Question about Acer Aspire 9300 Notebook
Acer 9300 bios upgrade failed
I downloaded the acer BIOS winflash to do BIOS upgrade on my acer 9300. now my 9300 won't start.
when power up, i saw two green flash on the hd symbol and a flash on the CD, then a pause and the flash repeat again.
Look like it's in a fail safe mode, and it's trying to detect anything in the cd for it to read.
Have anyone ran into this problem? and how did you solved it? Thanks in advance.
Tony
  • 1 more comment
  • rustygoat Apr 01, 2009
    zerocool, i have same probelm as you, what version bios did u downgrade to
    i'm on version 1.06
    thanks
  • LeeG45 Apr 17, 2009
    Zerocool411,
    Wow - THANK YOU for your post!! I was upgrading my Acer 9300 from XP to Vista and about half way through it said my BIOS was needed to be upgraded, so I went to the Acer support site and downloaded the newest BIOS, ran the install exactly as instructions, but when the system went into reboot, it would not restart. I was sure the BIOS upgrade went sour. Tried everything I could find online, but nothing worked. Then I found your post this morning and thought - I have 4GB RAM also - surely it couldn't be that simple??? Well, I reinstalled my old RAM modules, 512MB x 2 for the original 1GB of RAM, and presto - the system restarted like nothing was wrong! Now I have to figure out how to increase the memory over the 1GB for Vista.
    Thanks again!
    Lee
  • Anonymous May 02, 2009
    I have the same problems, no boot or bios and black display, just power-light and HD light are on.
    Is the vga-inverter dead?
    Ritser
Hi!
I have the same problem, and my problem was that I have installed 4GB ram and that ram modules wasn't accepted with the new bios. So I installed the old modules and it all worked again, downgraded the bios to one version older and installed my 4GB ram modules and it all worked.
Hope that's your problem too.
Good luck
Posted on Feb 17, 2009
I have acer aspire 9300, the first time it went to black screen i tried all my posible means but i couldn't. then i gave it to my friend for try. he did it by heating the vga chip with a dryer followed by power up with the adopter then connect the battery 3x whiles the machine light is on. power off connect your battery, note: when it happens again remove the battery and power on with the adapter if not 1. power on without ram and battery then 2. connect ram and power on; All is well for u
Posted on Aug 12, 2011
Hi...
Same exact issue... Customer brought in thier computer and said his son was on it and it just went black... However I believe it was not booting up after they did updates to is to include the bios. I tried the suggested above and put in some old 512 ram and bingo we screen again. Kudos to ACER on thier bios upgrade ;)
Posted on Jul 14, 2010
Recovering bios on acer desktop motherboard
Make sure your computer is off. try resetting the CMOS look on your motherboard and find what looks like a big watch battery about the size of a nickle take that out and leave it out for about 30 minutes and put it back in, that will reset BIOS back to default settings this should solve the problem if it doesn't you have problems elsewhere
Jun 23, 2013 | Acer Veriton 3600G PC Desktop
Acer aspire 5349 won't boot
I had the same problem. I clicked on F2. in Bios screen I press f10 (save and exit), and windows started.
Apr 02, 2012 | Acer Aspire 9300-5349 Notebook
I want to flash the bios of my liptop acer aspire 9300,how to do?
You can find the Bios and the information on the ACER support site:
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=135
Aug 13, 2011 | Acer Aspire 9300 Notebook
In order to allow the two new 1G RAM to work with the two Acer originals to work, I was advised to update the BIOS. The two new 1G RAMs work O.K. on their own but not with the two 512M Acer originals...
here's what do download hirens boot cd from this site hirens bootcd
then unpack this one using you regular packing software and burn the iso using the batch file provided on the hirens folder and presto you have a bootable cd utility that has a uniflasher pre installed already.. then you can flash the bios easily. hope this helps
Feb 10, 2010 | Acer Aspire T180 PC Desktop
The exact same thing happened when I did a bios update on my acer
sorry to say this but you have to replace your PC's motherboard. flashing the bios is one big mistake that i learned from. also i think that's not covered by the warranty.
Sep 10, 2009 | Acer Aspireā„¢ T180 PC Desktop
My Aspire 9300 no work anything
Did you recently change or add memory? My 9300 will not recognize 4GB RAM after I upgraded the BIOS to version 1.2, so I use only 2GB and it works ok again.
Apr 27, 2009 | Acer Aspire 9300 Notebook
Can't upgrade an Acer Aspire 3000 notebook to 2 gb
Thanks for choosing fixya.com
Your not alone in this type of problem. When it comes to computer (laptop especially) they usually have a "Max allowed ram" most times its listed in the back of the manual in small print. Its a way to keep people buying new computers (if your into the conspiracy theories)
Chances are even a bios upgrade would not fix your problem. Mostly BIOS upgrades add support for new boot options, plug and play support, and fixes to bugs in older versions.
You can check aspires/acers website for updates www.acer.com
If they have an update it will comes with documentation as to what the update does.
Hope this helps you out.
Jei
Dec 15, 2008 | Acer Aspire 3000 Notebook
Updating BIOS
You need to upgrade your bios.
Heres the link the software.
ftp://ftp.work.acer-euro.com/notebook/aspire_5630/bios/Bios%203.23.zip
You will need winzip or winrar to open the zip file just google either if you dont have them you can get them for free.
You then need to open the folder you just uncompressed and you will see another zip file, winflash is in there. it will allow you to flash the bios from within windows, just install it and follow the instructions on your screen
Dont forget to rate this solution
Aug 23, 2008 | Computers & Internet
Acer Aspire 9300 Notebook Logo
1,680 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
