Question about HP Pavilion dv9000z Notebook
My usb port does not respond on my HP laptop
When I plug anything into the USB port on my laptop there is no recognition that a device has been plugged in.
    Scholar:
  • 51 Answers
Hello there.
I understand that you are unable to use the USB port of your computer.
To isolate the issue try performing these steps.
1) Check whether the device is working fine.
2) Check with other USB ports to the same Notebook.
3) If these steps do not work then you can do this.
a) If your Notebook is under warranty you can send it to free repair ( Contact HP.com for more information)
b) If it is not under warranty then check for the repair cost from HP.com chat support.
Posted on Feb 15, 2009
A USB device has exceeded the power limits of its hub port
If you get an error message"Insufficient power to operate USB device" when you plug a USB deviceinto the computer's USB port, then this device is drawing excessive currentthat the USB port cannot supply. In case such as this, youneed to purchased a powered USB hub and connect this hub into the computer'sUSB port and then connect the USB device into this powered USB hub.
Mar 11, 2011 | HP Compaq nx6110 PC Laptop
HP Pavilion zv6000: USB ports are inop. USB port on rear of computer works fine. USB port on left/front will power my flash drive, but the light stays on constantly. The flash drive is does NOT show up in...
After reading the description, I think you need to try updating BIOS and latest device drivers for USB. Because USB are getting power on that means there would not be any fault to from the motherboard.
So please try updating latest BIOS for your notebook.
If you can provide me the product no for your notebook and the operating system which you are using currently then I can find the one for you.
Otherwise you can also do the same.
Type in the product no. on www.hp.com. Then go to software and driver download page, select the proper OS and search in BIOS ROM pack available for your notebook.
I hope this will help.
Jun 11, 2010 | HP Pavillion ZV6000 Notebook
Hp pavilion dv4000 usb port can't use
This error occures when a USB device draws more power than the USB port can supply.
To fix this problem, purchase a powered USB hub. Power up the hub and connect it to the laptop's USB port and then plug the USB device into the powered USB hub.
May 05, 2009 | HP Pavilion dv4000 Notebook
My averatec series 3200 notebook cant detect my usb device
The flash disk could be faulty, especially when it draws too much power, and this will cause the USB ports to shut down and the other USB devices won't work until the faulty device is removed.
Mar 11, 2009 | Averatec 3200 Notebook
Usb ports
  • The driver for the device is faulty. When you plug in a USB device, the computer should load and then configure the device without ever requesting a device driver. If the computer prompts you for a device driver, check the information that came with the device or go to the manufacturer's website to see if a driver is available.
  • The USB port might be defective. If the USB device is connected to a defective port, the device will not work. Try plugging the device into a different port. If all the USB ports are being used, unplug a device that you know works, and then plug the problem device into the port that device was using.
    If the device is plugged into a secondary USB hub with other USB devices, unplug the device from the hub, and then plug the device directly into a port on your computer.
  • Other USB devices might be drawing too much power from the hub. The device you are trying to use might require all the available power or bandwidth that your computer can provide. If other USB devices are connected to the computer and are drawing power from it, the first device might not work. If any other devices are drawing power from the hub, try disconnecting them, and then see if your device works. If this solves the problem, you might want to obtain a USB hub with its own power supply so that you have adequate power for all devices.
  • Oct 23, 2008 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
    CL51-15 USB Port Problem
    I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
    Kevin S.A.
    Sep 26, 2008 | ASI CL51-15 Notebook
    Usb ports
    You'll want to verify your computer recognizes your usb ports.
    In device manager, look to see that you don't have anything with an exclamation mark, question mark, or red X on it. Make sure you have the usb ports listed under Universal Serial Bus controllers. If nothing shows, your usb ports may be dead. Depends on the age of your computer and what might have happened to them.
    Device manager- right-click My Computer and go to properties, then select the hardware tab.
    Jan 28, 2008 | Acer TravelMate 2300 Notebook
    USB Port Recognition
    You must Look on your Desktop Locate
    My Computer
    Right click on My computer
    click on Properties
    Go to the Hardware tab
    Click on Device Manager
    Locate your USB Ports which are probably at the bottom of that list
    If there is an X over the USB Connections you must right click to enable them
    The other solution is to plug up the device and follow the above steps
    I sensing that this device did not have drivers that were downloaded to your system.
    The other thing is try to plug the device into another computer to see if it is reocginized by the other computer. If it is reocognized you know it is not the device. It is software related
    Nov 20, 2007 | Acer Aspire 3680 Laptop
    HP Pavilion dv9000z Notebook Logo
    97 people viewed this question
    Top HP Computers & Internet Experts
    Brian Sullivan
    Brian Sullivan
    joecoolvette
    joecoolvette
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
