Question about Boss Klash K780 Car Audio Amplifier
Boss amp turns off sometimes
My boss klash k680 amp turns on but no sound comes on then i mshake it around and it works sometimes then sound goes away when its playing
    President:
  • 624 Answers
There must be some bad solder connections in the amp. You will need a soldering iron and some solder. Plus the skill to use them so you do not cause much more damage to the amp. It is very easy to bridge a solder joint to a close by solder joint and cause a short in the circuit and can be very danergous, even cause the amp to catch fire. If you bridge any solder joints and then power the amp on, you may very well destroy the amp beyond being able to repair it by anybody. So if you are not sure of how good you may be able to solder the board, please just take it to a service center and have them check it out for you. If it is just some broken solder connections they should be able to repair it fairly cheap. Most shops charge about $65 for this type of repair, but not all repair shjops are priced the same, so you would need to check it out first.
It is very common, for car audio especially, to get cracked or broken solder joints due to the nature of them. They get bounced around a bit even when installed properly. Every time you hit a bump in the road the amp gets a little jolt.
If your amp had anything else besides the bad connections, it would not play OK after shaking it.
If you need any further help let me know.
Posted on Feb 14, 2009
BOSS AUDIO SYSTEMS SE950 Car Audio Amplifier: I have a SE950 boss amp, hooked to 2 audiobahn 12"...
Sounds like you are over working this amp for sure.. Upgrading your power wire & battery might help, check your gain level on your amp to. This is not the volume for the amp. Its to get both amp and the cd player on the same page... And most of all if your subs are wired up to .5 ohm stable, see if your amp do the same... My answer to this ?? Upgrade your amp, Boss audio was never a good company to me, but that is my opinon. Audiobahn set up all the way..
May 16, 2010 | Boss AUDIO SYSTEMS SE950 Car Audio...
Subwoofers Creating Independent Noise
Sounds like your RCA's are near your power & ground wires. I would run your RCA''s on the other side or as far away from the power wire as possibly. Sounds like your getting the infamous alternator whine. If none of the above work you can get a in line noise filter to filter out that noise. RCA's can pick up noise when their around anything that has alot of current running through it....Hope this helps
Mar 28, 2010 | Boss AUDIO SYSTEMS D13002 Car Audio...
Boss bass 600 Amp comes on but does not have sound
yes and also moisture. i have had plenty of amps die like this on me! needs repair
Jan 06, 2010 | Boss AUDIO SYSTEMS BASS600 Car Audio...
Metal Pedal mutes my guitar.
Sell the pedal and get a digitech, or convert it into a looper pedal.
Apr 05, 2009 | Boss Mt 2 Metal Zone Effects Pedal
Boss BA-2900 car amp doesnt produce any sound
i have come across a similar problem before. if you are using the ceramic (glass, clear) fuses the solder in the end caps sometimes melts. you will not see the fuse blown, but the fuse may still be bad. try a new fuse to see if that works. also make sure no single stray strands of wire from a positive or negative wire are touching on the terminals on the amp. i hope this helps. ill keep thinking of other things in the meantime
Jan 05, 2009 | Boss Car Audio & Video
Klash drive will not fill
What is a klash drive? Are you thinking of, as Smithbrother asks, a flash drive or thumb drive?
If you are, most don't hold exactly the amount they say are. For example, a 1 gigabyte flash drive will hold somewhere around 950 or 965 megabytes, a little less than the drive is listed as. That's common. If you're using a small flash drive (and that's what you're referring to), a 1 or 2 gigabyte flash drive costs as little as $12 to $16 dollars, sometimes half that price. If you're using a small size drive, consider getting a larger one.
Let me know if this answers your question.
XMinusOne@gmail.com
Dec 10, 2008 | Computers & Internet
Sound comes on, goes away
it needs to be checked for faulty solders if you dont know how to do this take it to a tech
Jan 29, 2008 | Jensen XA2150 Car Audio Amplifier
HDTV Rear Projection
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
Apr 01, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Boss Klash K780 Car Audio Amplifier Logo
245 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Jerry Umali
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
