Question about Maytag Ensignia MAV2757AWW Top Load Washer
At end of cycle washer is full of water..intermittent problem
Not everytime probably half the time in use the washing machine(MAV2757aww maytag) top loader will be full of water..doesnt seem to be the timer beacause it had traveled to the end of cycle...not the door switch I jumped it and it still did it...no kinks in lines either....intermittent problems sux..I rather see something on fire..then i could go there it is....Is this pointing to the pump on its way out..Help Help thanks
  • david_larame Feb 17, 2009
    Something I never would of thought of..it will be my next step..thanks
  • Anonymous Mar 09, 2009
    Checked between inner and outer tub ..no socks , kids toys all clear..no kinks in the hoses..Still having problems with standing water in tub at end of cycle timer has finished..I noticed after wash cycle the spin wasnt that fast..and the tub didnt drain..then went onto the rinse cycle..am i have problems with the timer missing a faster spin cycle to remove the water or does it spin slowly to remove the water..or am i have a pump problem ..I dont think its the pump..when ive see it pumping after rinse cycle the pumps seems fine.pumping strong.im thinking this my be an internal timer contact problem..... help!!
    Novelist:
  • 117 Answers
You may want to remove the inner tub and check for a article of clothing, hanky, sock, wash cloth or small baby item lodged between the inner and outer tubs. It floats and sporatically blocks the drain hole when the unit is suppose to be draining. I agree with you that is it not an electrical issue. Check this and let me know what you find.....
Waiting to hear from you,
Eric Campion
Posted on Feb 14, 2009
Washer will work in Rinse or Spin settings, but not any wash settings
If you are doing the normal procedures and the water elimination function is working, you have power to the circuit board and controls. The circuit board wash cycle section is independent and aligned with the timer circuit, thus the Wash Cycle Controller has failed. All of the functions or options are one the one board and a replacement board needs to be purchased and installed.
Feb 26, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag ensignia top load washer will not fill with water at start of the cycle?
The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
Aug 04, 2012 | Maytag Ensignia MAV2757AWW Top Load Washer
My Maytag MAV6000 washer leaks intermittently. In the past 3 weeks it has been used many times but has leaked 3 times. I removed the front panel to look at the pump and hoses and put the washer through a...
Realistically, a 10-year old Maytag is nearing the end of its usual life. The pump may be leaking at random times during a wash cycle. If you put 50% of the cost of a new one into repairs, it is time to thing seriously about replacement of the machine.
Apr 26, 2017 | Maytag Atlantis MAV6000 Top Load Washer
Tub is filling with water while off. is it the control valve inside the washing mach?
You need to check your water level switch. Make sure the clear hose that runs from the tub to the control panel is clear, not kinked or clogged and has not come loose at either end. Hope this helps
Mar 21, 2010 | Maytag Ensignia MAV2757AWW Top Load Washer
Water fills the tub then nothing happens.
it does not aggitate? Thats the cycle that allows the water to wash the clothes. It may be broken, I have had that happen a couple times. I would take the aggitator off and see if the teeth in the groves are worn out, It happen's when used alot. Commen problem and easy to replace.
Apr 05, 2009 | Maytag Ensignia MAV2757AWW Top Load Washer
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Ensignia MAV2757AWW Top Load Washer Logo
302 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
