Question about Kodak EasyShare C875 Digital Camera
No it doesn't work
It says on my camera the error #e45 see user's guide and i bash it and check my lens thing and it did work thanks for nothing
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
Como corregir un errror E45 en una kodak V570
The bad news is that this error means the lens alignment of your camera is messed up and it will take repair service to fix it. The cost of this might be equivalent to replacing the camera.
kodak-easyshare-v570-error-e45-users-guide.
Jul 28, 2011 | Kodak EasyShare V570 Digital Camera
Camera error E45
this may be due to some sand or big dust particles stuck in lens assembly
try cleaning the assembly
have you tried a hard reset?
Oct 06, 2008 | Kodak EasyShare LS443 Digital Camera
Error # E45
try to remove the camera battery, for a while & put it back on...
let me know again
Jun 14, 2008 | Kodak EasyShare CX6330 Digital Camera
I have the Kodak EasyShare V530 and every time i turn it on it gives me a message that says "camera error #E45 see user's guide" then it turns off. Unfortunately i dont have my user's guide. Is...
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=21cc7420d5ae338b61a176f16d1146f3&modelid=200385&q=Kodak+V530
Here is the link to download your manual.
The error code indicates that there is a stuck lens issue.
Check to see if any foriegn matter...i.e. dirt, has gotten into where the zoom lens opens out at. That is more than likely the point that is causing this error.
Jan 18, 2011 | Cameras
WHAT DO I DO WHEN MY KODAK EASYSHARE CAMERA SAYS ERROR E45
The bad news is that this means the lens alignment of your camera is messed up (lens jam) and it will take repair service to fix it.Some brave ones have been able to clear the lens jam by bashing the camera bottom against a desktop. This might as well damage the camera beyond repair, so try carefully first.
Aug 07, 2010 | Cameras
Camera error #e45 kodak digital camera v610
Hello :
This means the lens alignment of your camera is messed up and it will take repair service to fix it. The cost of this might be equivalent to replacing the camera- Better to call KODAK and see what they're willing to do for you.
Not supported solution is to smack the side of the camera . That helped some people with the same error .
Please read this useful link carefully : Kodak cam errors forum
I hope this will help .
please don't forget to rate !
Apr 06, 2010 | Kodak EasyShare V610 Digital Camera
When i swich on it says camera error ''E45 see users guide.
E45 error code indicates the lens of your camera is already defectived. You need to contact Kodak at 1 800 235 6325 ext 12. Your camera needs repair
Feb 03, 2010 | Kodak EasyShare Z700 Digital Camera
I have kodak ls443 get error message camera error e45 and it says see users guide. i have looked in users guide but cannot find andy info re error e45
Hello
Firstly, at the link below you can download a updated softcopy of the manual for free.
http://www.retrevo.com/s/Kodak-LS443-Digital-Cameras-review-manual/id/200dj378/t/1-2/
As for the error code you are getting, "error 45" is a lens related problem of LS443.
If the lens is not stuck, you may try to download the firmware from the Kodak site and update the one in your camera.
As the lens is already stuck, there is no choice except to send the camera back to Kodak for servicing.
Hope this can steer you in the right direction.
Kind regards
Andrea
Dec 23, 2009 | Kodak EasyShare LS443 Digital Camera
Camera error # e45
If it is under warranty i advice you give it for service as this is a pretty complicated procedure to get it fixed.
This error is caused due to the failure of lens alignment system.Try following the procedure below..
it may be the lens contacts or grit in the gears
open it up on the side of the lens you will see a row of thin gold coloured contacts that report the lens position back to the cpu sometimes these get dirty or bent.on the side of the lens is a motor, look where the gear meets the lens and use a pin to flip out any grit that is stuck in the teeth.
Its very unlikely the lens is "out of alignment" this just cant happen unless its been dropped or bashed, in which case it may be broken.
Also i have heard some people bashing the camera a couple of times to get it working..
hold the camera and bash the edge next to the lens against the palm of you hand as hard as you can, one I did have to get a little more medieval on and bashed aginst a bit of carpet on the bench.. but it worked... might be worth a go if the next step is the bin...
Nov 01, 2007 | Kodak EasyShare C875 Digital Camera
Camera error # 45
Dec 26, 2006 | Kodak EasyShare CX7530 Digital Camera
Kodak EasyShare C875 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
