Question about Frigidaire Affinity ATF8000FS
Grey gasket around door is releasing a gray powder
We have a Kenmore fron loader Model 417.440522400. We have found a gray powder on and under the gray gasket that surrounds the door. When run finger over the gray plastic it feels like a powder is coming off of the plastic. It is still soft to the touch so not obviously dried out as yet. We have kept it dry and no mildew or other staining is seen. There have not been any noticeable water leaks as yet, but do not want gray powder on clothes but want them clean. Any one else with this problem. Purchased in February 2006 so probable not under warranty but maybe a recall that we were not notified about?
  • jvgaleza May 11, 2010
    No luck with a solution we will call Sears on Monday. By the Way look again at original text. My problem is with a front loading Kenmore washer Model 417.440522400. I do not know how to change to show the correct appliance however I did try.
5 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: Clothes smell like mildew
HI thanks for your question. My solution is 1 cup of vinegar, per wash load. In time, will solve your problem.thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
dblred
  • 68 Answers
SOURCE: The gray rubber seal on the door and opening of my
at this point, all you can do is replace the door boot seal. but you can prevent it from happening agin by leaving the door open a little when it is not in use to allow air in the tub. if you dont, youll have another moldy boot
Posted on May 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have an Affinity Front loading washer model
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Posted on Sep 28, 2010
  • 170 Answers
SOURCE: Lots of mold around rubber
Use a s.o.s pad to remove mold there will still be staining but it will gey the bulk of.Now to get rid of the smell ( this has been a mixture I have used for about ten yers works every time) put the washer on hot heavy wash start when done filling drain what you want to do is make sure the water is the hottest it can be. now start washer again on hot wash when you see water in bottom of tub stop machine to open door ADD two cups of dish washing power( brand does not matter I tell most people to buy cheap stuff at walmart) start machine let it run till you see powder disolve then stop washer and add 1 cup bleach. let unit go through complete cycle..If your washer has a clean cycle use that instead of the heavy or normal cycle. The most I ever had to do this treatment was 2 cycles and it worked every time.Note all front load washers the door must be left open to pervent odor/bellows should be wiped clean after each use/and a good cleaning at least once a month. anyhow if this helped please vote if you need more help please ask
NOTE the dish soap is the stuff for a dish washer
Posted on Feb 10, 2011
Kenmore washer mold smell issue
front loader of top loader? For front loaders you need to dry around the front gasket and leave the door open 24 hours after each wash.
Put a couple of towels in the machine and add a full box of Arm and Hammer Baking Soda and do a 90' boil wash. Clean towels and the smell gone.
Jul 17, 2016 | Kenmore Washing Machines
There is a permanent smell which taints the clothes. How do I get rid of it
is it a front loader? Do you keep the door to the washer closed? You may need to sanitize the door gasket as well as the drum
Sep 14, 2014 | Creda IWD12 Front Load Washer / Dryer
I have an Amana Tandem 7300 and when it cycles, gray powder is everywhere and some of our clothes have been ripped up while being washed. Please tell me this is an easy fix which I can do myself!!
I have the same problem with my 7300. The grey material is actually the door gasket being rubbed and abraded away. Mine finally wore through the gasket entirely and had to be replaced. I have yet to find out why, or find anyone who knows why.
Jan 03, 2012 | Amana FXDX - FXDXI Dyna Super Glide Sport...
WASHER IS LEAKING FROM THE BOTTOM MIDDLE OF THE DOOR. IS THIS THE GRAY GASKET OR A PROBLEM WITH THE DOOR ITSELF?
If your front loader is leaking, the following link explains how to access and insprect the interior to accurately determine the cause:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
If discover that you need to replace the door bellow (gray rubber seal), the following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need. If the model number you have this question listed under is correct, the part number you need is 8182119. The bellow is listed as item 5 under the "Door and Latch Parts" section.
NOTE: Although the bellow DOES wear out with age and can develop holes, overloading the washer can contribute to the premature wear and tear on these seals. Please follow your owner's manual recommended loading procedures.
If you have any questions about this repair, or need additional assistance, please post and let me know. I hope this helps you.
Mar 18, 2010 | Kenmore Elite 45986 Front Load Washer
Where do I find the serial number/ model number on my front loader?
If this is a Kenmore front loader, the serial number is on a nameplate tag around the door opening along with the model number. You need to open the door to see it. I hope this helps you.
Feb 04, 2010 | Kenmore 44072 Front Load Washer
E20
the door won't lock, then i broke the grey thing that the door prong or latch locks into by slaming the door. its a little plastic grey hole hole. i don't see what holds the grey plastic thing in the hole. or how to order it. can you help. ? but the door wouldn't lock before that, i think the 3 and 4 year old kids play hanging on the door. how do you fix it. 2006 afinity fron loader washer. thank you. cheryl
Oct 24, 2008 | Frigidaire ATF6000ES Front Load Washer
Model: WBVH5200J2WW
call for service it is cover under warranty... all front loaders have a door gasket and all of them get holes in them...
Sep 02, 2008 | GE Energy Star WCVH6260F Front Load Washer
New Bosch water not draining
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Apr 01, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Black stuff in the bottom of the dishwasher
That black or gray stuff you're talking about is actually a combination of old food particles and soap deposits. The stuff builds up in the corners of the lower front areas of the tub and right under the inside of the door where it closes over the tub front. These areas can develop "scungy" deposits because these are areas that the dishwasher doesn't always clean and/or water remains pooled. A little routine cleaning about once a week around the bottom lip of the door and the door gasket with a damp sponge will prevent this build up. Hope this helps you.
May 11, 2007 | Whirlpool 24 in. DU920PW Built-In...
Frigidaire Affinity ATF8000FS Logo
75 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
