hotpoint VTD00 tumble dryer is making an unbearably loud vibrating noise. It seems to be coming from the back of the machine.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 10, 2011 | Hotpoint Dryers
CLEAN FILTER LIGHT REMAINS ON ALL THE TIME, I HAVE CLEANED FILTER, PROBLEM STILL PERSISTS. i HAVE ALSO CHANGED THE DOOR CATCH AS THIS APPEARED DIFFICULT TO CLOSE.
Hi, My Hotpoint Aquarius TCD32 0771200901
Tumble dryer stopped working, first a filter care light, so cleaned the filter and now the light comes on but nothing happens. Any ideas? Thanks
Dec 17, 2010 | Hotpoint TDC32 Electric Dryer
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Dryer wont heat up on a aquarius VTD00, do you think its the element
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. . Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter. Also overloading and blocked filters can lead to thermo cut out, it is best to check your manual and call someone out on this occasion. You may even have a red reset button on the rear of your machine some models do, if yours doesnt then call out engineer :)
Jul 19, 2009 | Hotpoint NWXR473EV Dryer
Can anyone tell me how to replace the heating elememnt on tumble
open back pay attetion to where you take the old one off just streach it out around the clips
Feb 17, 2009 | Hotpoint NWXR473EV Dryer
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Dryers Logo
394 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
