Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Ecspecialist filters\shooter.exe i get this message after i on the laptop that find the file c:\programme\ Ecspecialist filters\shooter.exe please ftell me how to fix this problem and how to download this file back
  • 8 more comments
  • syednurulla Feb 16, 2009
    i am having the same problem. when i am strating pc i am getting this message c:\program files\ECSpecialistTFilter\shooter.exe
  • asdf178 Feb 21, 2009
    i HAVE THE SAME problem...It is pissing me offfff
  • thatbrowncow Feb 25, 2009
    Ratheeshgdn got the solution spot on! great job buddy, thanks a lot! was really starting to get pissed off with that message on start up. anyone know what might have caused it so i can avoid it in the future?
  • Anonymous Mar 17, 2009
    Same problem when i on my laptop. What to do?
  • ashrafk Mar 24, 2009
    shooter.exe missing
  • fahd abdulla Apr 11, 2009
    i get this message after i on the Computer that find the file: Windows cannot find ""c:\Program Files\ECSpecialist T filter\Shooter.exe"". Make sure typed the name correctly, and then try agian. To search for a file, click the start button, and then click Search.
  • astrozeek Apr 26, 2009
    i cant find the file shooter.exe that is named "shell"
  • shanu_852003 May 06, 2009
  • ahadak May 17, 2009
  • sagar7389 Dec 22, 2009
    thanx a lot ratheeshgdn it really worked..
Hi,  Please follow the steps:
Go to Start-->run, type..regedit Go to Edit-->find shooter.exe , press F3 until you find this entry named as "shell" c:\Program files\Ecspecialist...\shooter.exe right click-->delete
Posted on Feb 21, 2009
  • jim_pillay Jan 12, 2011
    Thank you so much. It works perfectly. Jimmy
  • 61 Answers
Try to update antivirus and scan your pc.
Posted on Feb 16, 2009
I get this message after i on the laptop that find the file c:\programme\ Ecspecialist filters\shooter.exe please ftell me how to fix this problem and how to download
Posted on Feb 09, 2011
How do I use a program ive just downloaded on this laptop
Hi
Usually the files you download for programmes are ".exe" or ".zip" files. In the case of ".exe" files they are either executable, in which case you need to double click on them and follow the instructions to install the programme, or they are self-extracting zip files where you again double click on the programme, it will ask you where you want the files expanded to, and once expanded you need to find the "Setup.exe" file and double click to install the programme. ".zip" files you have to expand manually and then double click the Setup.exe" file to install the programme.
Incidentally you must have administrator rights to install programmes, if you are a standard user, most likely, then you must either run the programmes as administrator (right click on the file and click "Run as Administrator" in the menu that comes up) or log off and log on as an Administrator with appropriate password.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 29, 2014 | ASUS X53E-RS52 15.6" Laptop Computer,...
Missing of Ecspecialist filters\shooter.exe file
Press Win-key + r
A Run Dialog will appear, write msconfig
An other dialog will appear, With many tabs.. Like System, SYSTEM.INI...you will also see Startup, > go there.
Then you will see a list of programs that auto-start, when you Notebook loads the Windows.
In the list locate the Program you are stating and Uncheck it.
Restart your Notebook.
Hopefully, now there will be no message.
Sep 09, 2009 | Computers & Internet
On startup getting c:\..\shooter.exe not found error
goto start>run>type msconfig .. then goto startup tab and there uncheck shooter.exe..
then let me know ...
Sep 05, 2009 | Microsoft Windows XP Professional With...
Shotter..exe problem
Aug 31, 2009 | Microsoft Windows XP Professional
ECspecialist T filter shooter.exe
What is your problem exactly? What is wrong with the file shooter.exe?
Ryan Frame
Creative Energy Associates Technical Center
Aug 17, 2009 | Microsoft Windows XP Professional With...
Cannot find shooter.exe
Sounds like a Malware message. Boot your computer to the desktop, or if you are unable, boot to Safe Mode (F8). Download, install and run MalwareBytes (MalwareBytes.com). Hope that helps.
Jul 23, 2009 | Microsoft Windows XP Professional With...
After booting pc it popup and gives errorlike
goto start/run and type msconfig and nagivate to start-up tab , then select enable all or disable the one which has shooter.exe , apply and restart. your problem will be solved...
Jul 04, 2009 | Microsoft Windows XP Professional With...
I recieved error with the shooter.exe
Go to control panel->add/remove programs.
Check the list.
Find ur entry.
If its there, click on it and select remove or change or repair if its available.
If there is remove only, click on it.
There may be a repair option.
If so click on it and it will start repairing it. Make sure u have insert the CD.
If it cannot be repaired like that, you can remove.
I can give further detail but I don't know whether this is a program or a Virus.
Thanks
Please kindly rate the answer if its helpful to u
Good Luck.
Jun 27, 2009 | Microsoft Windows XP Professional
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
2,701 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
