Question about 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
When i arm the car how can i hear the sound viper on
How can i hear the sound viper on or viper off when i arm or disarm the alarm?
  • 95 Answers
Whats the make and model fo the alarm? and go to viper.com/support for more information
Posted on Feb 16, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Car does not arm or disarm when door opened alarm goes off
Hi, I love the viper. Mine worked flawlessly for many years until one time my unit would not arm or disarm. Obviously 1st I checked batteries which were good. I took mine to installer and they said I had a remote go bad. He got me new remote and that was it. Sometimes I wonder if somehow I managed to hit a factory reset sequence on my remote. Considering your also having an issue with door contacts as well, I would hope it's not the main unit. My system also had a special override switch in the footwell, if you have one, perhaps you may have switched accidentally. Hope this helps in troubleshooting.
Dec 18, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Can't disarm even with toggle switch
ususally this happens when the alarm dosent read the door being open, if the alarm dosent read that the door is open you should be grounding out the door trigger (green wire in most alarms) and repeat steps to deactivate the alarm
Nov 15, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Why I do not hear the siren chirp when arming and disarming?
Sounds like your alarm is set up for "Silent Arming" for when you dont want to wake up neighbors, kids etc. scroll thru your setup menu and see if silent arming is engaged, if so disengage.If you need more help email me avpowerstn@qnet.com (Jim)
Apr 29, 2012 | Viper Security and Remote Start System...
Hi. I have a Viper 5701 alarm in my car. Arm and disarm goes very well with the control unit. But I cannot programming to pasive arming, always have to use de button in remote control to works. Is ther a...
Open door, turn ignition on then off. Press aand hold programming button until you hear one chirp. After you hear the chirp, release programming button, press and release button one then press and hold. You will hear one chirp. While holding the programming button, press lock button on remote to change option. One chirp is active arming(what you currently have), Two chirps is passive arming without locks, Three chirps is passive arming with locks. Turn ignition on to exit programming. Test system.
Jun 13, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
When i arm and dis arm system i get error beep?
Hit f and then unlock
You may have lock out the remotes. If that doesn't work DEI has a one yr gurantee on remotes. In your box there should be a registration card. Call them.
Jan 26, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5901, Ford 2008 6.4/ When I use the trucks door keypad
If you use the viper remote to arm the alarm, you MUST use the viper remote to disarm the alrm prior to opening the door. The only REAL solution is to add the keyless entry feature to the viper system, and quit using hte factory remote all together.
Aug 09, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
May 10, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
VIPER 5701 GOES OFF ON ITS OWN
this is a EASY FIX.... if the car has a factory alarm installed, then the installer never connected the OEM disarm wire. its a LIGHT GREEN/BLACK wire connected to the H2 harness. just have them connect that and youre problem will go away .
JOSEPH GARCIA BEST BUY CERT M.E.C.P INSTALLER
Mar 24, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I cant disarm my alarm
Get inside the car, turn the key to the on position, the alarm is going to sound so do not panic when the alarm sounds press the valet button one time and the alarm should stop. To place the alarm in valet mode cycle the key with the door open on then off then press the valet button one time and the alarm should go into valet mode meaning the alarm light will be on steady.
Feb 03, 2009 | Viper Security and Remote Start System...
Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
Dec 12, 2007 | Viper (VGC421) Remote Control
5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
767 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
